1.前期準(zhǔn)備 準(zhǔn)備好杜邦線、HC-06藍(lán)牙模塊、單片機(jī)(我用的是粵嵌的51單片機(jī),自己做一個(gè)最小系統(tǒng)也行)、小車底盤、電源、L298N、螺柱(固定零件用的)。如果想做的話請自己買這些零件,做出來的效果圖片如下(我加了尋跡模塊)。
2.開工
///8個(gè)LED燈
sbit led1 = P1^0;
sbit led2 = P1^1;
sbit led3 = P1^2;
sbit led4 = P1^3;
sbit led5 = P1^4;
sbit led6 = P1^5;
sbit led7 = P1^6;
sbit led8 = P1^7;
sbit bell = P0^7;
//電機(jī)引腳
sbit La = P0^0;
sbit Lb = P0^1;
sbit Ra = P0^2;
sbit Rb = P0^3; 2.用到的主要知識就是中斷了。我本來想做一個(gè)尋跡和藍(lán)牙控制一體的小車(但是尋跡并沒有做好,所以這里就只給大家寫藍(lán)牙模塊怎么實(shí)現(xiàn)了),想了想當(dāng)尋跡模式立即轉(zhuǎn)到藍(lán)牙控制模式時(shí)(或者藍(lán)牙模式立即轉(zhuǎn)換成尋跡模式)好像也只有中斷可以,所以就加了個(gè)中斷來掃描看有沒有收到轉(zhuǎn)換信號。我的代碼如下。 include <reg52.h> sbit led1 = P1^0;
sbit led2 = P1^1;
sbit led3 = P1^2;
sbit led4 = P1^3;
sbit led5 = P1^4;
sbit led6 = P1^5;
sbit led7 = P1^6;
sbit led8 = P1^7;
sbit bell = P0^7;
sbit K1 = P3^3;
sbit K2 = P3^4;
sbit K3 = P3^6;
sbit K4 = P3^7;
sbit La = P0^0;
sbit Lb = P0^1;
sbit Ra = P0^2;
sbit Rb = P0^3;
sbit right = P0^4;
sbit left = P0^5;
sbit down_right = P0^6;
sbit down_left = P2^7; unsigned char a = 0;
unsigned char num = 0;
unsigned char temp = 0; bit auto_run = 0;
bit lanya_run = 1; void uart_init();
void delay(unsigned int time);
void go_up();
void go_down();
void turn_left();
void turn_right();
void bell_on();
void bell_off();
void led_all_on();
void led_all_off();
void go_around_shun();
void go_around_li();
void stop();
void change_name();
void init_T0(); void main() {
uart_init();
init_T0();
change_name();
while(1) {
if(lanya_run == 1) {
while(1) {
if(lanya_run != 1) {
break;
if (num != 0) {
ES = 0;
num = 0;
SBUF = a;
while (!TI);
TI = 0;
ES = 1;
switch (a)
case '0': go_up(); bell_on(); break;
case '1': go_down(); bell_on(); break;
case '2': turn_left(); bell_on(); break;
case '3': turn_right(); bell_on(); break;
case '5': go_around_shun(); bell_on(); break;
case '6': led_all_on(); break;
case '7': led_all_off(); break;
case '8': go_around_li(); bell_on(); break;
default: stop(); bell_off(); break;
if(auto_run == 1) {
while(1) {
if(auto_run != 1) {
break;
if (num != 0) {
ES = 0;
num = 0;
SBUF = a;
while (!TI);
TI = 0;
ES = 1;
go_up();
if (!left && right) {
go_around_shun();
bell_on();
delay(50);
bell_off();
delay(1000);
if (!right && left) {
go_around_li();
bell_on();
delay(50);
bell_off();
delay(1000);
if(!right && !left) {
go_down();
bell_on();
delay(50);
bell_off();
delay(1000);
if(left && right) {
go_up();
delay(100);
} void uart_fun() interrupt 4 {
RI = 0;
a = SBUF;
num++;
} void T0Int() interrupt 1 {
TH0 = 0xD8;
TL0 = 0xF0; temp++; if(temp == 10) {
temp = 0;
if(a == '9' && lanya_run == 1) {
lanya_run = 0;
auto_run = 1;
if(a == '9' && lanya_run == 0) {
lanya_run = 1;
auto_run = 0;
} void uart_init() {
TMOD = 0x20; //設(shè)置定時(shí)器設(shè)置
TH1 = 0xFD; //設(shè)置初始波特率9600
TL1 = 0xFD; //
TR1 = 1; //開啟定時(shí)器1
SM0 = 0; //設(shè)置串行工作方式
SM1 = 1; //
REN = 1; //允許傳興接受位
EA = 1; //開啟總中斷
ES = 1; //開啟串口中斷口
} void delay(unsigned int time) {
int i = 121;
while(time--)
while(i--);
} void stop()
La = 0;
Lb = 0;
Ra = 0;
Rb = 0;
} void go_around_shun() {
La = 1;
Lb = 0;
Ra = 0;
Rb = 1;
} void go_around_li() {
La = 0;
Lb = 1;
Ra = 1;
Rb = 0;
} void go_down() {
La = 0;
Lb = 1;
Ra = 0;
Rb = 1;
} void go_up() {
La = 1;
Lb = 0;
Ra = 1;
Rb = 0;
} void turn_right() {
La = 1;
Lb = 0;
Ra = 1;
Rb = 0;
delay(5);
Ra = 0;
delay(5);
} void turn_left() {
Ra = 1;
Rb = 0;
La = 1;
Lb = 0;
delay(5);
La = 0;
delay(5);
} void change_name() {
char name[] = "AT+NAME=StarSea\r\n";
char i;
for(i = 0; i < sizeof(name); i++) {
SBUF = name[ i];
while(!TI);
TI = 0;
delay(500);
} [ i]void bell_on() {
bell = 0;
} void bell_off() {
bell = 1;
} void led_all_on() {
P0 = 0x00;
} [ i]void led_all_off() {
P0 = 0x11;
} void init_T0() {
TMOD = 0x21;
TH0 = 0xD8;
TL0 = 0xF0;
EA = 1;
ET0 = 1;
TR0 = 1;
- 把程序燒入單片機(jī),再把收到的小車底盤零件拼起來,其他配件用杜邦線和對應(yīng)引腳連接起來。
- 下載藍(lán)牙串口這個(gè)程序。以編輯前進(jìn)按鈕為例:我的代碼中,收到字符0就前進(jìn)收到字符4就停下。所以這里按下就發(fā)送0,松開就發(fā)送4。我的所有按鈕如圖(自動駕駛就是尋跡,但是沒有做好)。
- 通過藍(lán)牙串口連接HC-05(默認(rèn)的藍(lán)牙名字)即可開始用自制的藍(lán)牙小車了。
