查看: 3773|回復: 0
中景園電子1.3寸OLED顯示屏程序_C51單片機系列_帶字庫
ID:138443 發(fā)表于 2020-5-31 10:45 | 顯示全部樓層 |閱讀模式
  1. #include <reg52.H>
  2. #include <intrins.h>
  3. sbit lcd_sclk=P1^0;  /*接口定義:lcd_sclk就是D0*/
  4. sbit lcd_sid=P1^1;   /*接口定義:lcd_sid就是D1*/
  5. sbit lcd_rs=P1^2;    /*接口定義:lcd_rs就是DC*/
  6. sbit lcd_cs1=P1^3;   /*接口定義:lcd_cs1就是OLED的片選CS1*/
  7. sbit Rom_OUT=P1^4;   /*字庫IC接口定義:Rom_OUT就是OUT*/
  8. sbit Rom_CS=P1^5;    /*字庫IC接口定義Rom_CS就是字庫IC的CS2*/
  9. #define uchar unsigned char
  10. #define uint unsigned int
  11. #define ulong unsigned long
  12. uchar code bmp1[];
  13. uchar code jiong1[]={/*--  文字:  囧  --*/
  14. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  15. 0x00,0xFE,0x82,0x42,0xA2,0x9E,0x8A,0x82,0x86,0x8A,0xB2,0x62,0x02,0xFE,0x00,0x00,
  16. 0x00,0x7F,0x40,0x40,0x7F,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x7F,0x00,0x00};
  17. uchar code lei1[]={/*--  文字:  畾  --*/
  18. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  19. 0x80,0x80,0x80,0xBF,0xA5,0xA5,0xA5,0x3F,0xA5,0xA5,0xA5,0xBF,0x80,0x80,0x80,0x00,
  20. 0x7F,0x24,0x24,0x3F,0x24,0x24,0x7F,0x00,0x7F,0x24,0x24,0x3F,0x24,0x24,0x7F,0x00};
  21. /*寫指令到LCD模塊*/
  22. void transfer_command_lcd(int data1)
  23. {
  24.         char i;
  25.         lcd_rs=0;
  26.         lcd_sclk=0;
  27.         for(i=0;i<8;i++)
  28.    {
  29.
  30.                 if(data1&0x80) lcd_sid=1;
  31.                 else lcd_sid=0;
  32.                 lcd_sclk=1;
  33.                 _nop_();
  34.                 lcd_sclk=0;
  35.                  data1<<=1;
  36.    }
  37. }
  38. /*寫數(shù)據(jù)到LCD模塊*/
  39. void transfer_data_lcd(int data1)
  40. {
  41.         char i;
  42.         lcd_rs=1;
  43.         lcd_sclk=0;
  44.         for(i=0;i<8;i++)
  45.    {
  46.
  47.                 if(data1&0x80) lcd_sid=1;
  48.                 else lcd_sid=0;
  49.                 lcd_sclk=1;
  50.                 _nop_();
  51.                 lcd_sclk=0;
  52.                  data1<<=1;
  53.    }
  54. }
  55. /*延時*/
  56. void delay(int n_ms)
  57. {
  58. int j,k;
  59. for(j=0;j<n_ms;j++)
  60. for(k=0;k<110;k++);
  61. }
  62. /*等待一個按鍵,我的主板是用P2.0與GND之間接一個按鍵*/
  63. void waitkey()
  64. {
  65. repeat:
  66.           if (P2&0x01) goto repeat;
  67.         else delay(6);
  68.         if (P2&0x01) goto repeat;
  69.         else
  70.         delay(40);;
  71. }
  72. /*LCD模塊初始化*/
  73. void initial_lcd()
  74. {
  75.         lcd_cs1=0;
  76.         Rom_CS = 1;
  77. //        lcd_reset=0;        /*低電平復位*/
  78.         delay(20);
  79.         //lcd_reset=1;                    /*復位完畢*/
  80.         delay(20);
  81.         transfer_command_lcd(0xAE);   //display off
  82.         transfer_command_lcd(0x20);        //Set Memory Addressing Mode
  83.         transfer_command_lcd(0x10);        //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
  84.         transfer_command_lcd(0xb0);        //Set Page Start Address for Page Addressing Mode,0-7
  85.         transfer_command_lcd(0xc8);        //Set COM Output Scan Direction
  86.         transfer_command_lcd(0x02);//---set low column address
  87.         transfer_command_lcd(0x10);//---set high column address
  88.         transfer_command_lcd(0x40);//--set start line address
  89.         transfer_command_lcd(0x81);//--set contrast control register
  90.         transfer_command_lcd(0x7f);
  91.         transfer_command_lcd(0xa1);//--set segment re-map 0 to 127
  92.         transfer_command_lcd(0xa6);//--set normal display
  93.         transfer_command_lcd(0xa8);//--set multiplex ratio(1 to 64)
  94.         transfer_command_lcd(0x3F);//
  95.         transfer_command_lcd(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
  96.         transfer_command_lcd(0xd3);//-set display offset
