該程序是論壇某位大佬的,不過是F4的。稍加修改,適用于F103系列(2.8寸觸摸屏)。
單片機源程序如下:
- #include "led.h"
- #include "delay.h"
- #include "key.h"
- #include "sys.h"
- #include "lcd.h"
- #include "usart.h"
- #include "24cxx.h"
- #include "w25qxx.h"
- #include "touch.h"
- //兩個數(shù)之差的絕對值
- //x1,x2:需取差值的兩個數(shù)
- //返回值:|x1-x2|
- u16 my_abs(u16 x1,u16 x2)
- if(x1>x2)return x1-x2;
- else return x2-x1;
- //5個觸控點的顏色
- const u16 POINT_COLOR_TBL[CT_MAX_TOUCH]={RED,GREEN,BLUE,BROWN,GRED};
- //電阻觸摸屏測試函數(shù)
- /*void rtp_test(void)
- u8 key;
- u8 i=0;
- while(1)
- key=KEY_Scan(0);
- tp_dev.scan(0);
- if(tp_dev.sta&TP_PRES_DOWN) //觸摸屏被按下
- if(tp_dev.x[0]<lcddev.width&&tp_dev.y[0]<lcddev.height)
- if(tp_dev.x[0]>(lcddev.width-24)&&tp_dev.y[0]<16)Load_Drow_Dialog();//清除
- else TP_Draw_Big_Point(tp_dev.x[0],tp_dev.y[0],RED); //畫圖
- }else delay_ms(10); //沒有按鍵按下的時候
- if(key==KEY0_PRES) //KEY0按下,則執(zhí)行校準(zhǔn)程序
- LCD_Clear(WHITE);//清屏
- TP_Adjust(); //屏幕校準(zhǔn)
- Load_Drow_Dialog();
- i++;
- if(i%20==0)LED0=!LED0;
- //加載鍵盤控制界面
- //x,y:界面起始坐標(biāo)
- //py_load_ui(0,0)
- void py_load_ui(u16 x,u16 y)
- POINT_COLOR=RED;
- LCD_DrawRectangle(x,y,x+240,y+200);
- LCD_DrawLine(x,y+100,x+240,y+100);
- LCD_DrawLine(x+120,y,x+120,y+200);
- LCD_Fill(x+2,y+2,x+118,y+98,WHITE);//控制LED1
- LCD_Fill(x+122,y+2,x+238,y+98,WHITE);//控制LED2
- LCD_Fill(x+2,y+102,x+118,y+198,WHITE);//控制LED1 LED2 開
- LCD_Fill(x+122,y+102,x+238,y+198,WHITE);//控制LED1 LED2 關(guān)
- POINT_COLOR=BLACK;
- LCD_ShowString(x+39,y+38,lcddev.width,lcddev.height,24,"LED1");
- LCD_ShowString(x+153,y+38,lcddev.width,lcddev.height,24,"LED2");
- LCD_ShowString(x+39,y+138,lcddev.width,lcddev.height,24,"LED_ON");
- LCD_ShowString(x+153,y+138,lcddev.width,lcddev.height,24,"LED_OFF");
- //按鍵狀態(tài)設(shè)置
- //x,y:鍵盤坐標(biāo)
- //key:鍵值(0~8)
- //sta:狀態(tài),0,松開;1,按下;
- void py_key_staset(u16 x,u16 y,u8 keyx,u8 sta)
- u16 i=keyx/2,j=keyx%2;
- if(keyx>8)return;
- if(sta)
- LCD_Fill(x+j*120+1,y+i*100+1,x+j*120+119,y+i*100+99,GREEN);//按鍵按下
- else
- LCD_Fill(x+j*120+1,y+i*100+1,x+j*120+119,y+i*100+99,WHITE);
- //得到觸摸屏的輸入
- //x,y:鍵盤坐標(biāo)
- //返回值:按鍵鍵值(1~9有效;0,無效)
- //key=py_get_keynum(250,140); 640*320
- u8 py_get_keynum(u16 x,u16 y)
- u16 i,j;
- static u8 key_x=0;//0,沒有任何按鍵按下;1~4,1~4號按鍵按下
- u8 key=0;
- tp_dev.scan(0); //屏幕掃描
- for(i=0;i<2;i++)
- for(j=0;j<2;j++)
- if(tp_dev.x[0]<(x+j*120+120)&&tp_dev.x[0]>(x+j*120)&&tp_dev.y[0]<(y+i*100+100)&&tp_dev.y[0]>(y+i*100))
- key=i*2+j+1;
- break;
- if(key)
- if(key_x==key)key=0;
- else
- py_key_staset(x,y,key_x-1,0);
- key_x=key;
- py_key_staset(x,y,key_x-1,1);
- break;
- else if(key_x) //如果要記錄按下后的狀態(tài) 這句話需要被注釋掉
- key_x=0;
- return key;
- tp_dev.init();
- LCD_ShowString(60,130,200,16,16,"Press KEY0 to Adjust");
- if(tp_dev.touchtype!=0XFF)LCD_ShowString(60,130,200,16,16,"Press KEY0 to Adjust");//電阻屏才顯示
- delay_ms(1500);
- if(tp_dev.touchtype&0X80); //電容屏測試
- else rtp_test(); //電阻屏測試
- int main(void)
- u8 key;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級分組2
- delay_init(); //初始化延時函數(shù)
- uart_init(115200); //初始化串口波特率為115200
- LED_Init(); //初始化LED
- LCD_Init(); //LCD初始化
- KEY_Init();
- tp_dev.init(); //初始化觸摸屏
- LCD_ShowString(120,72,lcddev.width,lcddev.height,16,"LED CONTROL SYSTEM");
- py_load_ui(0,0);
- while(1)
- delay_ms(10);
- key=py_get_keynum(0,0);
- switch(key)
- case 1 :LED0=!LED0;break;
- case 2 :LED1=!LED1;break;
- case 3 :LED0=LED1=1;break;/*GPIO_ResetBits(GPIOC,GPIO_Pin_4 | GPIO_Pin_5)*/
- case 4 :LED0=LED1=0;break;/*GPIO_SetBits(GPIOC,GPIO_Pin_4 | GPIO_Pin_5);break;*/
- //可以用來控制開關(guān)機等
- // key=KEY_Scan(0);
- // if(key==KEY2_PRES)//KEY2按下
觸摸屏虛擬按鍵程序.7z
(246.82 KB, 下載次數(shù): 94)
2020-5-9 16:48 上傳
點擊文件名下載附件
