查看: 3296|回復(fù): 6
單片機(jī)Proteus仿真lcd12864一直黑屏,麻煩指教
ID:749524 發(fā)表于 2020-5-12 14:04 | 顯示全部樓層 |閱讀模式
lcd一直黑屏
lcd一直黑屏
#include"12864.h"
#include"reg52.h"
#include <intrins.h>
sbit CS=P2^5;
sbit SID=P2^6;
sbit SCLK=P2^7;
unsigned char code AC_TABLE[]={
0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,
0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,
0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f,
0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f,
void SendByte(unsigned char Dbyte)
        unsigned char i;
        for(i=0;i<8;i++)
                SCLK = 0;
                Dbyte=Dbyte<<1;
                SID = CY;
                SCLK = 1;
                SCLK = 0;
unsigned char ReceiveByte(void)
        unsigned char i,temp1,temp2;
        temp1=temp2=0;
        for(i=0;i<8;i++)
                temp1=temp1<<1;
                SCLK = 0;
                SCLK = 1;
                SCLK = 0;
                if(SID) temp1++;
        for(i=0;i<8;i++)
                temp2=temp2<<1;
                SCLK = 0;
                SCLK = 1;
                SCLK = 0;
                if(SID) temp2++;
        return ((0xf0&temp1)+(0x0f&temp2));
void CheckBusy( void )
        do SendByte(0xfc);
        while(0x80&ReceiveByte());
void WriteCommand( unsigned char Cbyte )
        CS = 1;
        CheckBusy();
        SendByte(0xf8);
        SendByte(0xf0&Cbyte);
        SendByte(0xf0&Cbyte<<4);
        CS = 0;
void WriteData( unsigned char Dbyte )
        CS = 1;
        CheckBusy();
        SendByte(0xfa);
        SendByte(0xf0&Dbyte);
        SendByte(0xf0&Dbyte<<4);
        CS = 0;
void LcmInit( void )
     WriteCommand(0x30);
     WriteCommand(0x03);
     WriteCommand(0x0c);
     WriteCommand(0x01);
     WriteCommand(0x06);
void Location_xy_12864(unsigned char x,unsigned char y)
        switch(x)
                case 0:
                        x=0x80;break;
                case 1:
                        x=0x90;break;
                case 2:
                        x=0x88;break;
                case 3:
                        x=0x98;break;
                default:
                        x=0x80;
        y=y&0x07;
        WriteCommand(0x30);
        WriteCommand(y+x);
        WriteCommand(y+x);
void LcmClearTXT( void )
        unsigned char i;
        WriteCommand(0x30);
        WriteCommand(0x80);
        for(i=0;i<64;i++)
        WriteData(0x20);
        Location_xy_12864(0,0);
//??ê???
void PutStr(unsigned char row,unsigned char col,unsigned char *puts)
        WriteCommand(0x30);
        WriteCommand(AC_TABLE[8*row+col]);
        while(*puts != '\0')
                if(col==8)
                        col=0;
                        row++;
                if(row==4) row=0;
                WriteData(*puts);
                puts++;
                if(*puts != '\0')
                        WriteData(*puts);
                        puts++;
                        col++;
void Delay(unsigned int t)
        unsigned int m,n;
        for(m=0;m<t;m++);
        for(n=0;n<10;n++);
ID:89423 發(fā)表于 2020-9-23 19:34 | 顯示全部樓層
解決了嗎?我的也是這樣,求指導(dǎo)
ID:96682 發(fā)表于 2020-9-24 06:18 來自觸屏版 | 顯示全部樓層
選型很重要,仿真軟件沒有的只能上實(shí)物了
ID:272366 發(fā)表于 2020-9-24 14:35 | 顯示全部樓層
把這個(gè)CheckBusy,全部去掉試試
ID:728202 發(fā)表于 2020-9-24 14:43 | 顯示全部樓層
我寫的驅(qū)動(dòng),可以實(shí)現(xiàn)自動(dòng)換行。英文字母和符號(hào)顯示不用取模
LCD12864.rar
125.1 KB, 下載次數(shù): 31
參與人數(shù) 1黑幣 +20 收起 理由
ID:451718 發(fā)表于 2020-9-24 16:16 | 顯示全部樓層
你選的是一個(gè)不帶字庫的12864, 結(jié)果你用帶字庫的程序來驅(qū)動(dòng), 能有顯示?   選型不正確!!
ID:641629 發(fā)表于 2020-9-24 16:19 | 顯示全部樓層
網(wǎng)上找一個(gè)能亮的   我記得論壇里面有