  97.         transfer_command_lcd(0x00);//-not offset
  98.         transfer_command_lcd(0xd5);//--set display clock divide ratio/oscillator frequency
  99.         transfer_command_lcd(0xf0);//--set divide ratio
  100.         transfer_command_lcd(0xd9);//--set pre-charge period
  101.         transfer_command_lcd(0x22); //
  102.         transfer_command_lcd(0xda);//--set com pins hardware configuration
  103.         transfer_command_lcd(0x12);
  104.         transfer_command_lcd(0xdb);//--set vcomh
  105.         transfer_command_lcd(0x20);//0x20,0.77xVcc
  106.         transfer_command_lcd(0x8d);//--set DC-DC enable
  107.         transfer_command_lcd(0x14);//
  108.         transfer_command_lcd(0xaf);//--turn on oled panel
  109.         lcd_cs1=1;
  110. }
  111. void lcd_address(uchar page,uchar column)
  112. {
  113.         transfer_command_lcd(0xb0 + column);   /*設置頁地址*/
  114.         transfer_command_lcd((((page+2) & 0xf0) >> 4) | 0x10);        /*設置列地址的高4位*/
  115.         transfer_command_lcd(((page+2)& 0x0f) | 0x00);        /*設置列地址的低4位*/
  116. }
  117. /*全屏清屏*/
  118. void clear_screen()
  119. {
  120.         unsigned char i,j;
  121.         lcd_cs1=0;
  122.         Rom_CS = 1;
  123.         for(i=0;i<8;i++)
  124.         {
  125.                 transfer_command_lcd(0xb0+i);
  126.                 transfer_command_lcd(0x02);
  127.                 transfer_command_lcd(0x10);
  128.                 for(j=0;j<132;j++)
  129.                 {
  130.                           transfer_data_lcd(0x00);
  131.                 }
  132.         }
  133.          lcd_cs1=1;
  134. }
  135. /*顯示128x64點陣圖像*/
  136. void display_128x64(uchar *dp)
  137. {
  138.         uint i,j;
  139.         lcd_cs1=0;
  140.         for(j=0;j<8;j++)
  141.         {
  142.                 lcd_address(0,j);
  143.                 for (i=0;i<128;i++)
  144.                 {
  145.                         transfer_data_lcd(*dp);                                        /*寫數(shù)據(jù)到LCD,每寫完一個8位的數(shù)據(jù)后列地址自動加1*/
  146.                         dp++;
  147.                 }
  148.         }
  149.         lcd_cs1=1;
  150. }
  151. /*顯示16x16點陣圖像、漢字、生僻字或16x16點陣的其他圖標*/
  152. void display_graphic_16x16(uint page,uint column,uchar *dp)
  153. {
  154.         uint i,j;
  155.          lcd_cs1=0;
  156.         Rom_CS = 1;
  157.         for(j=2;j>0;j--)
  158.         {
  159.                 lcd_address(column,page);
  160.                 for (i=0;i<16;i++)
  161.                 {
  162.                         transfer_data_lcd(*dp);                                        /*寫數(shù)據(jù)到LCD,每寫完一個8位的數(shù)據(jù)后列地址自動加1*/
  163.                         dp++;
  164.                 }
  165.                 page++;
  166.         }
  167.         lcd_cs1=1;
  168. }
  169. /*顯示8x16點陣圖像、ASCII, 或8x16點陣的自造字符、其他圖標*/
  170. void display_graphic_8x16(uint page,uchar column,uchar *dp)
  171. {
  172.         uint i,j;
  173.         lcd_cs1=0;
  174.         for(j=2;j>0;j--)
  175.         {
  176.                 lcd_address(column,page);
  177.                 for (i=0;i<8;i++)
  178.                 {
  179.                         transfer_data_lcd(*dp);                                        /*寫數(shù)據(jù)到LCD,每寫完一個8位的數(shù)據(jù)后列地址自動加1*/
  180.                         dp++;
  181.                 }
  182.                 page++;
  183.         }
  184.         lcd_cs1=1;
  185. }
  186. /*顯示5*7點陣圖像、ASCII, 或5x7點陣的自造字符、其他圖標*/
  187. void display_graphic_5x7(uint page,uchar column,uchar *dp)
  188. {
  189.         uint col_cnt;
  190.         uchar page_address;
  191.         uchar column_address_L,column_address_H;
  192.         page_address = 0xb0+page-1;
  193.
