點(diǎn)陣控制,因無(wú)法發(fā)圖片
- #include<reg51.h>//頭文件
- sbit shcp=P1^2;//數(shù)據(jù)輸入時(shí)鐘線 595的11腳
- sbit stcp=P1^1;//輸出存儲(chǔ)器鎖存時(shí)鐘線 595的12腳
- sbit ds=P1^0;//數(shù)據(jù)線 595的14腳
- sbit s1=P3^1;//按下暫停再暫按繼續(xù)
- sbit s2=P3^2;//按下方向取反
- sbit s3=P3^3;//閃爍
- sbit s4=P3^4; //切換內(nèi)容
- sbit s5=P3^5; //加速
- sbit s6=P3^6; //減速
- bit fx;//方向切換
- bit ss ;//閃爍切換
- int xsflag=0;
- int sd=10;
- int count;
- unsigned char alt;//數(shù)據(jù)移動(dòng)定時(shí)時(shí)間
- unsigned int net;//控制顯示的字符
- unsigned char zi1=7,zi2=3,zi3=3;
- unsigned int zong;//總字符 (所有的字?jǐn)?shù)+1)*32 字?jǐn)?shù)指的是漢字,字母、數(shù)字兩個(gè)算一個(gè)數(shù)字
- unsigned char code tab1[]={
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
- 0x08,0x20,0x06,0x20,0x40,0x7E,0x31,0x80,0x00,0x01,0x7F,0xE2,0x40,0x0C,0x4F,0xF0,
- 0x40,0x08,0x7F,0xE4,0x00,0x00,0x1F,0xE2,0x00,0x01,0xFF,0xFE,0x00,0x00,0x00,0x00,/*"測(cè)",2*/
- 0x08,0x40,0x08,0x42,0x08,0x81,0xFF,0xFE,0x09,0x00,0x04,0x02,0x19,0x02,0x12,0x42,
- 0x14,0x42,0x90,0x42,0x70,0x7E,0x14,0x42,0x12,0x42,0x15,0x42,0x18,0x02,0x00,0x00,/*"控",3*/
- 0x08,0x20,0x08,0x22,0x08,0x41,0xFF,0xFE,0x08,0x80,0x09,0x01,0x10,0x01,0x11,0x02,
- 0x11,0xC2,0x11,0x34,0xFF,0x08,0x11,0x14,0x11,0x62,0x11,0x81,0x10,0x01,0x00,0x00,/*"技",4*/
- 0x00,0x08,0x08,0x10,0x08,0x20,0x08,0x40,0x08,0x80,0x0B,0x00,0x0C,0x00,0xFF,0xFF,
- 0x0C,0x00,0x0B,0x00,0x48,0x80,0x38,0x40,0x08,0x20,0x08,0x10,0x00,0x08,0x00,0x00,/*"術(shù)",5*/
- 0x00,0x10,0x00,0x10,0x07,0x10,0xF9,0x10,0x11,0x10,0x11,0x10,0x11,0x10,0x11,0x10,
- 0x11,0x10,0x11,0x12,0x11,0x01,0x11,0x02,0x11,0xFC,0x10,0x00,0x00,0x00,0x00,0x00,/*"與",6*/
- 0x00,0x80,0x01,0x00,0x06,0x00,0x1F,0xFF,0xE0,0x00,0x00,0x01,0x38,0x02,0x07,0x04,
- 0x80,0xC8,0x60,0x30,0x00,0xC8,0x07,0x04,0x78,0x02,0x00,0x01,0x00,0x01,0x00,0x00,/*"儀",7*/
- 0x01,0x10,0x01,0x10,0x79,0x2F,0x49,0x29,0x49,0x49,0x49,0x49,0x79,0x8F,0x07,0x00,
- 0x01,0x80,0x79,0x4F,0x4D,0x49,0x4B,0x29,0x49,0x29,0x79,0x1F,0x01,0x10,0x00,0x00,/*"器",8*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",9*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/
- unsigned char code tab2[]={
- 0x10,0x04,0x1F,0xFC,0x10,0x84,0x00,0x80,0x00,0x80,0x10,0x84,0x1F,0xFC,0x10,0x04,/*"H",2*/
- 0x00,0x00,0x00,0xF8,0x01,0x24,0x01,0x24,0x01,0x24,0x01,0x24,0x00,0xE8,0x00,0x00,/*"e",3*/
- 0x00,0x00,0x08,0x04,0x08,0x04,0x1F,0xFC,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00,/*"l",4*/
- 0x00,0x00,0x08,0x04,0x08,0x04,0x1F,0xFC,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00,/*"l",5*/
- 0x00,0x00,0x00,0xF8,0x01,0x04,0x01,0x04,0x01,0x04,0x01,0x04,0x00,0xF8,0x00,0x00,/*"o",6*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xCC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",7*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",8*/
- unsigned char code tab3[]={
- 0x00,0x00,0x08,0x04,0x08,0x04,0x1F,0xFC,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00,/*"1",2*/
- 0x00,0x00,0x0E,0x0C,0x10,0x14,0x10,0x24,0x10,0x44,0x11,0x84,0x0E,0x0C,0x00,0x00,/*"2",3*/
