查看: 20316|回復: 2
Proteus8.9 VSM Studio Keil編譯器仿真AT89C51RD2系列020_lcdPG128x2
ID:371233 發(fā)表于 2020-5-28 22:57 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 kaillen 于 2020-5-29 03:30 編輯
一,打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示)
圖1
二,調整原理圖大小,適合可視,另存工程文件。(如下圖2,3,4所示)
圖2
圖3
圖4
三,點擊Source Code標簽。(如下圖5所示)
圖5
四,編輯main.c 代碼如Proteus8.9 VSM Studio Keil編譯器仿真AT89C51RD2系列020_lcdPG128x2 (如下圖6所示)
圖6
五,Main.c 代碼:
#include "PG128x2.h"
int main(void)
        u16 i, j=0, m=4;
        while(1) {
                init_128x2();
                if(0==m) m=4;
                else m=0;
                cls_img (128,128, 0xff);
                for(i=0;i<4;i++) for(j=0;j<2;j++) delayus(100);
                cls_img (128,128, 0x00);
                for(i=0;i<4;i++) display_HZ(0+m,i,HZ0[ i]);
                        for(i=0;i<4;i++) for(j=0;j<400;j++) delayus(100);
                init_128x2();
                        for(i=0;i<4;i++) for(j=0;j<40;j++) delayus(100);
                 for(i=0;i<4;i++) display_HZ(4-m,i,HZ1[ i]);
                for(i=0;i<4;i++) display_HZ(8+m,i,HZ0[ i]);
                init_128x2();
                 for(i=0;i<4;i++) display_HZ(12-m,i,HZ1[ i]);
LcdPG128x2.h:
/* Main.c file generated by New Project wizard
*Coder:       Ziegler Yin
* Created:   周日 5月 3 2020
* Processor: AT89C51RD2
* Compiler:  Keil for 8051
#ifndef __PG128X2_H_
#define __PG128X2_H_
#include "89c51rd2.h"
#include <INTRINS.H>
#define u8 unsigned char
#define u16 unsigned int
sbit wr=P2^0;
sbit rd=P2^1;
sbit ce=P2^2;
sbit cd=P2^3;
sbit rst=P2^4;
static u8 code HZ0[4][128]={{
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x00,
0x00,0x07,0x80,0x00,0x00,0x07,0x80,0x00,0x00,0x07,0x80,0x00,0x00,0x07,0x80,0x00,
0x00,0x07,0x8F,0xC0,0x00,0x07,0xFF,0xE0,0x07,0xFF,0x80,0x00,0x03,0xE7,0x00,0x00,
0x00,0x07,0x00,0x00,0x00,0x07,0x80,0x00,0x00,0x07,0x80,0x00,0x00,0x0F,0xC0,0x00,
0x00,0x0E,0xE0,0x00,0x00,0x0E,0xF0,0x00,0x00,0x1E,0x78,0x00,0x00,0x1C,0x3C,0x00,
0x00,0x3C,0x3E,0x00,0x00,0x78,0x1F,0x00,0x00,0xF0,0x1F,0xC0,0x01,0xC0,0x0F,0xF0,
0x07,0x00,0x07,0xFE,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x80,0x00,
0x00,0x03,0xC0,0x00,0x01,0x81,0xC7,0xE0,0x03,0x83,0xFD,0xF0,0x03,0xFE,0x01,0xF8,
0x07,0x80,0x03,0xC0,0x07,0x00,0x03,0x00,0x0F,0x03,0xF8,0x00,0x0E,0x7F,0xF0,0x00,
