查看: 4919|回復(fù): 2
ADXL345+STM32的智能運動手環(huán)程序+原理圖設(shè)計
ID:755772 發(fā)表于 2020-5-20 19:18 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
基于STM32的智能運動手環(huán)原理圖:
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "sys.h"
  4. #include "usart.h"
  5. #include <stdio.h>
  6. #include "timer.h"
  7. #include "key.h"
  8. #include "exti.h"
  9. #include "adxl345.h"
  10. #include "lcd1602.h"
  11. #include "ds18b20.h"
  12. unsigned char ReadAdxl345;           //定時讀取adxl345數(shù)據(jù)
  13. unsigned char ErrorNum=0;   //記錄錯誤次數(shù)
  14. unsigned char CheckNum=0;   //檢測次數(shù)
  15.
  16. char dis0[16];//液晶數(shù)組顯示暫存
  17. char dis1[35];
  18. unsigned int xlTab[5];//心率數(shù)組
  19. unsigned char count=0;        //心率濾波計數(shù)
  20. unsigned int xinLater=0;//        心率延時處理
  21. unsigned int xinLv =0;    //心率值
  22. unsigned int BuShu=0;//步數(shù)
  23. unsigned int Normal_num=0;                        //正常次數(shù)
  24. unsigned int Error_num=0;                        //傾斜次數(shù)
  25. unsigned int disBuShu = 0;  //顯示步數(shù)
  26. float disJuLi = 0;//顯示距離
  27. float temperature;  //溫度
  28. unsigned char readTemp = 0;        //讀取溫度標(biāo)志
  29. int main(void)
  30. {
  31.         delay_init();                     //延時函數(shù)初始化
  32.         uart_init(9600);                 //串口初始化為9600
  33.   TIM3_Int_Init(49,7199);//50ms
  34.         EXTIX_Init();                // 初始化外部中斷
  35.         LED_Init();                                  //初始化與LED連接的硬件接口
  36.         KEY_Init();                        //初始化按鍵
  37.         Lcd_GPIO_init();  //初始化lcd引腳
  38.         Lcd_Init();                  //初始化lcd屏幕
  39.         delay_ms(200);
  40.
  41.   Init_ADXL345();
  42.   if(Single_Read_ADXL345(0X00)==0xe5)
  43.   {
  44.     delay_ms(5);
  45.   }
  46.   else
  47.   {
  48.     delay_ms(3);
  49.   }
  50.
  51.         while(1)
  52.         {
  53.     if(ReadAdxl345== 1)   //定時讀取adxl345數(shù)據(jù)
  54.     {
  55.       ReadAdxl345= 0;
  56.       ReadData_x();                                                  //三軸檢測函數(shù)
  57.       CheckNum++;
  58.       if((temp_Y>450)||(temp_Y<-450)) //查看正常次數(shù)
  59.       {
  60.         Normal_num++;  //正常次數(shù)++
  61.       }
  62.       else
  63.       {
  64.         Error_num++;//傾斜次數(shù)
  65.       }
  66.       if((Error_num!=0)&&(Normal_num!=0))//檢測到步數(shù)
  67.       {
  68.                                 BuShu++;   //步數(shù)脈沖量++
  69.         Error_num=0;    //清除一個周期檢測
  70.         Normal_num=0;
  71.       }
  72.     }
  73.
  74.                 if(disFlag==1)           //顯示標(biāo)志
  75.                 {
  76.                         disFlag = 0;
  77.                         readTemp++;  //定時計數(shù)
  78.                         if(readTemp >= 8)//約800ms處理一次數(shù)據(jù) 溫度
  79.                         {
  80.                                 readTemp =0;//重新計數(shù)
  81.                                 temperature=(float)DS18B20_Get_Temp()/10;        //縮小10倍為實際值
  82.                         }
  83.
  84.                         disBuShu = BuShu/2;  //顯示步數(shù)
  85.                         disJuLi = disBuShu*0.45;//顯示距離
  86.
  87.                         sprintf(dis0,"X:%03d/min %4.1f C",xinLv,temperature);//打印
  88.                         Lcd_Puts(0,0,(unsigned char *)dis0);        //顯示
  89.                         Lcd_1Put(14,0,0xdf);//顯示符號
  90.                         sprintf(dis1,"BS:%03d JL:%4.1fm  ",disBuShu,disJuLi);//打印
  91.                         Lcd_Puts(0,1,(unsigned char *)dis1);        //顯示
  92.
  93.                 }
  94.         }
  95. }
原理圖.zip (98.08 KB, 下載次數(shù): 98)
stm32-35、程序及功能.7z (200.08 KB, 下載次數(shù): 127)
admin + 50 共享資料的黑幣獎勵!
收藏收藏4 分享淘帖 頂 踩
ID:569729 發(fā)表于 2020-5-24 14:04 | 只看該作者
你好,想問一下脈搏傳感器的輸出接LM393的反相器的負(fù)端,即2管腳可以嗎
ID:295874 發(fā)表于 2020-5-25 20:08 | 只看該作者
請問圖中的脈搏傳感器型號具體是哪一款?
