查看: 1439|回復(fù): 0
單片機(jī)8*8點(diǎn)陣顯示加油
ID:752001 發(fā)表于 2020-6-13 14:35 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<intrins.h>
typedef unsigned char uchar;
typedef unsigned int uint;
#define P P1
sbit SER=P3^4;
sbit SCK=P3^6;
sbit RCK=P3^5;
void SendTo595(uchar byteData);
char shu=0xFE;
void delay(unsigned int n)
     unsigned int i=0,j=0;
     for(i=0;i<n;i++)
         for(j=0;j<123;j++);
void hang()
   P=shu;
        shu=_crol_(shu,1);
char a[32]={0x00,0x04,0xFF,0xB4,0xB4,0xB2,0xF1,0x18,
                  0x21,0x22,0xF8,0xA9,0xFA,0xA8,0xA9,0xFA,
            0x00,0x66,0xFF,0xFF,0x7E,0x3C,0x18,0x00,
                                          0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
                int i,b=0;
                                int num=12;
                                while(num--){
                                for(i=0;i<8;i++)
                                                hang();
            SendTo595(a[i+b]);
        delay(3);
                                P=0xFF;
                                SendTo595(0x00);
                                b++;
                        if(b>=24)b=0;
                        P=0xFF;
void SendTo595(uchar Data)
        int j=0;
                for(j;j<8;j++)
                        SCK = 0;
                        SER=0x80&Data;
                        Data=_crol_(Data,1);
      SCK = 1;
                        _nop_();
      RCK = 0;
                        RCK = 1;
            _nop_();
            RCK = 0;