0x00,0x0F,0x1C,0x00,0x00,0x0F,0x1E,0x00,0x00,0x3E,0x1E,0x00,0x00,0x7C,0x3C,0x00,
0x01,0xEE,0x70,0x00,0x03,0x1F,0xE0,0x00,0x00,0x3F,0xE0,0x00,0x00,0x7F,0xF0,0x00,
0x00,0xE7,0xBC,0x00,0x03,0x8F,0xDF,0x00,0x00,0x3D,0xCF,0xE0,0x00,0x79,0xC7,0xFC,
0x00,0xE1,0xC0,0x00,0x03,0x81,0xC0,0x00,0x07,0x03,0xC0,0x00,0x00,0x03,0xC0,0x00,
0x00,0x3F,0x80,0x00,0x00,0x0F,0x80,0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x00,0x3C,0x00,0x00,
0x00,0x3C,0x00,0x00,0x00,0x38,0xC0,0x00,0x00,0x38,0xE0,0x00,0x00,0x3F,0xE0,0x78,
0x00,0xFF,0xFF,0xFC,0x03,0xF9,0xDE,0x78,0x00,0x3B,0x9E,0xF0,0x00,0x3F,0x1E,0xE0,
0x00,0x3F,0xFF,0xC0,0x07,0xFE,0x1F,0x80,0x7F,0x9C,0x1F,0xC0,0x00,0x38,0x1E,0xE0,
0x01,0xFF,0x9E,0x70,0x00,0xFF,0xDE,0x38,0x01,0xE3,0xDE,0x38,0x03,0xE3,0x9E,0x1C,
0x07,0xFF,0x9F,0xFC,0x0E,0xFF,0x9E,0xFC,0x1C,0xE3,0x9E,0x7C,0x38,0xE3,0x9E,0x38,
0x60,0xE3,0x9E,0x00,0x00,0xFF,0xDC,0x00,0x00,0xE3,0x9C,0x00,0x00,0xE3,0x9C,0x00,
0x00,0x00,0x1C,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xE0,0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0xF0,0x0F,0xF0,0x00,0xE1,0xFD,0xF0,
0x00,0xE0,0x61,0xE0,0x00,0xE0,0x03,0x80,0x00,0xE8,0x07,0x00,0x01,0xCE,0x1E,0x00,
0x01,0xCF,0x1E,0x00,0x01,0xFE,0x0E,0x00,0xFF,0xFE,0x07,0xFE,0x7D,0x9C,0xFF,0xF2,
0x03,0x9F,0xF7,0x00,0x03,0xBC,0x07,0x00,0x03,0xB8,0x07,0x00,0x01,0xF8,0x07,0x00,
0x00,0xF0,0x07,0x00,0x00,0xF8,0x07,0x00,0x01,0xFC,0x07,0x00,0x03,0xDE,0x07,0x00,
0x07,0x8E,0x07,0x00,0x0E,0x06,0xCF,0x00,0x3C,0x00,0x7F,0x00,0x00,0x00,0x3E,0x00,
0x00,0x00,0x1E,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}
static u8 code HZ1[4][128]={
0x01,0xE0,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0xEF,0x00,0x00,0x1C,0xEF,0x80,0x00,
0x0E,0xEF,0x07,0x80,0x0E,0xEE,0xFF,0xC0,0x0D,0xFE,0xF7,0x80,0x1F,0xCC,0xF7,0x80,
0x1E,0x00,0xF7,0x00,0x00,0x78,0xE7,0x00,0x03,0xFC,0xE7,0x00,0x0F,0x38,0xE7,0x00,
0x00,0x38,0xE7,0x00,0x00,0x70,0xE7,0x00,0x00,0x78,0xE7,0x00,0x1F,0xE0,0xE7,0x00,
0x0E,0x01,0xE7,0x00,0x0E,0x01,0xC7,0x06,0x0E,0x01,0xC7,0x06,0x0E,0x3B,0x87,0x0E,
0x0F,0xE7,0x03,0x8E,0x1F,0xCE,0x03,0xFE,0x1F,0x1C,0x01,0xFE,0x1E,0x70,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
0x00,0xE0,0xE0,0x00,0x00,0xF0,0xF8,0x00,0x00,0xF0,0xF0,0x00,0x00,0xF0,0xF0,0x00,
0x01,0xE1,0xF0,0x00,0x01,0xC1,0xD8,0x00,0x03,0xC3,0xDC,0x00,0x03,0x83,0x8F,0x00,
