可去皮,重量微調(diào),語音播報重量。
單片機源程序如下:
- #include "main.h"
- #include "LCD1602.h"
- #include "HX711.h"
- //#include"eeprom.h"
- unsigned long HX711_Buffer = 0;
- unsigned int Weight_Maopi = 0,Weight_Shiwu = 0;
- char Price_Count = 0;
- unsigned char KEY_NUM = 0;
- unsigned char Price_Buffer[3] = {0x00,0x00,0x00};
- unsigned long Money = 0;
- bit Flag_OK = 0;
- unsigned int Weight=10,s1num=0; //報警值初始化 按鍵計數(shù)標(biāo)志
- float m__1=2.90;
- //語音播報程序
- sbit MUSIC_REST =P2^2;//語音芯片復(fù)位腳
- sbit MUSIC_DATA =P2^1;//語音芯片脈沖識別
- sbit bus =P2^0;//語音芯片工作狀態(tài)識別信號
- unsigned char bbh,xm1,xm2,xm0,xm3;
- void delay_us(unsigned int us)
- while(us--)
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- void Music(unsigned char music_count)
- MUSIC_REST=1;
- delay_us(200);
- MUSIC_REST=0;
- delay_us(200);
- while(music_count>0)
- MUSIC_DATA=1;
- delay_us(100);
- MUSIC_DATA=0;
- delay_us(100);
- music_count--;
- void Msc()
- if((xm0+xm1+xm2+xm3)!=0) //當(dāng)超出測量范圍時不進行播報
- Music(16); //播報:“ 重量 ”
- while(!bus);
- if(xm0==0)
- Music(2); //播報:“千位數(shù)具體值” 0
- while(!bus);
- else Music(xm0+2); //播報:“千位數(shù)具體值”
- while(!bus);
- // Music(14); //播報:“點”
- // while(!bus);
- if(xm1==0)
- Music(2); //播報:“百位數(shù)具體值” 0
- while(!bus);
- else Music(xm1+2); //播報:“千位數(shù)具體值”
- while(!bus);
- if((xm2+xm3)!=0)
- Music(xm2+2); //播報:“十分位的具體值”
- while(!bus);
- Music(xm3+2); //播報:“百分位的具體值”
- while(!bus);
- Music(15); //播報:“單位”
- while(!bus);
- else
- while(!bus);
- //主函數(shù)
- void main()
- Init_LCD1602(); //初始化LCD1602
- LCD1602_write_com(0x80); //指針設(shè)置
- LCD1602_write_word("Welcome to use! "); //開機畫面第一行
- Delay_ms(2000); //延時2s
- Price_Buffer[0] = 0;
- Price_Buffer[1] = 0;
- Price_Buffer[2] = 0;
- Flag_OK = 0;
- LCD1602_write_word(" Test weight ");//重量檢測儀
- LCD1602_write_com(0x80+0x40); //指針設(shè)置
- LCD1602_write_word("weight: g ");
- Get_Maopi(); //稱毛皮重量
- while(1)
- Get_Weight(); //稱重
- KEY_Scan();
- //稱重
- void Get_Weight()
- HX711_Buffer = HX711_Read();
- HX711_Buffer = HX711_Buffer/100;
- if(HX711_Buffer > Weight_Maopi)
- Weight_Shiwu = HX711_Buffer;
- Weight_Shiwu = Weight_Shiwu - Weight_Maopi; //獲取實物的AD采樣數(shù)值。
- Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/m__1+0.05); //計算實物的實際重量
- //因為不同的傳感器特性曲線不一樣,因此,每一個傳感器需要矯正這里的4.30這個除數(shù)。
- //當(dāng)發(fā)現(xiàn)測試出來的重量偏大時,增加該數(shù)值。
- //如果測試出來的重量偏小時,減小改數(shù)值。
- //該數(shù)值一般在4.0-5.0之間。因傳感器不同而定。
- //+0.05是為了四舍五入百分位
- if(Weight_Shiwu >500 )Weight_Shiwu=500;
- if(Weight_Shiwu < 5)Weight_Shiwu=0;
- xm0=Weight_Shiwu/1000 ;
- xm1=Weight_Shiwu%1000/100;
- xm2=Weight_Shiwu%100/10;
- xm3=Weight_Shiwu%10;
- LCD1602_write_com(0x80+0x40+7);
- LCD1602_write_data(xm0+ 0x30);
- LCD1602_write_data(xm1 + 0x30);
- LCD1602_write_data(xm2 + 0x30);
- LCD1602_write_data(xm3 + 0x30);
- void delay(unsigned int x) //毫秒級延時函數(shù)
- unsigned int i,j;
- for(i=x;i>0;i--)
- for(j=110;j>0;j--);
- void KEY_Scan()
- while(!k4)
- bbh=1;
- if(bbh==1) //bb=1調(diào)用一次播報程序
- bbh=0;
- Msc();
- if(key1==0) //
- delay(10);
- if(key1==0)
- while(!key1); //
- Get_Maopi(); //去皮
- if(key2==0) //
- delay(10);
- if(key2==0)
- while(!key2); // 微調(diào)重量-
- m__1=m__1+0.10;
- if(m__1>=5.10)m__1=5.00;
- if(key3==0) //
- delay(10);
- if(key3==0)
- while(!key3); // 微調(diào)重量+
- m__1=m__1-0.10;
- if(m__1<=1.10)m__1=2.50;
- //獲取毛皮重量
- void Get_Maopi()
- Weight_Maopi = HX711_Buffer/100;
- //MS延時函數(shù)(12M晶振下測試)
- void Delay_ms(unsigned int n)
- unsigned int i,j;
- for(i=0;i<n;i++)
- for(j=0;j<123;j++);
電子稱設(shè)計.zip
(174.55 KB, 下載次數(shù): 60)
2020-5-8 20:52 上傳
點擊文件名下載附件
