查看: 9743|回復(fù): 2
單片機煙霧傳感器proteus仿真+程序+PCB原理圖
ID:733372 發(fā)表于 2020-5-21 18:50 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
利用ADC0832對煙霧傳感器進行仿真并報警
煙霧探測元件清單
單片機源程序如下:
#include<reg52.h>       //包含單片機寄存器的頭文件
#include <intrins.h>    //包含_nop_()函數(shù)定義的頭文件
uchar a,q,t,t1;
long int s1,d0,b,c,d,s,e1,biao,biao1,biao2,a1;
uchar code qw[]={1,1,1};
uchar qs[5]={0,0,0,9,0,};
uchar key_buffer[8]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};//2013-01-03
sbit clk=P1^1;         //時鐘
sbit cs=P1^0;          //片選端
sbit d1=P1^2;          //起始信號輸入與端口選擇及數(shù)據(jù)輸出端
sbit rs=P2^5;          //將rS位定義為P2.5引腳
sbit e=P2^7;           //將e位定義為P2.7引腳
sbit rw=P2^6;          //將rw位定義為P2.6引腳
sbit k1=P1^4;
sbit k2=P1^5;
sbit k3=P1^6;
sbit k4=P1^7;
sbit D1=P2^0;          //正常指示燈(綠燈)
sbit D2=P2^1;          //警情指示燈(紅燈)
sbit beep=P2^2;//蜂鳴器
uchar code tad[]="value:00000ppm";
uchar code tad1[]="Alarm:09000ppm";
函數(shù)功能:延時若干毫秒
入口參數(shù):x
void delay(uchar x)
        uint a,b;
        for(a=x;a>0;a--)
                for(b=90;b>0;b--);
uchar du()//讀AD轉(zhuǎn)換數(shù)據(jù)
        uchar i,k,j;
        cs=0;                //片選有效
        for(j=0;j<3;j++)   //通道選擇
                clk=1;
                d1=qw[j];
                for(q=0;q<2;q++)          _nop_();
                clk=0;
        for(i=0;i<8;i++)
                clk=1;
                clk=0;
                k=(k<<1)|d1;
        cs=1;
        for(q=0;q<28;q++)        _nop_();//延時
    return k;  //返回AD0832轉(zhuǎn)換值
        液晶顯示器LED1602
void write_date(uchar date)
        rs=1;
        P0=date;
        delay(5);
        e=1;
        delay(5);
        e=0;
void write_com(uchar com)
        rs=0;
        P0=com;
        delay(5);
        e=1;
        delay(5);
        e=0;
void init()
        uchar num;
        e=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
        for(num=0;num<14;num++)
                        write_date(tad[num]);
                                delay(2);
                write_com(0x80+0x40);
                        write_date(tad1[num]);
                                delay(2);
void write_sfm(uint date)//向1602送顯示
        uint wan,pian,bai,shi,ge;
        wan=date/10000;
        pian=date%10000/1000;
        bai=date%10000%1000/100;
        shi=date%10000%1000%100/10;
        ge=date%10000%1000%100%10;
        write_com(0x80+6);
        write_date(0x30+wan);
        write_date(0x30+pian);
        write_date(0x30+bai);
        write_date(0x30+shi);
        write_date(0x30+ge);
void zh()//AD數(shù)據(jù)處理
                a=du();
                b=(a/51);//整數(shù)
                s=(a%51);
                s1=(s*10);//整形為兩個字節(jié)
                c=(s1/51);//小數(shù)1
                d=(s1%51);
                d0=(d*10);//整形
                e1=(d0/51);//小數(shù)2
                b=b*100;
                c=c*10;
                a1=(b+c+e1);//a1必須定義為長整型
                delay(10);
                if(a1>140)
                        a1=a1-140;
                        if(a1>=0)
                        a1=(a1*1000)/36;
                        write_sfm(a1);
                        write_sfm(0);
函數(shù)功能:報警子程序
void zx()//控制
        long int sa;
        sa=((qs[3]*1000)+(qs[2]*100)+(qs[1]*10)+qs[0]);        //報警設(shè)定值
        if(a1>sa) //煙霧檢測值大于設(shè)定值
                D2=0;        //報警紅燈亮
                D1=1;         //正常指示綠燈滅
                biao2=1; //蜂鳴器報警標志置1
                D1=0;        //正常指示綠燈亮
                D2=1;         //報警紅燈滅
                biao2=0; //蜂鳴器報警標志清0
                beep=1;         //蜂鳴器不響
函數(shù)功能:按鍵識別
void key_scan()//按鍵識別
        uchar i;
        static uchar key_value,key_state=0;
        P1=0xf0;//設(shè)置P1口高4位為輸入口
        if((P1&0xf0)!=0xf0)//有鍵按下
                delay(2);        //延時消抖
                key_state =P1&0xf0;
                if(key_state!=0xf0)        //再判有鍵按下
                        switch(key_state)
                                case 0xe0:                //S1按下
                                         key_value=1;
                                         break;
                                case 0xd0://S2按下
                                        key_value=2;
                                         break;
                                case 0xb0: //S3按下
                                        key_value=3;
                                         break;
                                case 0x70: //S4按下
                                        key_value=4;
                                         break;
                        for(i=0;i<7;i++) //按鍵隊列FIFO處理
                                        key_buffer[ i]=key_buffer[i+1];
                                key_buffer[7]=key_value; //最新按鍵值存入緩沖隊列
                while((P1&0xf0)!=0xf0);         //等待按鍵釋放
函數(shù)功能:按鍵處理
void key_do()  // 按鍵處理
        uchar d,i;
        while((key_buffer[0]!=0xff)||(key_buffer[1]!=0xff)||(key_buffer[2]!=0xff)||(key_buffer[3]!=0xff)||(key_buffer[4]!=0xff)||
              (key_buffer[5]!=0xff)||(key_buffer[6]!=0xff)||(key_buffer[7]!=0xff))//有鍵按下
                        switch(key_buffer[0])
                                case 1:                //S1按下
                                         biao++;
                                         t1=1;
                                         TR1=0;
                                         if(biao==5)
                                                TR1=1;
                                                biao=0;
                                                write_com(0x0c);//關(guān)閉光標閃爍
                                         biao1=0;
                                         break;
                                case 2://S2按下
                                                 if(biao==1)
                                                        if(biao1==0)
        write_com(0x80+0x40+10);//定位光標閃爍的位置
        write_com(0x0f); //打開光標閃爍
