查看: 3640|回復(fù): 3
單片機(jī)交通燈 按鍵1切換長(zhǎng)短時(shí)間,按鍵2增加時(shí)間,按鍵3夜間模式所有黃燈閃爍
#include<reg51.h>
#define              uint unsigned int;
#define  uchar unsigned char;
void  DigitalTube();   //數(shù)碼管顯示函數(shù)
void  InterruptT0();              //內(nèi)部中斷0
sbit  P10 = P1^0;                            //紅綠燈引腳的初始化
sbit  P11 = P1^1;
sbit  P12 = P1^2;
sbit  P13 = P1^3;
sbit  P14 = P1^4;
sbit  P15 = P1^5;
sbit  P16 = P1^6;                            //數(shù)碼管使能控制
sbit  P17 = P1^7;
sbit  P20 = P2^0;
sbit  P21 = P2^1;
sbit  K22 = P2^2;                 //按鍵22
sbit  K23 = P2^3;
sbit  K24 = P2^4;
sbit dula = P2^5;
uint LedBuf[10] = {
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90
};                            //0~9的數(shù)字顯示共陽(yáng)
uint Kflag = 1;                              //按鍵24的標(biāo)志
uint LedNumNS = 27;                 //南北的數(shù)字顯示
uint LedNumEW = 30;                 //東西的數(shù)字顯示
uint i = 0;
uint j = 0;
uint j1 = 0;
uint k = 0;
uint g = 0;
uint z = 0;
int r=0;                                         //計(jì)數(shù)及狀態(tài)的變量
uint LedTime1 = 30;
uint LedTime2 = 27;
uint LedTime3 = 30;
uint LedTime4 = 27;
uint Kf22 = 1;              //按鍵前一個(gè)狀態(tài)的值
uint Kf23 = 1;
uint Kf24 = 1;
uint KSta24 = 1;              //按鍵的當(dāng)前值
uint KSta23 = 1;
uint KSta22 = 1;
uchar Kflag22 = 0;              //按鍵22的switch函數(shù)參數(shù)
EA = 1;                                          //開(kāi)總中斷
ET0 = 1;                            //開(kāi)內(nèi)部中斷0
TR0 = 1;
TMOD = 0x01;                 //方式1
TH0 = 0xFC;
TL0= 0x67; //1ms中斷
P1 = 0xEE;                            //
void InterruptT0() interrupt 1
TH0 = 0xFC;
TL0 = 0x67; //1ms中斷
i++;
k++;
KSta24 = K24;                                //按鍵K24  夜間模式
if(Kf24 != KSta24)                            //按鍵有動(dòng)作
                          if(Kf24 == 1)                            //按鍵按下
                                        Kflag = !Kflag;
                          Kf24 = KSta24;
KSta23 = K23;                                //按鍵K23  增減時(shí)長(zhǎng)
if(Kf23 != KSta23)                            //按鍵有動(dòng)作
            if(Kf23 == 1)                            //按鍵按下
            //              LedTime = LedTime +2;
                          LedTime1 = LedTime1 +5;              //32  34 36 38 30
                          LedTime2 = LedTime2 +5;              //25  23 21  19 17
                          LedTime3 = LedTime3 +5;
                          LedTime4 = LedTime4 +5;
                          if(LedTime1 >=60)
                                                      LedTime1 = 10;
                                                      LedTime2 = 7;
                                                      LedTime3 = 10;
                                                      LedTime4 = 7;
                          LedNumEW = LedTime1;
                          LedNumNS = LedTime2;
            Kf23= KSta23;
KSta22 = K22;                                //按鍵K22  某方向長(zhǎng)時(shí)間紅燈
if(Kf22 != KSta22)                            //按鍵有動(dòng)作
            if(Kf22 == 1)                            //按鍵按下
                          Kflag22 ++;
                          if(Kflag22>= 3)
                                        Kflag22 = 0;
                          switch(Kflag22)
                                        case 1:
                                                      LedTime1 = 60;
                                  LedTime2 = 57;              //case2
                                                      LedTime3 = 30;
                                                      LedTime4 = 27; //case1
                                            break;
                                        case 2:
                                                      LedTime1 = 30;
                                  LedTime2 = 27;                //case2
                                                      LedTime3 = 60;
