查看: 1280|回復(fù): 1
求大家?guī)臀铱纯闯绦,測(cè)量溫度大于設(shè)置溫度LED1燈亮,測(cè)量溫度小于設(shè)置溫度LEd2燈亮。
ID:707421 發(fā)表于 2020-5-22 21:02 | 顯示全部樓層 |閱讀模式
#include < reg52.h >
#include < character.h >
#include < lcd.h >
#include < clock.h >
#include < sensor.h>
#include < calendar.h >
#include < key.h >
sbit bell = P2 ^ 0;
sbit LED1 = P2 ^ 6;
sbit LED2 = P2 ^7;
void Delay_ms(unsigned int t)
        unsigned int i,j;
        for(i=0;i<t;i++)
        for(j=0;j<120;j++)
void Timer0_Service() interrupt 1
   static uchar count = 0;
   static uchar flag = 0;
   count = 0;
   TR0 = 0;
   TH0 = 0x3c;
   TL0 = 0XB0;
   TR0 = 1 ;
   count ++;
   if( count == 20 )
      bell = ~ bell;
      count = 0;
      flag ++;
   if( flag == 6 )
      flag = 0;
      TR0 = 0;
uchar HexNum_Convert(uchar HexNum)
uchar Numtemp;
Numtemp=(HexNum>>4)*10+(HexNum&0X0F);
return Numtemp;
void main( void )
     unsigned char wendu[2]={30,20};
unsigned char clock_time[6] = {0X00,0X59,0X23,0X09,0X04,0X11};
         unsigned char alarm_time[12]={20,8,12,10,11,10,10,13,11,14,10,16};
         unsigned char temperature[2] ,temperature1[2] ;
   unsigned int  zhengshuA,zhengshuB,zhengshu=0;
  unsigned int  xiaoshu_aA,xiaoshu_aB,xiaoshu_a;
  unsigned int  all;
    zhengshuA=temperature[0]/16+temperature[1]*16;
     xiaoshu_aA=(temperature[0]&0x0f)*10/16
    zhengshuB=temperature1[0]/16+temperature1[1]*16
    xiaoshu_aB=(temperature1[0]&0x0f)*10/16;
    zhengshu=zhengshuA+zhengshuB;
    xiaoshu_a=xiaoshu_aA+xiaoshu_aB;
    all=(zhengshu*10+xiaoshu_a)/2;
    Lcd_Initial();
        Clock_Fresh( clock_time );
        Clock_Initial( clock_time )
  LED1=0;
  LED2=0;
    EA = 1
    ET0 = 1;
          ET2 = 1
    TMOD = 0x01
          RCAP2H = 0x3c
    RCAP2L = 0xb0
    while( 1
           switch( Key_Scan()
          case up_array:
                       Key_Idle()
                               break;
          case down_array
                                                    Key_Idle()
                                 break;
                  case clear_array:
                                                     Key_Idle()
                                                  break;
                  case function_array:
                             Key_Function( clock_time, alarm_time,wendu)
                  case null:
                            Lcd_Clock( clock_time )
                Sensor_Fresh( temperature )
        Sensor1_Fresh( temperature1 );
        Delay_ms(1000);
        Delay_ms(1000);
        Lcd_Temperture( temperature )
                                              Lcd_Temperture1( temperature1 )
        Lcd_pingjun(temperature, temperature1);
        Delay_ms(1000);
                                                        if((all)<(wendu[1]*10))
                                                        LED1=1;
                                                        LED2=0;
        break;}
                                        {if((all)>(wendu[0]*10))
                                               LED2=1;
                                                LED1=0;
                                                 break;}
                                                 else{LED2=0;
                                                LED1=0;break;}}
            break;}
ID:707421 發(fā)表于 2020-5-22 22:31 | 顯示全部樓層
已經(jīng)弄好了
