原理圖
2020-5-12 13:05 上傳
部分代碼如下:
- * Function: 24c02驅(qū)動(dòng)
- * Description: 256個(gè)尋址單元 00~ff 32頁(yè)每頁(yè)8b
- * Parameter:
- * Return: *
- 記錄
- 5.5
- 1.二進(jìn)制書(shū)寫(xiě)格式010101010 前面加個(gè)0即可
- #include<reg51.h>
- #include"intrins.h"
- typedef unsigned char uint8;
- typedef char int8;
- typedef unsigned int uint16;
- typedef unsigned char uchar;
- sbit function=P3^5; //按鍵信號(hào)輸入口
- sbit buzzer=P3^3; //蜂鳴器信號(hào)口
- sbit dula=P2^6; //數(shù)碼管段選信號(hào)
- sbit wela=P2^7; //數(shù)碼管位選信號(hào)
- sbit sda=P2^0 ; //24c02數(shù)據(jù)信號(hào)
- sbit scl=P2^1 ; //24c02時(shí)鐘信號(hào)
- uint8 code table[]={ //數(shù)字代碼
- 0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- float speed,mileage; //測(cè)得的速度 及 里程
- uint8 count; //定時(shí)器0 中斷計(jì)數(shù)
- uint8 frontcount; //外部中斷0 計(jì)數(shù)
- * Function: 微秒級(jí)延時(shí)函數(shù)
- void us_delay( uint16 count )
- while( --count )
- _nop_();
- * Function: 毫秒延時(shí)函數(shù)
- void ms_delay(uint8 t)
- uint8 x,y;
- for(x=t;x>0;x--)
- for(y=110;y>0;y--);
- * Function: 蜂鳴器函數(shù)
- void beep()
- buzzer=0;
- ms_delay(100);
- buzzer=1;
- * Function: 數(shù)碼管顯示函數(shù)
- * Description: 共三位數(shù)碼管,顯示速度及里程 *
- void display(uint8 shu)
- uint8 bai,shi,ge;
- bai=shu/100;
- shi=shu%100/10;
- ge=shu%10;
- dula=1;
- P0=table[bai]; //送段選數(shù)據(jù)
- dula=0;
- P0=0xff;
- wela=1;
- P0=0x7e; //送位選數(shù)據(jù)
- wela=0;
- ms_delay(1);
- dula=1;
- P0=table[shi];
- dula=0;
- P0=0xff;
- wela=1;
- P0=0x7d;
- wela=0;
- ms_delay(1);
- dula=1;
- P0=table[ge];
- dula=0;
- P0=0xff;
- wela=1;
- P0=0x7b;//原來(lái)是0xfb 第八位是高 現(xiàn)在要保證實(shí)驗(yàn)班上片選信號(hào)始終為低
- wela=0;
- ms_delay(1);
- * Function: 24c02初始化
- void store_init()
- sda=1;
- us_delay(2);
- scl=1;
- us_delay(2);
- * Function: 啟動(dòng)信號(hào)
- * Description: scl在高電平期間 sda地跳變
- void store_start()
- sda=1;
- us_delay(2);
- scl=1;
- us_delay(2);
- sda=0;
- us_delay(2);
- * Function: 停止信號(hào)
- * Description: scl在高電平期間 sda高跳變
- void store_stop()
- sda=0;
- us_delay(2);
- scl=1;
- us_delay(2);
- sda=1;
- us_delay(2);
- * Function: 應(yīng)答信號(hào)
- void store_respons()
- uchar i;
- scl=1;
- us_delay(2);
- while((sda==1)&&(i<250))
- i++;
- scl=0;
- us_delay(2) ;
- * Function: 寫(xiě)一個(gè)字節(jié)
- void store_write_byte(uchar date)
- uchar i ;
- for(i=0;i<8;i++)
- scl=0;
- us_delay(2);
- sda=date&0x80;
- us_delay(2);
- scl=1;
- us_delay(2);
- date<<=1;
- scl=0; // 在scl=1 時(shí)間段 取sda的值
- us_delay(2);
- sda=1;
- us_delay(2);
- * Function: 讀一個(gè)字節(jié)
- uchar store_read_byte()
- uchar date ,i;
- for(i=0;i<8;i++)
- scl=1;
- us_delay(2) ;
- date=(date<<1)|sda;
- scl=0;
- us_delay(2) ;
- return date ;
- * Function: 寫(xiě)入指定位置 一個(gè)字節(jié)的數(shù)據(jù)
- void store_write_add(uchar address,uchar date)
- store_start();
- store_write_byte(0xa0); //最后一位0代表 方向 寫(xiě)
- store_respons();
- store_write_byte(address); //寫(xiě)入的地址
- store_respons();
- store_write_byte(date); //寫(xiě)入的數(shù)據(jù)
- store_respons();
- store_stop();
- * Function: 讀出指定位置 一個(gè)字節(jié)的數(shù)據(jù)
- uchar store_read_add(uchar address)
- uchar date;
- store_start();
- store_respons();
- store_respons();
- store_start();
- store_write_byte(0xa1); //最后一位1代表 方向 讀
- store_respons();
- date=store_read_byte(); //讀 剛才寫(xiě)入的地址內(nèi) 數(shù)據(jù)
- store_stop();
- return date;
- * Function: 按鍵信號(hào)檢測(cè)程序
- * Description: 1、按一次跳轉(zhuǎn)到里程數(shù) 2、長(zhǎng)按清除里程數(shù)
- void keyscan()
- if(function==0)
- ms_delay(10);
- if(function==0) //短按檢測(cè)
- while(!function);
- ms_delay(8);
- beep();
- mileage=store_read_add(0x00);
- display(mileage); //顯示里程
- if(function==0) //長(zhǎng)按檢測(cè)
- ms_delay(50);
- if(function==0)
- while(!function);
- ms_delay(8);
- beep();
- store_write_add(0x00,0); //清除 AT24c02上的數(shù)據(jù)
- * Function: 報(bào)警檢測(cè)程序
- * Description: 當(dāng)速度大于 120KM/h時(shí) 蜂鳴器響
- void alarm()
- if(speed>120)
- beep();
- * Function: 初始化函數(shù)
- void init()
- wela=0;
- dula=0;
- TMOD=0x01;
- TH0=(65536-50000)/256; // 50ms計(jì)數(shù)一次
- TL0=(65536-50000)%256;
- EA=1;
- ET0=1;
- TR0=1;
- EX0=1; //外部中斷0
- IT0=1; //開(kāi)啟外部中斷
- store_init(); //AT24c02初始化
- void main()
- init();
- while(1)
- display(speed);
- keyscan();
- alarm();
- * Function: 外部中斷0 函數(shù)
- void w0() interrupt 0
- frontcount++;
- * Function: 定時(shí)器0 中斷函數(shù)
- void time0() interrupt 1
- count++;
- if(count==20) //1秒鐘采集一次
- count=0;
- speed= frontcount*2*3.14*0.3*3.6; //速度計(jì)算 KM/h
- frontcount=0;
- mileage=mileage+frontcount*2*3.14*0.3*0.001; //里程數(shù) 累加
- store_write_add(0x00,mileage); //里程數(shù) 寫(xiě)入存儲(chǔ)器
文檔51hei下載地址:
汽車(chē)車(chē)速檢測(cè)系統(tǒng)設(shè)計(jì).doc
(518.17 KB, 下載次數(shù): 14)
2020-5-12 13:07 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
