查看: 4053|回復(fù): 7
請(qǐng)教STC12C5608單片機(jī)EEPROM如何斷電保存多個(gè)數(shù)據(jù)
ID:136485 發(fā)表于 2020-5-28 09:29 | 顯示全部樓層 |閱讀模式
   mode();
   if(d==1)
         CR=1;
         if((key1==1)&&(key3==0)&&(key4==0))
         count1++;
         if(count1>8000)
           count1=0;
           if(num>0)
                 num=num-17;
                 if((key3==1)&&(key1==0))break;
                 CCAP3H=num;
                 delay(10);
   if((key1==1)&&(key3==1))
         count2++;
         if(count2>8000)
            count2=0;
            if(num<0xFF)
                  num=num+17;
                  CCAP3H=num;
                  delay(10);
  if((key4==1)&&(key1==1)&&(key3==0))
   count3++;
   if(count3>20000)
     count3=0;
         sum++;
         if(sum==0x11)
           sum=0x10;
if(key2==1)
   count4++;
   if(count4>20000)
         count4=0;
         sum--;
         if(sum==0x00)
           sum=0x01;
  switch(sum)
  //case 0x00:CCAP0H=0xFF;CCAP1H=0xFF;CCAP2H=0xFF;break;
  case 0x01:PWM1();break;
  case 0x02:PWM2();break;
  case 0x03:PWM3();break;
  case 0x04:PWM4();break;
  case 0x05:PWM5();break;
  case 0x06:PWM6();break;
  case 0x07:PWM7();break;
  case 0x08:PWM8();break;
  case 0x09:PWM9();break;
  case 0x0A:PWM10();break;
  case 0x0B:PWM11();break;
  case 0x0C:PWM12();break;
  case 0x0D:PWM13();break;
  case 0x0E:PWM14();break;
  case 0x0F:PWM15();break;
  case 0x10:PWM16();break;
  default:break;
   if(d==0)
         temp=0xFF;
     CCAP0H=temp;
     CCAP1H=temp;
     CCAP2H=temp;
     CCAP3H=temp;
         CR=0;
         delay(100);
關(guān)閉IAP
void IapIdle()
  ISP_CONTR = 0;                  //關(guān)閉IAP功能
  ISP_CMD = 0;                    //清除命令寄存器
  ISP_TRIG = 0;                   //清除觸發(fā)寄存器
  ISP_ADDRH = 0x80;               //將地址設(shè)置到非IAP區(qū)域
  ISP_ADDRL = 0x00;
從ISP/IAP/EEPROM區(qū)域讀取一字節(jié)
uchar IapReadByte(uint addr)
  uchar dat;                       //數(shù)據(jù)緩沖區(qū)
  ISP_CONTR = ENABLE_ISP;         //使能IAP
  ISP_CMD = CMD_READ;             //設(shè)置IAP命令
  ISP_ADDRL = addr;               //設(shè)置IAP低地址
  ISP_ADDRH = addr  >> 8;          //設(shè)置IAP高地址
  ISP_TRIG = 0x46;                //寫觸發(fā)命令(0x5a)
  ISP_TRIG = 0xB9;                //寫觸發(fā)命令(0xa5)
  _nop_();                        //等待ISP/IAP/EEPROM操作完成
  dat = ISP_DATA;                 //讀ISP/IAP/EEPROM數(shù)據(jù)
  IapIdle();                      //關(guān)閉IAP功能
  return dat;                     //返回
寫一字節(jié)數(shù)據(jù)到ISP/IAP/EEPROM區(qū)域
void IapProgramByte(uint addr, uchar dat)
  ISP_CMD = CMD_PROGRAM;          //設(shè)置IAP命令
  ISP_DATA = dat;                 //寫ISP/IAP/EEPROM數(shù)據(jù)
  IapIdle();
扇區(qū)擦除
void IapEraseSector(uint addr)
  ISP_CMD = CMD_ERASE;            //設(shè)置IAP命令
  IapIdle();
要求同時(shí)保存參數(shù)d,num,sum三個(gè)參數(shù),我現(xiàn)在只能按照例子保存一個(gè)參數(shù),在上電讀出,請(qǐng)教各位高手
ID:136485 發(fā)表于 2020-5-28 09:44 | 顯示全部樓層
void mode()
   delay(80);
   if((key3==0)&&(key1==0))
     d++;
         IapEraseSector(ISP_ADDRESS);
         IapProgramByte(ISP_ADDRESS, d);
     if(d==2)
       d=0;
ID:228467 發(fā)表于 2020-5-28 10:15 | 顯示全部樓層
可以加個(gè)大電容,在斷電后短暫時(shí)間給單片機(jī)供電,完成保存數(shù)據(jù)
ID:744327 發(fā)表于 2020-5-28 10:16 | 顯示全部樓層
void Uart_Send_Str(unsigned char str[],unsigned char len,bit mode)
        unsigned char k;
        if(mode == 1)
                for(k = 0;k < len; k++)
                        UartSend(48 + str[k]);
        }else
                        str[k] = 0;
ID:213173 發(fā)表于 2020-5-28 10:52 | 顯示全部樓層
kxcuser 發(fā)表于 2020-5-28 09:44
void mode()
        unsigned char Temp[x]={......};//需要保存的數(shù)據(jù)
        IapEraseSector(ISP_ADDRESS);//擦除指定扇區(qū)
        for(i=0;i<x;i++}//x不大于512
                IapProgramByte(ISP_ADDRESS+i, Temp);//從指定扇區(qū)首地址連續(xù)寫入
ID:136485 發(fā)表于 2020-5-28 11:34 | 顯示全部樓層
麻煩管理員把這個(gè)帖子關(guān)了,我自己解決了
ID:723402 發(fā)表于 2020-5-28 11:35 | 顯示全部樓層
想掉電保存多個(gè)數(shù)據(jù),用stc15系列或者STC8系列,有帶比較器功能的,檢測(cè)到掉電就觸發(fā)中斷才有足夠的數(shù)據(jù)保存數(shù)據(jù)。
ID:136485 發(fā)表于 2020-5-28 12:01 | 顯示全部樓層
wulin 發(fā)表于 2020-5-28 10:52
謝謝,現(xiàn)在是按指定的地址
