查看: 5569|回復(fù): 11
Arduino加5110屏+TEA5767組成的數(shù)調(diào)收音機(jī)源程序
ID:722919 發(fā)表于 2020-5-7 22:43 | 顯示全部樓層 |閱讀模式
接線圖
接線圖
  1. #include <TEA5767N.h>  //https://github.com/mroger/TEA5767
  2. #include <LCD5110_Graph.h> //http://www.rinkydinkelectronics點com/library.php?id=48
  3. LCD5110 lcd(8,9,10,12,11);
  4. TEA5767N radio = TEA5767N();
  5. extern unsigned char BigNumbers[];
  6. extern unsigned char TinyFont[];
  7. extern uint8_t splash[];
  8. extern uint8_t signal5[];
  9. extern uint8_t signal4[];
  10. extern uint8_t signal3[];
  11. extern uint8_t signal2[];
  12. extern uint8_t signal1[];
  13. int analogPin = 0;
  14. int val = 0;
  15. int frequencyInt = 0;
  16. float frequency = 0;
  17. float previousFrequency = 0;
  18. int signalStrength = 0;
  19. void setup()
  20. {
  21.   radio.setMonoReception();
  22.   radio.setStereoNoiseCancellingOn();
  23.   initScreen();
  24.   showSplashScreen();
  25.   Serial.begin(9600);
  26. }
  27. void loop() {
  28.
  29.   for(int i;i<30;i++)
  30.   {
  31.      val = val + analogRead(analogPin);
  32.      delay(1);
  33.   }
  34.
  35.   val = val/30;
  36.   frequencyInt = map(val, 2, 1014, 8700, 10700); //Analog value to frequency from 87.0 MHz to 107.00 MHz
  37.   float frequency = frequencyInt/100.0f;
  38.   if(frequency - previousFrequency >= 0.1f || previousFrequency - frequency >= 0.1f)
  39.   {
  40.     lcd.clrScr();
  41.     radio.selectFrequency(frequency);
  42.     printSignalStrength();
  43.     printStereo();
  44.     printFrequency(frequency);
  45.     previousFrequency = frequency;
  46.   }
  47.
  48.   lcd.clrScr();
  49.   printSignalStrength();
  50.   printStereo();
  51.   printFrequency(frequency);
  52.   delay(50);
  53.   val = 0;
  54. }
  55. void initScreen()
  56. {
  57.   lcd.InitLCD();
  58.   lcd.setFont(BigNumbers);
  59.   lcd.clrScr();
  60. }
  61. void showSplashScreen()
  62. {
  63.   lcd.drawBitmap(0, 0, splash, 84, 48);
  64.   lcd.update();
  65.   delay(3000);
  66.   lcd.clrScr();
  67.   lcd.update();
  68. }
  69. void printFrequency(float frequency)
  70. {
  71.   String frequencyString = String(frequency,1);
  72.   if(frequencyString.length() == 4)
  73.   {
  74.     lcd.setFont(BigNumbers);
  75.     lcd.print(frequencyString,14,12);
  76.     lcd.update();
  77.   }
  78.   else
  79.   {
  80.     lcd.setFont(BigNumbers);
  81.     lcd.print(frequencyString,0,12);
  82.     lcd.update();
  83.   }
  84. }
  85. void printStereo()
  86. {
  87.     boolean isStereo = radio.isStereo();
  88.      if(isStereo)
  89.     {
  90.       lcd.setFont(TinyFont);
  91.       lcd.print("STEREO",55,2);
  92.     }
  93. }
  94. void printSignalStrength()
  95. {
  96.   signalStrength = radio.getSignalLevel();
  97.   String signalStrenthString = String(signalStrength);
  98.   if(signalStrength >=15)
  99.   {
  100.     lcd.drawBitmap(1, 1, signal5, 17 , 6);
  101.   }else if(signalStrength >=11 && signalStrength <15)
  102.   {
  103.     lcd.drawBitmap(1, 1, signal4, 17 , 6);
  104.   }
  105.   else if(signalStrength >=9 && signalStrength <11)
  106.   {
  107.     lcd.drawBitmap(1, 1, signal3, 17 , 6);
  108.   }
  109.    else if(signalStrength >=7 && signalStrength <9)
  110.   {
  111.     lcd.drawBitmap(1, 1, signal2, 17 , 6);
  112.   }
  113.    else if(signalStrength <7)
  114.   {
  115.     lcd.drawBitmap(1, 1, signal1, 17 , 6);
  116.   }
  117. }
FMRadio(tea5767_5110-nano).zip
2.09 KB, 下載次數(shù): 74
完整代碼
參與人數(shù) 2黑幣 +65 收起 理由
wangshoukai + 15
admin + 50 共享資料的黑幣獎勵!
