查看: 3107|回復(fù): 4
ADC0808芯片測量電壓值,精確度為0.02V怎么改程序,求大神解答。
回帖獎勵 10 黑幣 回復(fù)本帖可獲得 5 黑幣獎勵! 每人限 1 次(中獎概率 30%)
ID:318131 發(fā)表于 2020-5-13 08:20 | 顯示全部樓層 |閱讀模式
程序:
#include<reg52.h>
#define LCD_DB  P2
sbit LCD_RS = P1^0;
sbit LCD_RW = P1^1;
sbit LCD_EN = P1^2;
sbit AD_OE=P3^1;
sbit AD_EOC=P3^2;
sbit AD_A=P3^4;
sbit AD_B=P3^5;
sbit AD_C=P3^6;
sbit AD_START=P3^0;
unsigned char Zh1[]="    voltmeter   ";
unsigned char Zh2[]=" Voltage:       ";
unsigned char sj,ai;
int AD_sj=0,AD_ai=0;
void Busy()                 //檢忙
    unsigned char sta;
    LCD_DB = 0xff;
    LCD_RS = 0;
    LCD_RW = 1;
    do
    LCD_EN = 1;
    sta = LCD_DB;
    LCD_EN = 0;
    while(sta&0x80);
void Lcd_Write_Cmd(unsigned char cmd)      //命令
    Busy();
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_DB = cmd;
    LCD_EN = 1;
    LCD_EN = 0;
void Lcd_Write_Data(unsigned char dat)     //數(shù)據(jù)
    Busy();
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_DB = dat;
    LCD_EN = 1;
    LCD_EN = 0;
void InitLcd()                            //初始化
    Lcd_Write_Cmd(0x38);
    Lcd_Write_Cmd(0x08);
    Lcd_Write_Cmd(0x01);
    Lcd_Write_Cmd(0x06);
    Lcd_Write_Cmd(0x0c);
void LcdSetCursor(unsigned char x,unsigned char y)   //坐標
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd_Write_Cmd(addr|0X80);
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *s)  //字符串
    LcdSetCursor(x,y);
    while(*s)
        Lcd_Write_Data(*s);
        s++;
//AD轉(zhuǎn)換
void AD_xsgs()  //顯示格式
        AD_sj=5.00/255*sj*100;
    Zh2[10]=(AD_sj/100)+0x30;
    Zh2[11]='.';
    Zh2[12]=(AD_sj%100/10)+0x30;
    Zh2[13]=(AD_sj%100%10)+0x30;
    Zh2[14]='V';
void AD_csh()     //AD主程序
        AD_A=0;
        AD_B=0;
        AD_C=0;
        AD_START=1;
        AD_START=0;
        AD_OE=0;
        AD_START=1;
        AD_START=0;
        while(AD_EOC==1);
        AD_OE=1;
        sj=P0;
        AD_OE=0;
void ad ()
        AD_A=1;
        AD_B=0;
        AD_C=0;
        AD_START=1;
        AD_START=0;
        AD_OE=0;
        AD_START=1;
        AD_START=0;
        while(AD_EOC==1);
        AD_OE=1;
        ai=P0;
        AD_OE=0;
        InitLcd();
        LcdShowStr(0,0,Zh1);
    LcdShowStr(0,1,Zh2);
     AD_csh();
     AD_xsgs();
     ad ();
ID:282850 發(fā)表于 2020-5-13 11:10 | 顯示全部樓層
ADC0808對5V精度是0.0196,基本足你的要求。
改:
        AD_sj=5*100*sj/255;
試試!
或者
AD_sj=5*1000*sj/255;
后邊顯示再多一位。
ID:318131 發(fā)表于 2020-5-13 12:15 | 顯示全部樓層
f556 發(fā)表于 2020-5-13 11:10
改:
謝謝你的回答,但是改了之后,液晶上顯示的數(shù)據(jù)和電壓表測出來的數(shù)據(jù)相差很大
ID:282850 發(fā)表于 2020-5-14 09:15 | 顯示全部樓層
元亨利貞 發(fā)表于 2020-5-13 12:15
改成AD_sj定義成unsigned long
ID:921489 發(fā)表于 2021-5-31 15:44 | 顯示全部樓層
他的精度就是0.019,基本滿足要求
