查看: 2562|回復(fù): 2
keilc51自帶的intrins.h函數(shù)編譯報(bào)錯(cuò)
INTRINS.H
Intrinsic functions for C51.
Copyright (c) 1988-2010 Keil Elektronik GmbH and ARM Germany GmbH
All rights reserved.
#ifndef __INTRINS_H__
#define __INTRINS_H__
#pragma SAVE
#if defined (__CX2__)
#pragma FUNCTIONS(STATIC)
/* intrinsic functions are reentrant, but need static attribute */
#endif
extern void          _nop_     (void);
extern bit           _testbit_ (bit);
extern unsigned char _cror_    (unsigned char, unsigned char);
extern unsigned int  _iror_    (unsigned int,  unsigned char);
extern unsigned long _lror_    (unsigned long, unsigned char);
extern unsigned char _crol_    (unsigned char, unsigned char);
extern unsigned int  _irol_    (unsigned int,  unsigned char);
extern unsigned long _lrol_    (unsigned long, unsigned char);
extern unsigned char _chkfloat_(float);
extern int           abs       (int);
extern void          _illop_   (void);
#endif
#if !defined (__CX2__)
extern void          _push_    (unsigned char _sfr);
extern void          _pop_     (unsigned char _sfr);
#endif
#pragma RESTORE
#endif
ID:660091 發(fā)表于 2020-5-30 10:22 | 只看該作者
就算是自帶函數(shù)報(bào)錯(cuò),錯(cuò)誤也是在你編寫的函數(shù)中找,因?yàn)樽詭Ш瘮?shù)不可能出錯(cuò)。
你這個(gè)錯(cuò)誤是意思是少了;你看哪里缺了分號(hào)
ID:589491 發(fā)表于 2021-3-22 17:18 | 只看該作者
錯(cuò)誤的分號(hào)
