已經(jīng)成功了的工程文件分享給大家。可能需要的環(huán)境搭建教程(點(diǎn)替換成.)www點(diǎn)wzyrr520點(diǎn)xyz/blog/post/admin/ESP32-CAM-Arduino-IDE
psc (1).jpg (179.56 KB, 下載次數(shù): 114)
2020-6-10 11:31 上傳
2020-6-10 11:31 上傳
- #include "esp_camera.h"
- #include <WiFi.h>
- // WARNING!!! Make sure that you have either selected ESP32 Wrover Module,
- // or another board which has PSRAM enabled
- // Select camera model
- //#define CAMERA_MODEL_WROVER_KIT
- //#define CAMERA_MODEL_ESP_EYE
- //#define CAMERA_MODEL_M5STACK_PSRAM
- //#define CAMERA_MODEL_M5STACK_WIDE
- #define CAMERA_MODEL_AI_THINKER
- #include "camera_pins.h"
- const char* ssid = "2307";
- const char* password = "88888888";
- void startCameraServer();
- void setup() {
- Serial.begin(115200);
- Serial.setDebugOutput(true);
- Serial.println();
- camera_config_t config;
- config.ledc_channel = LEDC_CHANNEL_0;
- config.ledc_timer = LEDC_TIMER_0;
- config.pin_d0 = Y2_GPIO_NUM;
- config.pin_d1 = Y3_GPIO_NUM;
- config.pin_d2 = Y4_GPIO_NUM;
- config.pin_d3 = Y5_GPIO_NUM;
- config.pin_d4 = Y6_GPIO_NUM;
- config.pin_d5 = Y7_GPIO_NUM;
- config.pin_d6 = Y8_GPIO_NUM;
- config.pin_d7 = Y9_GPIO_NUM;
- config.pin_xclk = XCLK_GPIO_NUM;
- config.pin_pclk = PCLK_GPIO_NUM;
- config.pin_vsync = VSYNC_GPIO_NUM;
- config.pin_href = HREF_GPIO_NUM;
- config.pin_sscb_sda = SIOD_GPIO_NUM;
- config.pin_sscb_scl = SIOC_GPIO_NUM;
- config.pin_pwdn = PWDN_GPIO_NUM;
- config.pin_reset = RESET_GPIO_NUM;
- config.xclk_freq_hz = 20000000;
- config.pixel_format = PIXFORMAT_JPEG;
- //init with high specs to pre-allocate larger buffers
- if(psramFound()){
- config.frame_size = FRAMESIZE_UXGA;
- config.jpeg_quality = 10;
- config.fb_count = 2;
- } else {
- config.frame_size = FRAMESIZE_SVGA;
- config.jpeg_quality = 12;
- config.fb_count = 1;
- #if defined(CAMERA_MODEL_ESP_EYE)
- pinMode(13, INPUT_PULLUP);
- pinMode(14, INPUT_PULLUP);
- #endif
- // camera init
- esp_err_t err = esp_camera_init(&config);
- if (err != ESP_OK) {
- Serial.printf("Camera init failed with error 0x%x", err);
- return;
- sensor_t * s = esp_camera_sensor_get();
- //initial sensors are flipped vertically and colors are a bit saturated
- if (s->id.PID == OV3660_PID) {
- s->set_vflip(s, 1);//flip it back
- s->set_brightness(s, 1);//up the blightness just a bit
- s->set_saturation(s, -2);//lower the saturation
- //drop down frame size for higher initial frame rate
- s->set_framesize(s, FRAMESIZE_QVGA);
- #if defined(CAMERA_MODEL_M5STACK_WIDE)
- s->set_hmirror(s, 1);
- #endif
- WiFi.begin(ssid, password);
- while (WiFi.status() != WL_CONNECTED) {
- delay(500);
- Serial.print(".");
- Serial.println("");
- Serial.println("WiFi connected");
- startCameraServer();
- Serial.print("Camera Ready! Use 'http://");
- Serial.print(WiFi.localIP());
- Serial.println("' to connect");
- void loop() {
- // put your main code here, to run repeatedly:
- delay(10000);
2020-6-10 15:34 上傳
esp32cam.rar
(21 KB, 下載次數(shù): 106)
2020-6-10 11:13 上傳
點(diǎn)擊文件名下載附件
這個(gè)是編譯好的工程文件 下載積分: 黑幣 -5
