查看: 1747|回復: 1
單片機+24c02c是怎么讀跟寫的呢?
ID:699678 發(fā)表于 2020-6-5 15:26 | 顯示全部樓層 |閱讀模式
定時器實現秒表,每一秒寫入24C02C一次,秒數可以用液晶1602第一行顯示。顯示格式為“miaoshu:**”,其中**代表具體的秒數。重新上電后,從上一次寫入的秒數開始計時。下面我自己寫的,讀和寫都沒有顯示出來
#include<reg51.h>
sbit sda=P3^1;
sbit scl=P3^0;
sbit dx=P2^6;
sbit wx=P2^7;
uchar  sec,tcnt;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay()
void delayms(uint z)
   uint x,y;
   for(x=z;x>0;x--)
   for(y=110;y>0;y--);
void start()
   sda=1;
   delay();
   scl=1;
   delay();
   sda=0;
   delay();
void stop()
   sda=0;
   delay();
   scl=1;
   delay();
   sda=1;
   delay();
void respons()
   uchar i;
   scl=1;
   delay();
   while((sda==1)&&(i<250))i++;
   scl=0;
   delay();
void init()
   sda=1;
   delay();
   scl=1;
   delay();
void write_byte(uchar date)
   uchar i,temp;
   temp=date;
   for(i=0;i<8;i++)
      temp=temp<<1;
          scl=0;
          delay();
          sda=CY;
          delay();
          scl=1;
          delay();
   scl=0;
   delay();
   sda=1;
   delay();
uchar read_byte()
   uchar i,k;
   scl=0;
   delay();
   sda=1;
   delay();
   for(i=0;i<8;i++)
      scl=1;
          delay();
          k=(k<<1)|sda;
          scl=0;
          delay();
   return k;
void write_add(uchar address,uchar date)
   start();
   write_byte(0xa0);
   respons();
   write_byte(address);
   respons();
   write_byte(date);
   respons();
   stop();
uchar read_add(uchar address)
   uchar date;
   start();
   write_byte(0xa0);
   respons();
   respons();
   start();
   write_byte(0xa1);
   respons();
   date=read_byte();
   stop();
   return date;
void display(uchar shi,uchar ge)
P0=0xff;
delayms(1);
wx=1;
P0=0xfe;
wx=0;
P0=0xff;
delayms(1);
dx=1;
P0=table[shi];
dx=0;
P0=0xff;
delayms(1);
wx=1;
P0=0xfd;
wx=0;
P0=0xff;
delayms(1);
dx=1;
P0=table[ge];
dx=0;
   init();
   sec=read_add(1);
    if(sec>60)sec=0;
  TMOD=0x01;
  ET0=1;
  EA=1;
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  TR0=1;
    display(sec/10,sec%10);
        if(tcnt==20)
    write_add(1,sec);
    tcnt=0;
        sec++;
        if(sec==60)
        sec=0;
  void t0()interrupt 1
   tcnt++;
ID:732506 發(fā)表于 2020-6-6 01:25 | 顯示全部樓層
用仿真里面的 I2C DEBUG 工具看一下一般都可以找到原因,還有兩根線都要加上拉電阻。
Powered by 單片機教程網
