用12864仿真數(shù)字電壓表
單片機源程序如下:
- #include<reg51.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- unsigned char code liu[]= // 劉
- {0x00,0x08,0x28,0x49,0x8A,0x0C,0xC8,0x38,0x08,0x00,0xF8,0x00,0x00,0xFF,0x00,0x00,
- 0x40,0x20,0x10,0x08,0x04,0x03,0x06,0x38,0x10,0x00,0x07,0x20,0x40,0x3F,0x00,0x00
- unsigned char code si[]=
- {0x00,0x00,0x00,0xFE,0x92,0x92,0x92,0xFE,0x92,0x92,0x92,0x92,0xFE,0x00,0x00,0x00,
- 0x20,0x38,0x00,0x00,0x3C,0x40,0x40,0x42,0x4C,0x40,0x40,0x70,0x04,0x18,0x30,0x00
- unsigned char code si1[]=
- 0x20,0x38,0x00,0x00,0x3C,0x40,0x40,0x42,0x4C,0x40,0x40,0x70,0x04,0x18,0x30,0x00};
- sbit CS1=P2^0;//片選1,低電平有效,CS1=0開左屏幕,CS1=1關(guān)左屏幕
- sbit CS2=P2^1;//片選2,低電平有效,CS2=0開右屏幕,CS2=1關(guān)右屏幕
- sbit RS=P2^2;//數(shù)據(jù),指令選擇信號,RS=1為數(shù)據(jù)操作,RS=0為寫指令或讀狀態(tài)(一般為讀忙標志)
- sbit RW=P2^3;//讀寫選擇信號,RW=1為讀選通,RW=0為寫選通
- sbit EN=P2^4;//讀寫使能信號
- void busy()//忙檢測函數(shù)
- P0=0X00; //這句不能少
- RS=0; //表示寫或讀,1為數(shù)據(jù)操作
- RW=1;//RW為1時表示讀取12864的信息
- EN=1;
- while(P0&0X80);//P0&0X80結(jié)果為真則一直執(zhí)行空操作,也就是說P0&0X80為0則結(jié)束循環(huán)
- EN=0;
- void wcmd(uchar cmd)
- busy(); //每次寫入指令或數(shù)據(jù)之前都進行忙檢測
- RS=0;
- RW=0;
- P0=cmd;
- EN=1;_nop_();_nop_();//在EN下降沿寫入數(shù)據(jù)和指令
- EN=0;
- void wdata(uchar dat) //寫命令和寫數(shù)據(jù)只在RS=0或RS=1上不同,其余都相同
- busy();
- RS=1;
- RW=0;
- P0=dat;
- EN=0;
- void set_page(uchar page)//設置頁,12864LCD共有8頁,每頁有8行點陣點。
- page=0xb8|page; //首頁地址為0XB8
- wcmd(page); //page取值范圍為0~7,表示第1到8頁
- void set_line(uchar line)//設置顯示的起始行,共有0--63行,一般從0行開始顯示
- line=0xc0|line; //起始行地址0XC0
- wcmd(line); //line取值范圍為0~63,表示第1到64行
- void set_column(uchar column)//設置顯示的列
- //column=column&0x3f; //列的最大值為0X3F,即64
- column=0x40|column; //列的首地址為0X40,
- wcmd(column); //column的取值范圍為0~63,共64列
- void select_screen(uchar screen)//選屏,screen取值范圍為0,1,2
- switch(screen)
- case 0:CS1=0;CS2=0;break; //全屏
- case 1:CS1=0;CS2=1;break; //左半屏
- case 2:CS1=1;CS2=0;break; //右半屏
- default:break;
- void clear_screen(uchar screen)//清屏
- uchar i,j;
- select_screen(screen);//先選屏
- for(i=0;i<8;i++)//控制頁數(shù)0--7,共8頁
- set_page(i);//設置頁
- set_column(0); //設置列,每頁都從第1列開始,共64列
- for(j=0;j<64;j++)//控制列數(shù)0--63,共64列
- wdata(0x00);//寫入0,列地址指針會自動加1
- void init() //LCD初始化
- busy(); //忙檢測
- select_screen(0);//選屏,全屏
- wcmd(0x20);
- select_screen(0); //選屏,全屏
- wcmd(0x00);
- clear_screen(0); //清屏
- set_line(0); //起始行:0
- void show(uchar screen,uchar page,uchar column,uchar *p)//顯示一個漢字,一個漢字有32字節(jié)數(shù)據(jù)
- uchar i; //screen表示選擇屏幕,page表示頁,column表示列,*p表示漢字的數(shù)組
- select_screen(screen); //選屏
- set_page(page); //設置頁,寫上半頁
- set_column(column);//設置列
- for(i=0;i<16;i++) //控制16列的數(shù)據(jù)輸出
- wdata(p[i]); //漢字的上半部分
- set_page(page+1); //寫下半頁
- set_column(column); //控制列
- wdata(p[i+16]); //漢字的下半部分
- void main()
- //unsigned char i;
- init(); //LCD初始化
- set_line(0); //顯示開始行
- //1表示左屏顯示,0表示從0頁開始顯示。因為一頁只有8行點,
- //而顯示一個漢字需要16行點(整屏有64行點),所以顯示一個漢字需要2頁
- //第0頁顯示"歡"字的上半部分,第1頁顯示"歡"漢字的下半部分
- //2*16表示從第32列開始顯示,前面空出0~31列(即2個字的位置)
- show(1,0,1*16,liu);
- show(1,0,2*16,si);
- show(1,0,3*16,si1);
- while(1);
復制代碼
12864的程序和仿真圖.rar
(19.94 KB, 下載次數(shù): 24)
2020-6-4 10:07 上傳
點擊文件名下載附件
