2020-5-11 14:48 上傳
- /*************** writer:shopping.w ******************/
- #include <reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit LED1 = P1^0;
- sbit LED2 = P1^3;
- sbit K1 = P1^7;
- uchar Operation_NO = 0;
- uchar code DSY_CODE[]=
- 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
- void Delay(uint x)
- uchar i;
- while(x--)
- for(i=0;i<120;i++);
- void putc_to_SerialPort(uchar c)
- SBUF = c;
- while(TI == 0);
- TI = 0;
- void main()
- LED1=LED2=1;
- P0 = 0x00;
- SCON = 0x50;
- TMOD = 0x20;
- PCON = 0x00;
- TH1 = 0xfd;
- TL1 = 0xfd;
- TI = 0;
- RI = 0;
- TR1 = 1;
- IE = 0x90;
- while(1)
- Delay(100);
- if(K1 == 0)
- while(K1==0);
- Operation_NO=(Operation_NO+1)%4;
- switch(Operation_NO)
- case 0:
- putc_to_SerialPort('X');
- LED1=LED2=1; break;
- case 1:
- putc_to_SerialPort('A');
- LED1=0;LED2=1;break;
- case 2:
- putc_to_SerialPort('B');
- LED2=0;LED1=1;break;
- case 3:
- putc_to_SerialPort('C');
- LED1=0;LED2=0;break;
- void Serial_INT() interrupt 4
- if(RI)
- RI = 0;
- if(SBUF>=0&&SBUF<=9)
- P0 = DSY_CODE[SBUF];
- else
- P0 = 0x00;
單片機(jī)之間雙向通信.zip
(85.59 KB, 下載次數(shù): 22)
2020-5-11 10:52 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