  194.         lcd_cs1=0;
  195.
  196.         column_address_L =(column&0x0f)-1;
  197.         column_address_H =((column>>4)&0x0f)+0x10;
  198.
  199.         transfer_command_lcd(page_address);                 /*Set Page Address*/
  200.         transfer_command_lcd(column_address_H);        /*Set MSB of column Address*/
  201.         transfer_command_lcd(column_address_L);        /*Set LSB of column Address*/
  202.
  203.         for (col_cnt=0;col_cnt<6;col_cnt++)
  204.         {
  205.                 transfer_data_lcd(*dp);
  206.                 dp++;
  207.         }
  208.         lcd_cs1=1;
  209. }
  210. /****送指令到晶聯(lián)訊字庫IC***/
  211. void send_command_to_ROM( uchar datu )
  212. {
  213.         uchar i;
  214.         for(i=0;i<8;i++ )
  215.         {
  216.                 if(datu&0x80)
  217.                         lcd_sid = 1;
  218.                 else
  219.                         lcd_sid = 0;
  220.                         datu = datu<<1;
  221.                         lcd_sclk=0;
  222.                         lcd_sclk=1;
  223.         }
  224. }
  225. /****從晶聯(lián)訊字庫IC中取漢字或字符數(shù)據(jù)(1個字節(jié))***/
  226. static uchar get_data_from_ROM( )
  227. {
  228.
  229.         uchar i;
  230.         uchar ret_data=0;
  231.         lcd_sclk=1;
  232.         for(i=0;i<8;i++)
  233.         {
  234.                 Rom_OUT=1;
  235.                 lcd_sclk=0;
  236.                 ret_data=ret_data<<1;
  237.                 if( Rom_OUT )
  238.                         ret_data=ret_data+1;
  239.                 else
  240.                         ret_data=ret_data+0;
  241.                 lcd_sclk=1;
  242.         }
  243.         return(ret_data);
  244. }
  245. /*從相關(guān)地址(addrHigh:地址高字節(jié),addrMid:地址中字節(jié),addrLow:地址低字節(jié))中連續(xù)讀出DataLen個字節(jié)的數(shù)據(jù)到 pBuff的地址*/
  246. /*連續(xù)讀取*/
  247. void get_n_bytes_data_from_ROM(uchar addrHigh,uchar addrMid,uchar addrLow,uchar *pBuff,uchar DataLen )
  248. {
  249.         uchar i;
  250.         Rom_CS = 0;
  251.         lcd_cs1=1;
  252.         lcd_sclk=0;
  253.         send_command_to_ROM(0x03);
  254.         send_command_to_ROM(addrHigh);
  255.         send_command_to_ROM(addrMid);
  256.         send_command_to_ROM(addrLow);
  257.         for(i = 0; i < DataLen; i++ )
  258.              *(pBuff+i) =get_data_from_ROM();
  259.         Rom_CS = 1;
  260. }
  261. /******************************************************************/
  262. ulong  fontaddr=0;
  263. void display_GB2312_string(uchar y,uchar x,uchar *text)
  264. {
  265.         uchar i= 0;
  266.         uchar addrHigh,addrMid,addrLow ;
  267.         uchar fontbuf[32];
  268.         while((text[i]>0x00))
  269.         {
  270.                 if(((text[i]>=0xb0) &&(text[i]<=0xf7))&&(text[i+1]>=0xa1))
  271.                 {
  272.                         /*國標簡體(GB2312)漢字在晶聯(lián)訊字庫IC中的地址由以下公式來計算:*/
  273.                         /*Address = ((MSB - 0xB0) * 94 + (LSB - 0xA1)+ 846)*32+ BaseAdd;BaseAdd=0*/
  274.                         /*由于擔心8位單片機有乘法溢出問題,所以分三部取地址*/
  275.                         fontaddr = (text[i]- 0xb0)*94;
  276.                         fontaddr += (text[i+1]-0xa1)+846;
  277.                         fontaddr = (ulong)(fontaddr*32);
  278.
