2020-6-3 01:32 上傳
單片機源程序如下:
#include<reg52.h>
#include<stdio.h>
#define THC0 0xf9
#define TLC0 0x0f //2ms
unsigned char code Duan[]={0x3F, 0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};//共陰極數(shù)碼管,0-9段碼表
unsigned char Data_Buffer[8]={0,0,0,0,0,0,0,0}; // 顯示緩沖
uchar i=0;
sbit AddSpeed=P1^1;
sbit SubSpeed=P1^2;
sbit TurnForward=P1^3;
sbit TurnBackward=P1^4;
sbit Stop=P1^5;
sbit IN1=P3^0;
sbit IN2=P3^1;
sbit PWM_FC=P1^0;
int e ,e1 ,e2 ;
float uk ,uk1 ,duk ;//pid輸出值
float Kp=15,Ki=12,Kd=1.6;
int out=0;
uint SpeedSet=380;
uint cnt=0;
uint Inpluse=0,num=0;//脈沖計數(shù)
uint PWMTime=100;//脈沖寬度
unsigned char arry[];
void SendString(uint ch);
void PIDControl();
void SystemInit();
void delay(uchar x);
void PWMOUT();
void SetSpeed();
void SegRefre();
/**************主函數(shù)************/
SystemInit();
SetSpeed(); //按鍵設定速度
SegRefre(); //數(shù)碼管顯示刷新
PWMOUT(); //輸出PWM
void PIDControl() //pid偏差計算
e=SpeedSet-num;
duk=(Kp*(e-e1)+Ki*e+Kd*(e-2*e1+e2))/50;
uk=uk1+duk;
out=(int)uk; //輸出為占空比
if(out>1000)
out=1000;
else if(out<0)
out=0;
uk1=uk; //變量值移位
e2=e1;
e1=e;
PWMTime=out;
void delay(uchar x)
uint i,j;
for(i=x;i>0;i--)
for(j=50;j>0;j--);
void PWMOUT()
if(cnt<PWMTime)
PWM_FC=1;
PWM_FC=0;
if(cnt>1000) cnt=0;
void SystemInit()
TMOD=0X21;
TH0=THC0;
TL0=TLC0;
TH1=0xC0;
TL1=0XC0;
ET1=1;
ET0=1;
TR0=1;
TR1=1;
EX0=1;
IT0=1;
EA=1;
e =0;
e1=0;
e2=0;
IN1 = 1;
IN2 = 0;
void SetSpeed()
if(AddSpeed==0)
delay(200); //消抖處理
if(AddSpeed==0)
SpeedSet+=10;
if(SpeedSet>1500)
SpeedSet=1500;
if(SubSpeed==0)
delay(200);
if(SubSpeed==0)
SpeedSet-=10;
if(SpeedSet<0) SpeedSet=0;
if(TurnForward==0)
delay(200);
if(TurnForward==0)
IN1 = 1;
IN2 = 0;
while(TurnForward==0);
if(TurnBackward==0)
delay(200);
if(TurnBackward==0)
IN1 = 0;
IN2 = 1;
while(TurnBackward==0);
if(Stop==0)
delay(200);
if(Stop==0)
IN1 = 1;
IN2 = 1;
while(Stop==0);
void SegRefre() //顯示刷新
Data_Buffer[0]=SpeedSet/1000; //分離設定值各位
Data_Buffer[1]=SpeedSet%1000/100;
Data_Buffer[2]=SpeedSet%100/10;
Data_Buffer[3]=SpeedSet%10;
Data_Buffer[4]=num/1000;
Data_Buffer[5]=num%1000/100;
Data_Buffer[6]=num%100/10;
Data_Buffer[7]=num%10;
void int0() interrupt 0
Inpluse++; //采集外部脈沖
void t0() interrupt 1
static unsigned char Bit=0;
static unsigned int time=0;
TH0=THC0;
TL0=TLC0;
Bit++;
time++; //轉速測量周期
if(Bit>8) Bit=0;
P0=0xff;
P2=Duan[Data_Buffer[Bit]]; //顯示段碼
switch(Bit) //數(shù)碼管位選
case 0:P0=0X7F;break;
case 1:P0=0XBF;break;
case 2:P0=0XDF;break;
case 3:P0=0XEF;break;
case 4:P0=0XF7;break;
case 5:P0=0XFB;break;
case 6:P0=0XFD;break;
case 7:P0=0XFE;break;
if(time>100)
time=0;
num=Inpluse*5;
Inpluse=0;
PIDControl();
void timer_1() interrupt 3
cnt++; //cnt越大占空比越高2.5Khz
2020-6-6 02:22 上傳
全部資料51hei下載地址:
單片機直流電機.zip
(1.81 MB, 下載次數(shù): 178)
2020-6-3 01:34 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
