圖片1為原圖,2為我照搬的圖
附上代碼-------
#include <reg51.h>
sbit open = P2^0;
sbit close = P2^1;
sbit swap = P2^2;
sbit sub_speed = P2^3;
sbit add_speed = P2^4;
sbit PWM1 = P3^0;
sbit PWM2 = P3^1;
/************************液晶顯示*************/
sbit E=P3^7;
sbit RW = P3^6;
sbit RS = P3^5;
sbit test = P3^4;
int time = 0;
int high = 20;
int period = 30;
int change = 0;
int flag = 0;
int num_medium = 0;
int num_display = 0;
int count_speed = 0;
uchar wword[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
/*******************延時t毫秒****************/
void delay(uchar t)
uint i;
while(t)
/*對于11.0592MHz時鐘,延時1ms*/
for(i=0;i<125;i++);
t--;
//寫命令函數(shù)LCD
void wc51r(uchar j)
RS=0;
RW=0;
P1=j;
E=1;
E=0;
delay(3);
//寫數(shù)據(jù)函數(shù)LCD
void wc51ddr(uchar j)
RS=1;
RW=0;
P1=j;
E=1;
E=0;
delay(2);
//初始化函數(shù)LCD
void init()
wc51r(0x01); //清屏
wc51r(0x38); //使用8位數(shù)據(jù),顯示兩行,使用5*7的字型
wc51r(0x0c); //顯示器件,光標(biāo)開,字符不閃爍
wc51r(0x06); //字符不動,光標(biāo)自動右移一格
/***********8T0中斷服務(wù)程序************PWM波的生成**********/
void time0_int(void) interrupt 1
time++;
TH0 = 0xec;
TL0 = 0x78;
if(change == 0)
PWM2 = 1;
if(time == high)
PWM1=0;
else if(time == period)
PWM1 = 1;
time = 0;
{ PWM1 = 1;
if(time == high)
PWM2=0;
PWM2 = 1;
time = 0;
/****T1中斷服務(wù)程序********單位時間(S)方波的個數(shù)*************/
void time1_int(void) interrupt 3
count_speed++;
if(count_speed == 20)
{ count_speed = 0;
num_display = num_medium;
num_medium = 0;
/************************速度顯示的數(shù)據(jù)處理*********************/
void datamade()
uint data MM,NN;
wc51r(0xc2);
wc51ddr('S');
wc51ddr('p');
wc51ddr('e');
wc51ddr('e');
wc51ddr('d');
wc51ddr(0x3a);
NN = num_display%100;
MM = num_display/100;
wc51ddr(wword[MM]);
MM = NN/10;
NN = NN%10;
wc51ddr(wword[MM]);
wc51ddr(wword[NN]);
/**********通過按鍵實現(xiàn)對電機(jī)開關(guān)、調(diào)速、轉(zhuǎn)向的控制***************/
void motor_control()
if(open == 1)
EA = 1;
if(close == 1)
EA = 0;
if(swap == 1)
change = ~change;
while(swap != 0)
if(sub_speed == 1)
high++;
if(high == 30)
EA=0;
while(sub_speed != 0)
if(add_speed == 1)
high--;
if(high == 5)
high = 5;
while(add_speed != 0)
/***************************主函數(shù)*********************************/
P2 = 0x00;
ET0 = 1;
ET1 = 1;
TMOD = 0x11;
TH0 = 0xec; //定時器T0設(shè)置參數(shù)
TL0 = 0x78;
TH1 = 0x3c; //定時器T1設(shè)置參數(shù)
TL1 = 0xb0;
TR0 = 1;
TR1 = 1;
init(); //液晶顯示初始化程序
wc51r(0x84);
wc51ddr('H');
wc51ddr('e');
wc51ddr('l');
wc51ddr('l');
wc51ddr('o');
if(test == 0)
num_medium++;
datamade();
motor_control();