                                                      LedTime4 = 57;              //case1
                                                      break;
            Kf22 = KSta22;
if(j >= 200)
j  = 0;
j1++;
if(i >= 1000)
i = 0;
LedNumNS--;              //27
LedNumEW--;              //30
switch(g)
{                                            //剛開(kāi)始東西紅  南北綠
case 0:        //********2
            if(LedNumEW == 3)                                                           //*****3
                                        P14 = ! P14;   //綠燈滅
            if(Kf24 == Kflag)                            P15 = ! P15;   //黃燈亮
                                        LedNumNS = 3;
            if(LedNumEW == 0)
                          LedNumNS =  LedTime3;              //   30東西綠南北紅的時(shí)間
                          LedNumEW =               LedTime4;              //  27
                          P12 = ! P12;                 //東西綠燈亮
                          P10 = ! P10;                //東西紅燈滅
                          P13 = ! P13;                              //nanbei紅燈亮
                if(Kf24 == Kflag)
                          P15 = ! P15;                //南北黃燈滅
                          g = 1;
            break;
case 1:        //******4
            if(LedNumNS == 3)                 //黃燈亮
                       P12 = !P12;
                                           P11 = !P11;
                                           LedNumEW = 3;
            if(LedNumNS == 0)        //********5
                          LedNumEW = LedTime1;//重新賦值
            if(Kf24 == Kflag)              P11 = !P11;                 //南北黃燈滅
                          P10 = !P10;                //dongxi紅燈亮
                          P14 = !P14;
                          P13 = !P13;
                          g = 0;
            break;
if(Kf24 != Kflag)                                                        //夜間模式
r=0;
g=0;
if(j1 % 2 == 0)
            P11 = ! P11;
            P15 = ! P15;
}                                                          //所有方向黃燈閃爍
void  DigitalTube()                            //數(shù)碼管
switch(z)
case 0:        //第一個(gè)數(shù)碼管顯示數(shù)字
  P0 =0xFF;                            //防止數(shù)字顯示混亂
            dula = 1;
            P0 = LedBuf[LedNumEW / 10];              //十位
            P20 = 0;
            P17 = 0;
            P21 = 0;
            P16 = 1;
            dula = 0;
            z++;
            break;
case 1:                                                          //第二個(gè)數(shù)碼管亮
               P0 =0xFF;
            dula = 1;
            P0 = LedBuf[LedNumEW % 10];              //個(gè)位
            P16 = 0;
            P20 = 0;
            P21 = 0;
            P17 = 1;
            dula = 0;
  z++;
            break;
case 2:                                                        //第三個(gè)數(shù)碼管亮
  P0 =0xFF;
            dula = 1;
            P0 = LedBuf[LedNumNS / 10]; //十位
            P21 = 0;
            P16 = 0;
            P17 = 0;                                            //關(guān)閉2
            P20 = 1;                                            //使能第3個(gè)數(shù)碼管
            dula = 0;
            z++;                                                        //進(jìn)入3
            break;
case 3:                                                          //第四個(gè)數(shù)碼管亮
  P0 =0xFF;
            dula = 1;
            P0 = LedBuf[LedNumNS % 10];              //個(gè)位
            P20 = 0;                                          //第三個(gè)關(guān)閉
            P16 = 0;
            P17 = 0;
            P21 = 1;                                          //使能第四個(gè)數(shù)碼管
            dula = 0;
            z = 0;                                                          //進(jìn)入0
            break;
default:break;
ID:776649 發(fā)表于 2020-6-12 09:16 | 只看該作者
。。。大佬不發(fā)個(gè)程序嗎。。。
ID:905886 發(fā)表于 2021-4-14 20:11 | 只看該作者
謝謝樓主
ID:594512 發(fā)表于 2021-5-13 17:45 | 只看該作者
有仿真嗎