  279.                         addrHigh = (fontaddr&0xff0000)>>16;  /*地址的高8位,共24位*/
  280.                         addrMid = (fontaddr&0xff00)>>8;      /*地址的中8位,共24位*/
  281.                         addrLow = fontaddr&0xff;             /*地址的低8位,共24位*/
  282.                         get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,32 );/*取32個字節(jié)的數(shù)據(jù),存到"fontbuf[32]"*/
  283.                         display_graphic_16x16(y,x,fontbuf);/*顯示漢字到LCD上,y為頁地址,x為列地址,fontbuf[]為數(shù)據(jù)*/
  284.                         i+=2;
  285.                         x+=16;
  286.                 }
  287.                 else if(((text[i]>=0xa1) &&(text[i]<=0xa3))&&(text[i+1]>=0xa1))
  288.                 {
  289.                         /*國標簡體(GB2312)15x16點的字符在晶聯(lián)訊字庫IC中的地址由以下公式來計算:*/
  290.                         /*Address = ((MSB - 0xa1) * 94 + (LSB - 0xA1))*32+ BaseAdd;BaseAdd=0*/
  291.                         /*由于擔心8位單片機有乘法溢出問題,所以分三部取地址*/
  292.                         fontaddr = (text[i]- 0xa1)*94;
  293.                         fontaddr += (text[i+1]-0xa1);
  294.                         fontaddr = (ulong)(fontaddr*32);
  295.
  296.                         addrHigh = (fontaddr&0xff0000)>>16;  /*地址的高8位,共24位*/
  297.                         addrMid = (fontaddr&0xff00)>>8;      /*地址的中8位,共24位*/
  298.                         addrLow = fontaddr&0xff;             /*地址的低8位,共24位*/
  299.                         get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,32 );/*取32個字節(jié)的數(shù)據(jù),存到"fontbuf[32]"*/
  300.                         display_graphic_16x16(y,x,fontbuf);/*顯示漢字到LCD上,y為頁地址,x為列地址,fontbuf[]為數(shù)據(jù)*/
  301.                         i+=2;
  302.                         x+=16;
  303.                 }
  304.                 else if((text[i]>=0x20) &&(text[i]<=0x7e))
  305.                 {
  306.                         unsigned char fontbuf[16];
  307.                         fontaddr = (text[i]- 0x20);
  308.                         fontaddr = (unsigned long)(fontaddr*16);
  309.                         fontaddr = (unsigned long)(fontaddr+0x3cf80);
  310.                         addrHigh = (fontaddr&0xff0000)>>16;
  311.                         addrMid = (fontaddr&0xff00)>>8;
  312.                         addrLow = fontaddr&0xff;
  313.                         get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,16 );/*取16個字節(jié)的數(shù)據(jù),存到"fontbuf[32]"*/
  314.
  315.                         display_graphic_8x16(y,x,fontbuf);/*顯示8x16的ASCII字到LCD上,y為頁地址,x為列地址,fontbuf[]為數(shù)據(jù)*/
  316.                         i+=1;
  317.                         x+=8;
  318.                 }
  319.                 else
  320.                         i++;
  321.         }
  322.
  323. }
  324. void display_string_5x7(uchar y,uchar x,uchar *text)
  325. {
  326.         unsigned char i= 0;
  327.         unsigned char addrHigh,addrMid,addrLow ;
  328.         while((text[i]>0x00))
  329.         {
  330.
