Proteus的原理電路見圖1。單片機P1.0~ P1.4接有5個按鍵,當按鍵按下時,分別對應(yīng)產(chǎn)生正弦波、方波、三角波、梯形波和鋸齒波。
2020-5-27 10:50 上傳
單片機源程序如下:
- #include<reg51.h>
- sbit wr=P3^6;
- sbit rd=P3^2;
- sbit key0=P1^0; //定義P1.0腳的按鍵為正弦波鍵key0
- sbit key1=P1^1; //定義P1.1腳的按鍵為方波鍵key1
- sbit key2=P1^2; //定義P1.2腳的按鍵為三角波鍵key2
- sbit key3=P1^3; //定義P1.3腳的按鍵為梯形波鍵key3
- sbit key4=P1^4; //定義P1.3腳的按鍵為鋸齒波鍵key4
- unsigned char flag; //flag為1、2、3、4、5時對應(yīng)正弦波、方波、
- //三角波、梯形波、鋸齒波
- unsigned char const code //以下為正弦波采樣點數(shù)組256個數(shù)據(jù)
- SIN_code[256]={0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,
- 0xab,0xae,0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,
- 0xd8,0xda,0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf4,
- 0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
- 0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,
- 0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe3,0xe1,0xde,0xdc,0xda,0xd8,0xd6,
- 0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,0xbc,0xb9,0xb6,0xb4,0xb1,0xae,0xab,0xa8,
- 0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x92,0x8f,0x8c,0x89,0x86,0x83,0x80,0x7d,0x79,0x76,0x73,
- 0x70,0x6d,0x6a,0x67,0x64,0x61,0x5e,0x5b,0x58,0x55,0x52,0x4f,0x4c,0x49,0x46,0x43,0x41,
- 0x3e,0x3b,0x39,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27,0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,
- 0x17,0x15,0x14,0x12,0x10,0xf,0xd,0xc,0xb,0x9,0x8,0x7,0x6,0x5,0x4,0x3,0x3,0x2,0x1,0x1,
- 0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0x1,0x2,0x3,0x3,0x4,0x5,0x6,0x7,0x8,
- 0x9,0xa,0xc,0xd,0xe,0x10,0x12,0x13,0x15,0x17,0x18,0x1a,0x1c,0x1e,0x20,0x23,0x25,0x27,
- 0x29,0x2c,0x2e,0x30,0x33,0x35,0x38,0x3b,0x3d,0x40,0x43,0x46,0x48,0x4b,0x4e,0x51,0x54,
- 0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x73,0x76,0x79,0x7c};
- unsigned char keyscan() //鍵盤掃描函數(shù)
- unsigned charkeyscan_num,temp;
- P1=0xff; // P1口輸入
- temp=P1; //從P1口讀入鍵值,存入temp中
- if(~(temp&0xff)) //判是否有鍵按下,即鍵值不為0xff,則有鍵按下
- { //~按位取反
- if(key0==0) //產(chǎn)生正弦波的按鍵按下,P1.0=0
- keyscan_num=1; //得到的鍵值為1,表示產(chǎn)生正弦波
- else if(key1==0) //產(chǎn)生方波的按鍵按下,P1.1=0
- keyscan_num=2; //得到鍵值為2,表示產(chǎn)生方波
- elseif(key2==0) //產(chǎn)生三角波的按鍵按下, P1.2=0
- keyscan_num=3; //得到的鍵值為3,表示產(chǎn)生三角波
- elseif(key3==0) //產(chǎn)生梯形波的按鍵按下,P1.3=0
- keyscan_num=4; //得到的鍵值為4,表示產(chǎn)生梯形波
- elseif(key4==0) //產(chǎn)生鋸齒波的按鍵按下, P1.3=0
- keyscan_num=5; //得到的鍵值為5,表示產(chǎn)生鋸齒波
- else
- { keyscan_num=0; //沒有按鍵按下,鍵值為0
- returnkeyscan_num; //得到的鍵值返回
- void init_DA0832()
- rd=0;
- wr=0;
- void SIN()
- unsignedint i;
- i=0;
- do{
- P2=SIN_code[ i];
- i=i+1;
- }while(i<256);
- void Square()
- EA=1;
- ET0=1;
- TMOD=1;
- TH0=0xff;
- TL0=0x83;
- TR0=1;
- void Triangle()
- P2=0x00;
- do{
- P2=P2+1;
- }while(P2<0xff);
- P2=0xff;
- do{
- P2=P2-1;
- }while(P2>0x00);
- P2=0x00;
- void Sawtooth()
- P2=0x00;
- do{
- P2=P2+1;
- }while(P2<0xff);
- void Trapezoidal()
- unsignedchar i;
- P2=0x00;
- do{
- P2=P2+1;
- }while(P2<0xff);
- P2=0xff;
- for(i=255;i>0;i--)
- P2=0xff;
- do{
- P2=P2-1;
- }while(P2>0x00);
- P2=0x00;
- void main()
- init_DA0832();
- do
- flag=keyscan();
- }while(!flag);
- while(1)
- switch(flag)
- case 1:
- do{
- flag=keyscan();
- SIN();
- }while(flag==1);
- break;
- case 2:
- Square();
- do{
- flag=keyscan();
- }while(flag==2);
- TR0=0;
- break;
- case 3:
- do{
- flag=keyscan();
- Triangle();
- }while(flag==3);
- break;
- case 4:
- do{
- flag=keyscan();
- Trapezoidal();
- }while(flag==4);
- break;
- case 5:
- do{
- flag=keyscan();
- Sawtooth();
- }while(flag==5);
- break;
- default:
- flag=keyscan();
- break;
- void timer0(void) interrupt 1
- P2=~P2;
- TH0=0xff;
- TL0=0x83;
- TR0=1;
復制代碼
正弦波
2020-5-27 11:10 上傳
方波
2020-5-27 11:10 上傳
三角波
2020-5-27 11:10 上傳
梯形波
2020-5-27 11:10 上傳
鋸齒波
2020-5-27 11:10 上傳