0x07,0x87,0x87,0x80,0x07,0x87,0x03,0xC0,0x0F,0xCE,0x03,0xF0,0x1F,0xDC,0x01,0xFC,
0x1D,0xFB,0x80,0xFF,0x39,0xF3,0xCE,0x00,0x61,0xE3,0x9F,0x80,0x41,0xC3,0xBE,0x00,
0x01,0xC3,0xF0,0x00,0x01,0xC3,0xE0,0x00,0x01,0x83,0x80,0xC0,0x03,0x83,0x80,0xC0,
0x03,0x83,0x80,0xC0,0x03,0x83,0x81,0xC0,0x03,0x81,0xC1,0xE0,0x03,0x81,0xFF,0xE0,
0x03,0x80,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x80,
0x00,0x0F,0xFF,0x80,0x00,0xFF,0xC0,0x00,0x00,0x03,0xC0,0x00,0x00,0x03,0xC0,0x00,
0x00,0x03,0xC0,0x00,0x00,0x01,0xC0,0x00,0x00,0x01,0xC0,0x00,0x00,0x01,0xC0,0x00,
0x00,0x01,0xC0,0x00,0x00,0x01,0xC0,0x00,0x00,0x01,0xC0,0x00,0x00,0x01,0xC0,0x00,
0x00,0x01,0xC0,0x00,0x00,0x01,0xC0,0x00,0x00,0x01,0xC1,0xF8,0x00,0x07,0xFF,0xFC,
0x3F,0xFF,0xF8,0x06,0x3F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,
0x03,0x80,0x3E,0x00,0x03,0xC0,0x1F,0x00,0x03,0xC0,0x0F,0x00,0x03,0xC0,0x00,0x00,
0x03,0xC0,0x00,0x00,0x03,0xC0,0x00,0x00,0x03,0xC0,0x00,0xFE,0x03,0xC0,0x1F,0xF8,
0x03,0xFF,0xFE,0x00,0x1F,0xE3,0x1E,0x00,0x3F,0x80,0x3C,0x00,0x03,0x80,0x3F,0xC0,
0x03,0x80,0x79,0xE0,0x03,0x8C,0x71,0xE0,0x03,0xB8,0xF1,0xE0,0x03,0xE1,0xE1,0xC0,
0x07,0xC1,0xC1,0xC0,0x1F,0x03,0x83,0xC0,0x7E,0x07,0x03,0xC0,0x7C,0x0E,0x03,0x80,
0x38,0x1C,0x07,0x80,0x00,0x38,0xEF,0x80,0x00,0xE0,0x7F,0x00,0x00,0xC0,0x3E,0x00,
0x00,0x00,0x3C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}
void delayus(u8 x);
u8 read_status();
void status_check();
void data_write(u16 data1);
void command_write(u8 command);
void command_sending_with_one_data(u8 data1,u8 command);
void command_sending_with_two_data(u16 data1, u16 data2, u8 command);
void display_HZ(u8 x,u16 y,u8 *hz);
void clsA(u8 x,u16 y);
void cls(void);
void init_12864(void);
#endif
六,點擊構建工程按鈕,編譯工程。(如下圖7所示)
圖7
七,點擊窗口左下方仿真按鈕,可見lcdPG128x2屏上信息顯示在屏。 (如下圖8,9,10所示)
圖8
圖9
圖10
八,選擇release,點擊構建工程按鈕,編譯工程生成Hex文件。(如下圖11所示)
圖11
九, 系列的001-003虛擬仿真與開發(fā)板對應已證明:虛擬仿真程序對于開發(fā)板有效,之后不再?上下載到開發(fā)板的介紹。
附件Proteus8.9 VSM Studio Keil編譯器仿真AT89C51RD2系列020_lcdPG128x2在已安裝Proteus8.9的計算機文件夾中打開即可
需要進一步了解,請加入QQ群:976235464
020_PG128x2_02pt.rar
139.1 KB, 下載次數(shù): 21, 下載積分: 黑幣 -5
admin + 50 共享資料的黑幣獎勵!
ID:102963 發(fā)表于 2020-5-29 16:24 | 只看該作者
本帖最后由 songxia8013 于 2020-5-29 21:30 編輯
8.9版本仿真,建議搞下STC單片機的,大家好學習下STC單片機編程!
ID:795427 發(fā)表于 2022-6-22 11:05 | 只看該作者
你這樣還不如直接分享一個hex文件就好了,關鍵的OLED驅動顯示你封裝成了OBJ文件。只能看個演示效果。
Powered by 單片機教程網