  331.                 if((text[i]>=0x20) &&(text[i]<=0x7e))
  332.                 {
  333.                         unsigned char fontbuf[8];
  334.                         fontaddr = (text[i]- 0x20);
  335.                         fontaddr = (unsigned long)(fontaddr*8);
  336.                         fontaddr = (unsigned long)(fontaddr+0x3bfc0);
  337.                         addrHigh = (fontaddr&0xff0000)>>16;
  338.                         addrMid = (fontaddr&0xff00)>>8;
  339.                         addrLow = fontaddr&0xff;
  340.                         get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,8);/*取8個字節(jié)的數(shù)據(jù),存到"fontbuf[32]"*/
  341.
  342.                         display_graphic_5x7(y,x,fontbuf);/*顯示5x7的ASCII字到LCD上,y為頁地址,x為列地址,fontbuf[]為數(shù)據(jù)*/
  343.                         i+=1;
  344.                         x+=6;
  345.                 }
  346.                 else
  347.                 i++;
  348.         }
  349.
  350. }
  351. //===============main program===================
  352. void main(void)
  353. {
  354.         while(1)
  355.         {
  356.                 Rom_CS=1;
  357.                 lcd_cs1=0;
  358.                 initial_lcd();
  359.                 clear_screen();    //clear all dots
  360.                 display_128x64(bmp1);
  361.                 delay(10000);
  362.                 clear_screen();
  363.                 display_GB2312_string(0,1,"12864,帶中文字庫");        /*在第1頁,第1列,顯示一串16x16點陣漢字或8x16的ASCII字*/
  364.                 display_GB2312_string(2,1,"16X16簡體漢字庫,");  /*顯示一串16x16點陣漢字或8x16的ASCII字.以下雷同*/
  365.                 display_GB2312_string(4,1,"或8X16點陣ASCII,");
  366.                 display_GB2312_string(6,1,"或5X7點陣ASCII碼");
  367.                 delay(10000);
  368.                 clear_screen();
  369.                 display_GB2312_string(0,16,"中景園電子");
  370.                 display_GB2312_string(2,1,"主要生產(chǎn)OLED模塊");
  371.                 display_GB2312_string(4,1,"顧客至上真誠服務");
  372.                 display_GB2312_string(6,1,"誠信與質(zhì)量第一!");
  373.                 delay(10000);
  374.                 clear_screen();
  375.                 display_GB2312_string(0,1,"GB2312簡體字庫及");
  376.                 display_GB2312_string(2,1,"有圖型功能,可自");
  377.                 display_GB2312_string(4,1,"編大字或圖像或生");
  378.                 display_GB2312_string(6,1,"僻字,例如:");
  379.
  380.                 display_graphic_16x16(6,97,jiong1);                                        /*在第7頁,第81列顯示單個自編生僻漢字“囧”*/
  381.         display_graphic_16x16(6,113,lei1);                                        /*顯示單個自編生僻漢字"畾“*/
  382.                 delay(10000);
  383.
  384.                 clear_screen();
  385.                 display_GB2312_string(0,1,"<!@#$%^&*()_-+]/");        /*在第1頁,第1列,顯示一串16x16點陣漢字或8*16的ASCII字*/
  386.                 display_string_5x7(3,1,"<!@#$%^&*()_-+]/;.,?[");/*在第3頁,第1列,顯示一串5x7點陣的ASCII字*/
  387.                 display_string_5x7(4,1,"XY electronics Co., ");/*顯示一串5x7點陣的ASCII字*/
  388.                 display_string_5x7(5,1,"Ltd. established at  ");/*顯示一串5x7點陣的ASCII字*/
  389.                 display_string_5x7(6,1,"year 2010.Focus OLED ");/*顯示一串5x7點陣的ASCII字*/
  390.                 display_string_5x7(7,1,"Mobile:13265585975");/*顯示一串5x7點陣的ASCII字*/
  391.                 display_string_5x7(8,1,"Tel:0755-32910715");/*顯示一串5x7點陣的ASCII字*/
  392.                 delay(10000);
  393.                 display_GB2312_string(0,1,"啊阿埃挨哎唉哀皚");        /*在第1頁,第1列,顯示一串16x16點陣漢字或8x16的ASCII字*/
  394.                 display_GB2312_string(2,1,"癌藹矮艾礙愛隘鞍");  /*顯示一串16x16點陣漢字或8x16的ASCII字.以下雷同*/
  395.                 display_GB2312_string(4,1,"氨安俺按暗岸胺案");
  396.                 display_GB2312_string(6,1,"骯昂盎凹敖熬翱襖");
  397.                 delay(10000);
  398.                 display_GB2312_string(0,1,"鬟鬣麼麾縻麂麇麈");
  399.                 display_GB2312_string(2,1,"麋麒鏖麝麟黛黜黝");
  400.                 display_GB2312_string(4,1,"黠黟黢黷黧黥黲黯");
  401.                 display_GB2312_string(6,1,"鼢鼬鼯鼴鼷鼽鼾齄");
  402.                 delay(10000);
  403.         }
  404. }
  405. uchar code bmp1[]={
  406. //--  調(diào)入了一幅圖像:D:\我的文檔\My Pictures\12864-555.bmp  --*/
  407. //--  寬度x高度=128x64  --
  408. 0x00,0x06,0x0A,0xFE,0x0A,0xC6,0x00,0xE0,0x00,0xF0,0x00,0xF8,0x00,0x00,0x00,0x00,
  409. 0x00,0x00,0xFE,0x7D,0xBB,0xC7,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xC7,0xBB,0x7D,
