查看: 3326|回復(fù): 1
單片機流水燈+花樣控制(LED燈控制)
ID:773922 發(fā)表于 2020-6-9 14:15 | 顯示全部樓層 |閱讀模式
  1. #include<reg51.h>
  2. sbit S1=P1^0; //將 S1位定義為P1.0引腳.
  3. sbit S2=P1^1;
  4. sbit S3=P1^2;
  5. sbit S4=P1^3;
  6. unsigned char keyval;
  7. void led_delay(void)
  8. {
  9.         unsigned char i,j;
  10.         for(i=0;i<220;i++)
  11.                 for(j=0;j<220;j++);
  12. }
  13. void delay10ms(void)//軟件消抖延時函數(shù)
  14. {
  15.         unsigned char i,j;
  16.         for(i=0;i<100;i++)
  17.                 for(j=0;j<100;j++);
  18. }
  19. void forward(void) //正向流水點亮LED函數(shù)
  20. {
  21.         P3=0xfe;
  22.         led_delay();
  23.         P3=0xfd;
  24.         led_delay();
  25.         P3=0xfb;
  26.         led_delay();
  27.         P3=0xf7;
  28.         led_delay();
  29.         P3=0xef;
  30.         led_delay();
  31.         P3=0xdf;
  32.         led_delay();
  33.         P3=0xbf;
  34.         led_delay();
  35.         P3=0x7f;
  36.         led_delay();
  37. }
  38. void backward(void)
  39. {
  40.         P3=0x7f;
  41.         led_delay();
  42.         P3=0xbf;
  43.         led_delay();
  44.         P3=0xdf;
  45.         led_delay();
  46.         P3=0xef;
  47.         led_delay();
  48.         P3=0xf7;
  49.         led_delay();
  50.         P3=0xfb;
  51.         led_delay();
  52.         P3=0xfd;
  53.         led_delay();
  54.         P3=0xfe;
  55.         led_delay();
  56. }
  57. void Alter(void)
  58. {
  59.         P3=0x0f;
  60.         led_delay();
  61.         P3=0xf0;
  62.         led_delay();
  63. }
  64. void flash(void) //閃爍點亮LED的函數(shù)
  65. {
  66.         P3=0xff;
  67.         led_delay();
  68.         P3=0x00;
  69.         led_delay();
  70. }
  71. void key_scan(void)
  72. {
  73.         P1=0xff;
  74.         if((P1&0x0f)!=0x0f) //檢測到有鍵按下
  75.                 {
  76.                         delay10ms();//延時10ms再去檢測
  77.                         if(S1==0) //按鍵 k1被按下
  78.                         keyval=1;
  79.                         if(S2==0) //按鍵 k2被按下
  80.                         keyval=2;
  81.                         if(S3==0) //按鍵 k3被按下
  82.                         keyval=3;
  83.                         if(S4==0) //按鍵 k4被按下
  84.                         keyval=4;
  85.                 }
  86. }
  87. void main(void)
  88. {
  89.         keyval=0; //鍵值初始化為0
  90.         while(1)
  91.         {
  92.                 key_scan();
  93.                 switch(keyval)
  94.                 {
  95.                         case 1:forward();
  96.                                 break;
  97.                         case 2:backward();
  98.                                 break;
  99.                         case 3:Alter();
  100.                                 break;
  101.                         case 4: flash();
  102.                                 break;
  103.                 }
  104.         }
  105. }
LED.zip
28.86 KB, 下載次數(shù): 31, 下載積分: 黑幣 -5
內(nèi)含源碼,仿真文件
ID:772118 發(fā)表于 2020-6-15 10:19 | 顯示全部樓層
怎么錯的  我上當(dāng)了
