2020-5-12 16:25 上傳
2020-5-12 16:25 上傳
#include "reg52.h" //此文件中定義了單片機的一些特殊功能寄存器
#include<intrins.h>
typedef unsigned int u16; //對數(shù)據(jù)類型進行聲明定義
typedef unsigned char u8;
sbit s1=P1^4;
sbit s2=P1^5;
sbit s3=P1^6;
sbit s4=P1^7;
static unsigned char DisNum = 0; //顯示用指針
bit flag =0;//設(shè)定標志位,中斷溢出則標志位為1
#define LCD1602_DB P0 //data bus 數(shù)據(jù)總線
sbit LCD1602_RS = P2^6;
sbit LCD1602_RW = P2^5;
sbit LCD1602_EN = P2^7;
u8 i;
u8 printf1[]="GO_Forward";
u8 printf2[]="Back_Run";
u8 printf3[]="Now:STOP";
u8 printf4[]="Left_Run";
u8 printf5[]="Right_Run";
void delay(u8 i)
while(i--);//電機延時
void run()
s2=1;
s1=0;//右輪
delay(17);//delay越多,轉(zhuǎn)越猛
s4=0;
s3=1;//左輪
delay(130);
void back()
s2=0;
s1=1;//右輪
s4=1;
s3=0;//左輪
delay(130);
void left_run()
s2=1;
s1=0;//右輪
s3=0;//左輪
s4=1;
delay(130);
void right_run()
s2=0;
s1=1;//右輪
s3=1;//左輪
s4=0;
delay(130);
void stop()
s1=0;//右輪
s2=0;
s3=0;//左輪
s4=0;
void Read_Busy() //忙檢測函數(shù),判斷bit7是0,允許執(zhí)行;1禁止
unsigned char sta; //
LCD1602_DB = 0xff;
LCD1602_RS = 0;
LCD1602_RW = 1;
do
LCD1602_EN = 1;
sta = LCD1602_DB;
LCD1602_EN = 0; //使能,用完就拉低,釋放總線
}while(sta & 0x80);
void Lcd1602_Write_Cmd(u8 cmd) //寫命令
Read_Busy();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_EN = 1;
LCD1602_EN = 0;
void Lcd1602_Write_Data(u8 dat) //寫數(shù)據(jù)
Read_Busy();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_EN = 1;
LCD1602_EN = 0;
void LcdSetCursor(u8 x,u8 y) //坐標顯示
unsigned char addr;
if(y == 0)
addr = 0x00 + x;
addr = 0x40 + x;
Lcd1602_Write_Cmd(addr|0x80);
//按指定位置顯示一個字符
void give_where(u8 X, u8 Y,u8 DData)
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當(dāng)要顯示第二行時地址碼+0x40;
X |= 0x80; //算出指令碼
Lcd1602_Write_Cmd(X); //發(fā)命令字
Lcd1602_Write_Data(DData); //發(fā)數(shù)據(jù)
void LcdShowStr(u8 x,u8 y,u8 *str) //顯示字符串
LcdSetCursor(x,y); //當(dāng)前字符的坐標
while(*str != '\0')
Lcd1602_Write_Data(*str++);
void InitLcd1602() //1602初始化
Lcd1602_Write_Cmd(0x38); //打開,5*8,8位數(shù)據(jù)
Lcd1602_Write_Cmd(0x0c);//顯示開及光標設(shè)置
Lcd1602_Write_Cmd(0x06);//顯示光標移動位置
Lcd1602_Write_Cmd(0x01); //清屏
void UsartInit()
SCON=0X50; //設(shè)置為工作方式1
TMOD=0X20; //設(shè)置計數(shù)器工作方式2
PCON=0X80; //波特率加倍
TH1=0XF3; //計數(shù)器初始值設(shè)置,注意波特率是4800的
TL1=0XF3;
ES=1; //打開接收中斷
EA=1; //打開總中斷
TR1=1; //打開計數(shù)器
void zd0() interrupt 1 //T0中斷用來計數(shù)器溢出,超過測距范圍
flag=1; //中斷溢出標志
void Usart() interrupt 4
{ u8 receiveData;
InitLcd1602(); //1602初始化
i=SBUF;
switch(i)
case 'W':
run();
LcdShowStr(0,0,printf1);//顯示字符
break;
case 'B':
back();
LcdShowStr(0,0,printf2);//顯示字符
break;
case 'S':
stop();
LcdShowStr(0,0,printf3);//顯示字符
break;
case 'L':
left_run();
LcdShowStr(0,0,printf4);//顯示字符
break;
case 'R':
right_run();
LcdShowStr(0,0,printf5);//顯示字符
break;
receiveData=SBUF;//出去接收到的數(shù)據(jù)
RI = 0;//清除接收中斷標志位
SBUF=receiveData;//將接收到的數(shù)據(jù)放入到發(fā)送寄存器
while(!TI); //等待發(fā)送數(shù)據(jù)完成
TI=0; //清除發(fā)送完成標志位
UsartInit(); // 串口初始化
while(1);
/* 此代碼和小車是剛剛接觸硬件兩個月之后完成的,如有錯漏,請見諒,據(jù)此完成的實物小車,轉(zhuǎn)向為坦克式轉(zhuǎn)向,藍牙使用手機軟件商店自帶的藍牙串口助手,可以正常實現(xiàn),如有問題,可直接郵件聯(lián)系 */