                                                        d=qs[0];
                                                        d++;
                                                        if(d==10)        d=0;
                                                        write_date(0x30+d);//送顯示
                                                        write_com(0x80+0x40+10);//重新定位光標閃爍的位置
                                                        qs[0]=d;
                                                        //biao1=1;
                                                if(biao==2)
                                                        if(biao1==0)
        write_com(0x80+0x40+9);//定位光標閃爍的位置
                                                        d=qs[1];
                                                        d++;
                                                        if(d==10)        d=0;
                                                        write_com(0x80+0x40+9);//重新定位光標閃爍的位置
                                                        qs[1]=d;
                                                        //biao1=1;
                                                if(biao==3)
                                                        if(biao1==0)
        write_com(0x80+0x40+8);//定位光標閃爍的位置
                                                        d=qs[2];
                                                        d++;
                                                        if(d==10)        d=0;
                                                        write_com(0x80+0x40+8);//重新定位光標閃爍的位置
                                                        qs[2]=d;
                                                if(biao==4)
                                                        if(biao1==0)
        write_com(0x80+0x40+7);//定位光標閃爍的位置
                                                        d=qs[3];
                                                        d++;
                                                        if(d==10)        d=0;
                                                        write_com(0x80+0x40+7);//重新定位光標閃爍的位置
                                                        qs[3]=d;
                                         biao1=1;
                                         break;
                                case 3: //S3按下
                                                if(biao==1)
                                                        if(biao1==0)
                                                        d=qs[0];
                                                        d--;
                                                        if(d==-1)        d=9;
                                                        qs[0]=d;
                                                //        biao1=1;
                                           if(biao==2)
                                                        if(biao1==0)
                                                        d=qs[1];
                                                        d--;
                                                        if(d==-1)        d=9;
                                                        qs[1]=d;
                                                if(biao==3)
                                                        if(biao1==0)
                                                        d=qs[2];
                                                        d--;
                                                        if(d==-1)        d=9;
                                                        qs[2]=d;
                                                if(biao==4)
                                                        if(biao1==0)
                                                        d=qs[3];
                                                        d--;
                                                        if(d==-1)        d=9;
                                                        qs[3]=d;
                                                biao1=1;
                                                 break;
                                case 4: //S4按下
                                                TR1=1;
                                                biao=0;
                                                 break;
                                default: break;
                                key_buffer[7]=0xff; //緩沖隊列單元恢復(fù)無鍵按下標志
void init1()
        biao=0;
        biao1=0;biao2=0;beep=1;
        cs=1;
        clk=0;
        d1=0;
        rw=0;
        EA=1;
        ET1=1;
        TMOD=0x10;
        TH1=(65536-50000)/256;
        TL1=(65535-50000)%256;
        TR1=1;
        t1=0;
        D1=0;
        init();
函數(shù)功能:主函數(shù)
main()
        init1();
                if(biao==0)         //若打開報警功能
                        zx();        //調(diào)報警函數(shù)
                key_scan();
                key_do();//調(diào)按鍵處理函數(shù),進行報警值設(shè)定
                if(t1==0) //定時時間到0.2s
                        zh();  //調(diào)數(shù)據(jù)轉(zhuǎn)換, 啟動AD轉(zhuǎn)換
                        t1=1;  //關(guān)閉數(shù)據(jù)轉(zhuǎn)換和AD轉(zhuǎn)換
void as() interrupt 3          //定時器T1中斷函數(shù) ,定時啟動數(shù)據(jù)轉(zhuǎn)換和AD轉(zhuǎn)換,并根據(jù)情況進行蜂鳴器報警
        TH1=(65536-50000)/256;//重賦初值
        t++;  //時間計數(shù)加1
        if(t==4) //50ms*4=0.2s,0.2s時間到
                t=0;   //時間計數(shù)清0
                t1=!t1;         //啟動數(shù)據(jù)轉(zhuǎn)換和AD轉(zhuǎn)換
                if(biao2==1)
                        beep=!beep;         //蜂鳴器報警
程序問題還很多,大家能幫我修改一下嗎?仿真圖屏幕沒有反應(yīng): 煙霧探測報警器.7z (269.35 KB, 下載次數(shù): 164)
可以參考這個可用:http://www.torrancerestoration.com/bbs/dpj-80294-1.html
admin + 50 共享資料的黑幣獎勵!
收藏收藏4 分享淘帖 頂 踩
ID:862725 發(fā)表于 2020-12-18 12:57 | 只看該作者
仿真之后沒有反應(yīng)是怎么回事?同求大家指導(dǎo)
ID:440028 發(fā)表于 2022-1-5 14:37 | 只看該作者
好多都是沒反應(yīng)的,同求
