批注 2020-06-04 183514.png (152.93 KB, 下載次數(shù): 53)
2020-6-4 18:37 上傳
單片機源程序如下:
#include <showfun.h>
#include <stdio.h>
extern char fnLCMInit(); // LCM 初始化
extern void at(unsigned char x,unsigned char y);/*設(shè)定文本x,y值*/
extern void cls(); // 清屏
extern void charout(unsigned char *str); //ASCII(8*8) 顯示函數(shù)
extern void fnSetPos(unsigned char urow, unsigned char ucol); // 設(shè)置當(dāng)前地址
extern uchar dprintf(uchar x,uchar y,char *fmt);// ASCII(8*16) 及 漢字(16*16) 顯示函數(shù)
extern uchar fnPR12(uchar uCmd); // 寫無參數(shù)的指令
extern uchar fnPR13(uchar uData); // 寫數(shù)據(jù)
extern unsigned int Adc0832(unsigned char channel);
extern void Line( unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, bit Mode);
extern void Pixel(unsigned char PointX,unsigned char PointY, bit Mode);
uchar dsp[10]={0,0,0,0,0,0,0,0,0,0,};
char abc[3]={0,0,0,};
uchar key=0;
uint a=100;
uchar n=5;
uchar count=1;
uint k1=0;
uchar GeyKey();
void delay(uchar i);
void control();
main()
fnLCMInit();
fnSetPos(0,0);
dprintf(0,0,"直流電機加-減速及測速系統(tǒng)");
dprintf(0,12,"鍵盤+:步長加速");
dprintf(0,24,"鍵盤-:步長減速");
dprintf(0,36,"鍵盤=:順時針轉(zhuǎn)");
dprintf(0,48,"鍵盤on/c:逆時針轉(zhuǎn)");
dprintf(0,72,"方向:");
dprintf(0,84,"轉(zhuǎn)速:");
P1_1=0;
TMOD=0x15;
TH1=0x3c;
TL1=0xb0;
TH0=0x00;
TL0=0x00;
ET0=1;
ET1=1;
TR0=1;
TR1=1;
{ key=GeyKey();
switch(key)
{ case '1': { a=10;
//sprintf(abc,"%3.2f",a/255.0);
dprintf(0,96," 5 r/min");
//dprintf(0,96,abc);
dprintf(60,96,"r/min");
break; }
case '2': { a=25;dprintf(0,96," 25 r/min"); break; }
case '3': { a=40; dprintf(0,96," 40 r/min"); break; }
case '4': { a=55; dprintf(0,96," 60 r/min"); break; }
case '5': { a=70; dprintf(0,96," 80 r/min"); break; }
case '6': { a=90; dprintf(0,96,"100 r/min"); break; }
case '7': { a=110; dprintf(0,96,"120 r/min"); break; }
case '8': { a=130; dprintf(0,96,"135 r/min"); break; }
case '9': { a=150; dprintf(0,96,"150 r/min"); break; }
case '+': { dprintf(0,72,"方向: 順時針");
control();
break;
case '-': { P1_0=0;
dprintf(0,72,"方向: 逆時針");
control();
break;
case '=': {P1_0=1;dprintf(0,72,"方向: 順時針");break;}
case 'c': {P1_0=0;dprintf(0,72,"方向: 逆時針");break;}
case '/': {dprintf(0,72,"方向: 順時針");
control();}
default: break;
uchar GeyKey()
P1_4=0;
P1_5=1;
P1_6=1;
P1_7=1;
P3_0=1;
P3_1=1;
P3_2=1;
P3_3=1;
_nop_();_nop_();
if(!P3_0)return '7';
if(!P3_1)return '8';
if(!P3_2)return '9';
if(!P3_3)return '/';
P1_4=1;
P1_5=0;
P1_6=1;
P1_7=1;
_nop_();_nop_();
if(!P3_0)return '4';
if(!P3_1)return '5';
if(!P3_2)return '6';
if(!P3_3)return '*';
P1_4=1;
P1_5=1;
P1_6=0;
P1_7=1;
_nop_();_nop_();
if(!P3_0)return '1';
if(!P3_1)return '2';
if(!P3_2)return '3';
if(!P3_3)return '-';
P1_4=1;
P1_5=1;
P1_6=1;
P1_7=0;
_nop_();_nop_();
if(!P3_0)return 'c';
if(!P3_1)return '0';
if(!P3_2)return '=';
if(!P3_3)return '+';
return 0;
void delay(uchar i)
{ uchar j,k;
for(;i>0;i--)
for(j=15;j>0;j--)
for(k=11;k>0;k--);
void time()interrupt 3
TR1=0;
count++;
k1+=TL0;
if(count==51)
sprintf(dsp,"%3d",k1);
dprintf(0,108,dsp);
dprintf(60,108,"r/min");
count=1;
k1=0;
TH1=0x3c;
TL1=0xb0;
TH0=0x00;
TL0=0x00;
TR1=1;
void control()
EA=1;
{ if(a>=150)
a=150;
if(a<=10)
a=10;
P1_1=0;
delay(160-a);
P1_1=1;
delay(a);
key=GeyKey();
if(key=='-') a-=n;
if(key=='+') a+=n;
if(key=='=')
{ P1_0=1;
if(key=='c')
{ P1_0=0;
if(key=='*')
{ P1_1=0;
break;
if(key!=0)
break;
EA=0;
全部資料51hei下載地址:
直流電機測速+中文液晶顯示.rar
(95.73 KB, 下載次數(shù): 43)
2020-6-4 18:37 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