ID:701198 發(fā)表于 2020-5-8 16:12 | 顯示全部樓層
找了好久終于找到了,感謝樓主分享
ID:701198 發(fā)表于 2020-5-8 16:13 | 顯示全部樓層
感謝樓主分享,終于找到了。
ID:378732 發(fā)表于 2020-8-5 19:58 | 顯示全部樓層
這個電路圖是用什么畫的
ID:798252 發(fā)表于 2020-8-7 10:44 | 顯示全部樓層
ty417502873 發(fā)表于 2020-8-5 19:58
這個電路圖是用什么畫的
應(yīng)該是fritzing畫的
ID:979259 發(fā)表于 2021-11-8 20:18 | 顯示全部樓層
如何搜臺的?
ID:1061340 發(fā)表于 2023-1-17 15:43 | 顯示全部樓層
通過旋轉(zhuǎn)電位器搜索電臺
ID:1075262 發(fā)表于 2023-7-12 16:52 | 顯示全部樓層
求教:有沒有大佬做成功的?我怎么頻率卡在87Mhz,頻率電位器怎么調(diào)都不變。
ID:1083556 發(fā)表于 2023-7-23 00:49 | 顯示全部樓層
找了好久終于找到了,感謝樓主分享
ID:1088165 發(fā)表于 2023-7-23 21:51 | 顯示全部樓層
程序報錯,有能解決嗎?
Arduino:1.8.13 (Windows 10), 開發(fā)板:"Arduino Uno"
D:\arduino\arduino作品\Arduino加5110屏+TEA5767組成的數(shù)調(diào)收音機(jī)源程序\51黑論壇_FMRadio(tea5767_5110-nano)\FMRadio\FMRadio1\FMRadio1.ino: In function 'void printStereo()':
D:\arduino\arduino作品\Arduino加5110屏+TEA5767組成的數(shù)調(diào)收音機(jī)源程序\51黑論壇_FMRadio(tea5767_5110-nano)\FMRadio\FMRadio1\FMRadio1.ino:101:30: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\Administrator\Documents\Arduino\libraries\TEA5767-master\TEA5767N.cpp: In function 'transmitData.constprop':
C:\Users\Administrator\Documents\Arduino\libraries\TEA5767-master\TEA5767N.cpp:92:13: warning: iteration 5 invokes undefined behavior [-Waggressive-loop-optimizations]
   Wire.write(transmission_data[i]);
C:\Users\Administrator\Documents\Arduino\libraries\TEA5767-master\TEA5767N.cpp:91:18: note: within this loop
  for (int i=0 ; i<6 ; i++) {
C:\Users\Administrator\AppData\Local\Temp\cclP43mC.ltrans0.ltrans.o: In function `printSignalStrength':
D:\arduino\arduino作品\Arduino加5110屏+TEA5767組成的數(shù)調(diào)收音機(jī)源程序\51黑論壇_FMRadio(tea5767_5110-nano)\FMRadio\FMRadio1/FMRadio1.ino:111: undefined reference to `signal5'
D:\arduino\arduino作品\Arduino加5110屏+TEA5767組成的數(shù)調(diào)收音機(jī)源程序\51黑論壇_FMRadio(tea5767_5110-nano)\FMRadio\FMRadio1/FMRadio1.ino:114: undefined reference to `signal4'
D:\arduino\arduino作品\Arduino加5110屏+TEA5767組成的數(shù)調(diào)收音機(jī)源程序\51黑論壇_FMRadio(tea5767_5110-nano)\FMRadio\FMRadio1/FMRadio1.ino:118: undefined reference to `signal3'
D:\arduino\arduino作品\Arduino加5110屏+TEA5767組成的數(shù)調(diào)收音機(jī)源程序\51黑論壇_FMRadio(tea5767_5110-nano)\FMRadio\FMRadio1/FMRadio1.ino:122: undefined reference to `signal2'
C:\Users\Administrator\AppData\Local\Temp\cclP43mC.ltrans0.ltrans.o: In function `showSplashScreen':
D:\arduino\arduino作品\Arduino加5110屏+TEA5767組成的數(shù)調(diào)收音機(jī)源程序\51黑論壇_FMRadio(tea5767_5110-nano)\FMRadio\FMRadio1/FMRadio1.ino:72: undefined reference to `splash'
collect2.exe: error: ld returned 1 exit status
exit status 1
為開發(fā)板 Arduino Uno 編譯時出錯。
在文件 -> 首選項開啟
“編譯過程中顯示詳細(xì)輸出”選項
這份報告會包含更多信息。
ID:1075262 發(fā)表于 2023-7-24 15:19 | 顯示全部樓層
uno是可以通過編譯的,你是否已經(jīng)把FMRadio.ino,icons.c,splash.c 三個文件放在一個目錄里?
ID:369888 發(fā)表于 2023-7-30 13:11 | 顯示全部樓層
Fritzing中 TEA5767   LM386   5110  的原件庫怎么弄的,能發(fā)我一下嗎
