//20kHz PWM 可調(diào),步進(jìn)2%。帶顯示,樓主小菜菜上課溜號了頻率不會寫,下面代碼應(yīng)該是1khz的,該怎么改呢???還請諸位不吝賜教,先行謝過了- /* Main.c file generated by New Project wizard
- * Created: 周六 5月 30 2020
- * Processor: AT89C51
- * Compiler: Keil for 8051
- #include<reg51.h>
- #define uint unsigned int
- #define uchar unsigned char
- unsigned char num1;
- unsigned char dis;
- unsigned char code nondis[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//0-9
- uchar time;
- double count=70; //定義占空比,并初始占空比為70%
- sbit PWM=P0^0; //P0^0口輸出PWM
- sbit key_add=P3^4; //加的按鍵
- sbit key_dec=P3^5; //減的按鍵
- void delayxms(uint z); //延時
- void Motor_add(); //增加占空比
- void Motor_dec(); //減少占空比
- void timer0_init(); //定時器0初始化
- //顯示函數(shù)
- void display()
- unsigned char gewei,shiwei,baiwei;
- baiwei=num1/100;
- gewei=num1%10;
- shiwei=(num1/10)%10;
- P2=nondis[gewei];//個位
- P0=0x80;
- delayxms(1);
- P2=0xff;
- P2=nondis[shiwei];//十位
- P0=0x40;
- delayxms(1);
- P2=0xff;
- P2=nondis[baiwei];//百位
- P0=0x20;
- delayxms(1);
- P2=0xff;
- void main()
- timer0_init();
- delayxms(5);
- while(1)
- Motor_add();
- Motor_dec();
- num1 = count;
- display();//顯示函數(shù)
- //延時xms程序
- void delayxms(uint z) //延時xms程序
- uint x,y;
- for(y=z;x>0;x--)
- for(y=110;y>0;y--);
- //加
- void Motor_add()
- if(key_add==0)
- delayxms(2); //此處時間不能太長,否者會的中斷產(chǎn)生沖突
- if(key_add==0)
- count+=2; //每按一次加速按鍵占空比加2
- if(count>=98) //限定占空比上限
- count=98;
- while(!key_add);
- //減
- void Motor_dec()
- if(key_dec==0)
- delayxms(2);//此處時間不能太長
- if(key_dec==0)
- count-=2; //每按一次減速按鍵占空比減2
- if(count<=25) //限定占空比下限
- count=25;
- while(!key_dec);
- /***********定時器0初始化***********/
- TMOD=0x01; //定時器0工作于方式1
- TH0=(65536-10)/256;
- TL0=(65536-10)%256;
- TR0=1;
- ET0=1;
- EA=1;
- /**************定時0中斷處理******************/
- void timer0_int() interrupt 1
- TR0=0; //設(shè)置定時器初值期間,關(guān)閉定時器
- TR0=1;
- time++;
- if(time<count) //count為占空比
- PWM=1; //輸出高電平
- else
- PWM=0;
- if(time>=100)//20khz
- time=0;
(180.25 KB, 下載次數(shù): 89)
2020-5-31 21:16 上傳
仿真圖哥哥們