  410. 0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  411. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  412. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  413. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,
  414. 0x0C,0xFE,0xFE,0x0C,0x08,0x20,0x60,0xFE,0xFE,0x60,0x20,0x00,0x00,0x00,0x78,0x48,
  415. 0xFE,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xFE,0x00,
  416. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  417. 0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
  418. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  419. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  420. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  421. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  422. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  423. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  424. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  425. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0xFF,
  426. 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,0xFF,0x00,0x00,0xFE,0xFF,0x03,
  427. 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,0xFE,0x00,0x00,0x00,0x00,0xC0,0xC0,
  428. 0xC0,0x00,0x00,0x00,0x00,0xFE,0xFF,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
  429. 0xFF,0xFE,0x00,0x00,0xFE,0xFF,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,
  430. 0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  431. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  432. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  433. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,
  434. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0x0C,
  435. 0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xFF,0xFF,0x00,0x00,0x00,0x00,0xE1,0xE1,
  436. 0xE1,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  437. 0xFF,0xFF,0x00,0x00,0xFF,0xFF,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xFF,
  438. 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  439. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  440. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  441. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x1F,
  442. 0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F,0x0F,0x00,0x00,0x0F,0x1F,0x18,
  443. 0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,
  444. 0x00,0x00,0x00,0x00,0x00,0x0F,0x1F,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,
  445. 0x1F,0x0F,0x00,0x00,0x0F,0x1F,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F,
  446. 0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  447. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  448. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  449. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  450. 0x00,0x00,0x00,0x00,0x00,0xE2,0x92,0x8A,0x86,0x00,0x00,0x7C,0x82,0x82,0x82,0x7C,
  451. 0x00,0xFE,0x00,0x82,0x92,0xAA,0xC6,0x00,0x00,0xC0,0xC0,0x00,0x7C,0x82,0x82,0x82,
  452. 0x7C,0x00,0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0xC0,0xC0,0x00,0x7C,0x82,0x82,0x82,
  453. 0x7C,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  454. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  455. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  456. 0x00,0x24,0xA4,0x2E,0x24,0xE4,0x24,0x2E,0xA4,0x24,0x00,0x00,0x00,0xF8,0x4A,0x4C,
  457. 0x48,0xF8,0x48,0x4C,0x4A,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  458. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  459. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  460. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  461. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  462. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x20,0x10,0x10,
  463. 0x10,0x10,0x20,0xC0,0x00,0x00,0xC0,0x20,0x10,0x10,0x10,0x10,0x20,0xC0,0x00,0x00,
  464. 0x00,0x12,0x0A,0x07,0x02,0x7F,0x02,0x07,0x0A,0x12,0x00,0x00,0x00,0x0B,0x0A,0x0A,
  465. 0x0A,0x7F,0x0A,0x0A,0x0A,0x0B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  466. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  467. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  468. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  469. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  470. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x40,0x40,
  471. 0x40,0x50,0x20,0x5F,0x80,0x00,0x1F,0x20,0x40,0x40,0x40,0x50,0x20,0x5F,0x80,0x00,
  472. };
復制代碼
中景園電子1.3寸OLED顯示屏_C51系列_帶字庫.zip
97.85 KB, 下載次數(shù): 35, 下載積分: 黑幣 -5