- 0x00,0x00,0x0C,0x18,0x10,0x04,0x11,0x04,0x11,0x04,0x12,0x88,0x0C,0x70,0x00,0x00,/*"3",4*/
- 0x00,0x00,0x00,0xE0,0x03,0x20,0x04,0x24,0x08,0x24,0x1F,0xFC,0x00,0x24,0x00,0x00,/*"4",5*/
- 0x00,0x00,0x1F,0x98,0x10,0x84,0x11,0x04,0x11,0x04,0x10,0x88,0x10,0x70,0x00,0x00,/*"5",6*/
- 0x00,0x00,0x07,0xF0,0x08,0x88,0x11,0x04,0x11,0x04,0x18,0x88,0x00,0x70,0x00,0x00,/*"6",7*/
- void delay(unsigned int z)//延時(shí)子函數(shù)
- unsigned char x;
- for(;z>0;z--)
- for(x=110;x>0;x--);
- void writedata(unsigned char dat1,unsigned char dat2) //595顯示子函數(shù)
- unsigned char i;
- //CY存儲(chǔ)移位之后的數(shù)據(jù) CY進(jìn)位標(biāo)志位,單片機(jī)內(nèi)部的寄存器 移位之后的數(shù)據(jù)就存在CY里面
- for(i=0;i<8;i++)//循環(huán)八次
- dat1=dat1<<1;//數(shù)據(jù)左移11110001
- ds=CY;//數(shù)據(jù)發(fā)送
- shcp=1;//上升沿發(fā)生移位 上升沿時(shí)數(shù)據(jù)寄存器的數(shù)據(jù)鎖存。
- shcp=0;
- dat2=dat2<<1;//數(shù)據(jù)左移
- shcp=1;//上升沿發(fā)生移位 上升沿時(shí)數(shù)據(jù)寄存器的數(shù)據(jù)鎖存 。
- shcp=0;
- stcp=0;
- stcp=1;//上升沿將數(shù)據(jù)送到輸出鎖存器
- stcp=0;
- void main() //主函數(shù)
- char i,aa;
- TMOD=0x01;//定時(shí)器0 模式1 16位定時(shí)模式
- TH0=(65536-10000)/256;//定時(shí)10.000ms
- TL0=(65536-10000)%256;
- ET0=1;//使能定時(shí)器0
- EA=1;//開(kāi)啟總中斷
- TR0=1;//開(kāi)始計(jì)數(shù)
- zong=(zi1+1)*32;
- while(1) //無(wú)限循環(huán)
- if(s1==0)//檢測(cè)按鍵
- delay(30);//延時(shí)消除按鍵抖動(dòng)
- if(s1==0)
- ss=0;
- TR0=~TR0;//按下暫停 暫按繼續(xù)
- while(s1==0);//等待按鍵松手
- if(s2==0)//檢測(cè)按鍵
- if(s2==0)
- fx=~fx;//方向取反
- TR0=1;
- ss=0;
- aa=0;
- if(fx==0)net=0;//正向移動(dòng)
- if(fx==1)net=zong;//反向移動(dòng)
- while(s2==0);//等待按鍵松手
- if(s3==0){
- delay(30);
- TR0=0;
- net=32;
- ss=1;
- while(!s3);
- if(s4==0){
- xsflag++;
- if(xsflag>=3)
- xsflag=0;
- net=32;
- while(!s4);
- if(xsflag==0)
- zong=(zi1+1)*32;
- if(xsflag==1)
- zong=(zi2+1)*32;
- if(xsflag==2)
- zong=(zi3+1)*32;
- if(s5==0){
- ss=0;
- sd=sd-2;
- if(sd<=4)
- sd=4;
- while(!s5);
- if(s6==0){
- ss=0;
- sd=sd+2;
- if(sd>=20)
- sd=20;
- while(!s6);
- if(ss==0){
- for(i=0;i<16;i++)//循環(huán)移位
- //兩片138組成的4-16線譯碼器
- P2=i;//列數(shù)據(jù)驅(qū)動(dòng),138的驅(qū)動(dòng)端口
- if(xsflag==0){
- writedata(tab1[net+aa],tab1[net+aa+1]);//寫(xiě)入需要顯示的數(shù)據(jù)
- if(xsflag==1){
- writedata(tab2[net+aa],tab2[net+aa+1]);//
- if(xsflag==2){
- writedata(tab3[net+aa],tab3[net+aa+1]);//
- delay(3);//延時(shí)
- writedata(0,0);//清屏
- aa+=2;//數(shù)據(jù)加 實(shí)現(xiàn)掃描
- if(aa>30)aa=0;//循環(huán)16次 清零
- }else{
- count++;
- if(count >=50){
- count=0;
- net=net+32;
- if(net>zong){
- net=32;
- if(count>25){
- if(xsflag==0){
- if(xsflag==1){
- if(xsflag==2){
- }else{
- delay(50);
- void timer0() interrupt 1
- TH0=(65536-10000)/256;//10.000ms 進(jìn)入一次中斷
- alt++;
- if(alt>=sd)//到100.000ms時(shí)間加以實(shí)現(xiàn)移動(dòng) 用于控制移動(dòng)速度
- alt=0;
- if(fx==0)//正向移動(dòng)
- net=net+2; //每次送兩個(gè)編碼數(shù)據(jù)
- if(net>zong)//達(dá)到總字符
- net=0;//數(shù)據(jù)清零
- else//否則反向移動(dòng)
- net=net-2;//每次送兩個(gè)編碼數(shù)據(jù)
- if(net<2)//數(shù)據(jù)完畢
- net=zong;//回到總字符
16X16點(diǎn)陣.zip
(29.75 KB, 下載次數(shù): 140)
2020-5-27 19:26 上傳
點(diǎn)擊文件名下載附件
