查看: 2078|回復(fù): 1
STC15f2k60S2單片機(jī)中自帶ADC用串口發(fā)送問題
ID:94642 發(fā)表于 2020-5-21 09:49 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include "stc15f2k60s2.h"
#include "delay.h"
#include "def.h"
#include "adc.h"
#include "intrins.h"
#define ADC_POWER   0x80            //ADC電源控制位
#define ADC_FLAG    0x10            //ADC完成標(biāo)志
#define ADC_START   0x08            //ADC起始控制位
#define ADC_SPEEDLL 0x00            //540個(gè)時(shí)鐘
#define ADC_SPEEDL  0x20            //360個(gè)時(shí)鐘
#define ADC_SPEEDH  0x40            //180個(gè)時(shí)鐘
#define ADC_SPEEDHH 0x60            //90個(gè)時(shí)鐘
初始化ADC
void InitADC()
    P1ASF = 0xff;                   //設(shè)置P1口為AD口
    ADC_RES = 0;                    //清除結(jié)果寄存器
                ADC_RESL=0;
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL;
    delay1ms(2);                       //ADC上電并延時(shí)
讀取ADC結(jié)果
unsigned long GetADCResult(unsigned char ch)
        unsigned long Vo,ADC;
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
    _nop_();                        //等待4個(gè)NOP
    _nop_();
    _nop_();
    _nop_();
    while (!(ADC_CONTR & ADC_FLAG));//等待ADC轉(zhuǎn)換完成
    ADC_CONTR &= ~ADC_FLAG;         //Close ADC
  //        ADC_RES=ADC_RES*4+ADC_RESL;
        ADC=(ADC_RES<<2)|ADC_RESL;
        //ADC_RES=ADC_RES*256+c;
        Vo=ADC*3.3*1000/1023;
        //Vo=ADC_RES*3.3*10/255;
  return Vo;                 //返回ADC結(jié)果
讀取ADC結(jié)果
unsigned long Get1ADCResult(void)
        unsigned long Vo,V1,V2;
    Vo= GetADCResult(0);
    _nop_();
    _nop_();
    _nop_();
         V1= GetADCResult(0);
                _nop_();
                _nop_();
    V2=(Vo+V1)/2;
  return V2;                 //返回ADC結(jié)果
#include "uart.h"
void UartInit(void)
        SCON=0x50;
        TMOD= 0x00;
        AUXR=0X40;
        TL1=(65535-(11059200/4/9600));
        TH1=(65535-(11059200/4/9600))>>8;
        TR1  = 1;
        ES   = 1;
        EA   = 1;
void UartSendByte(u8 dat)
        SBUF = dat;
        while(TI == 0);
        TI = 0;
void UartSendStr(u8 *str)
        while(*str)
                UartSendByte(*str);
                str++;
void UartSend(u8 *str ,u8 len)
        while(len--)
                UartSendByte(*str);
                str++;
void UART0_Interrupt(void) interrupt 4 using 1
        u8 SbufTemp;
        if(RI)
                RI = 0;
                SbufTemp = SBUF;
串口監(jiān)測.zip
77.33 KB, 下載次數(shù): 17
ID:94642 發(fā)表于 2020-5-21 09:54 | 只看該作者
在ADC轉(zhuǎn)換時(shí)候,ADC_RES這個(gè)是系統(tǒng)自帶的八位寄存器,直接使用是高八位的數(shù)據(jù),如果想用8位的ADC采樣,直接舍棄低2位的就可以了,直接返回這個(gè)值用char 型的就可以了,而用10位的ADC寄存器這個(gè)值就溢出范圍了需要用十位的,用int型直接返回ADC_RES*4+ADC_RESL,這樣采集的數(shù)據(jù)才是正確的,希望學(xué)習(xí)這部分的童鞋注意
