2020-6-15 08:11 上傳
*鍵時(shí)鐘和鬧鐘光標(biāo)
#鍵用于控制鬧鐘和時(shí)鐘切換
A/B/C/D鍵預(yù)留,暫時(shí)控制LED2燈
數(shù)字鍵用于設(shè)置鬧鐘和時(shí)鐘時(shí)間
#include <reg52.h>
unsigned char ReturnKeyValue=0;
unsigned char KeyN=0;
#define WE8 0xfe
#define WE7 0xfd
#define WE6 0xfb
#define WE5 0xf7
#define WE4 0xef
#define WE3 0xdf
#define WE2 0xbf
#define WE1 0x7f
//sbit dula = P2^6;
//sbit wela = P2^7;
sbit BEEP =P3^0;
sbit LED1 =P3^2;
sbit LED2 = P3^3;
unsigned char CurrentSec_ge=0;
unsigned char CurrentSec_shi=0;
unsigned char CurrentMin_ge=0;
unsigned char CurrentMin_shi=0;
unsigned char CurrentHour_ge=0;
unsigned char CurrentHour_shi=0;
unsigned char SetClockSec_ge=0;
unsigned char SetClockSec_shi=0;
unsigned char SetClockMin_ge=0;
unsigned char SetClockMin_shi=0;
unsigned char SetClockHour_ge=0;
unsigned char SetClockHour_shi=0;
unsigned char ChangeTimeCount =0;
uint TimeKCount =0;
uint TimeGCount =0;
uint TimeKflag =0;
uint num = 0;
uint flag;
uint cflag;
uchar code table[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar code table1[] = {0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x80};
uint rsec = 0, rmin = 0, rhour = 0;
uint csec = 0, cmin = 1, chour = 0;
void clock();
void delay(uint z);
void displaysec(uint sec);
void displaymin(uint min);
void displayhour(uint hour);
unsigned char AlarmTimeCount =0;
void Alarmclock()
if(rsec == csec && rmin == cmin && rhour == chour)
BEEP =0;
LED1 =0;
AlarmTimeCount=200;
void delay(uint z)
uint x,y;
for(x=0;x<z;x++)
for(y=0;y<110;y++);
P2 = WE1;
if((KeyN==1)||(KeyN==7))
if(TimeKflag==1)
P0 = 0xff;
P0 = table[sec%10];
P0 = table[sec%10];
delay(3);
P2 = WE2;
if((KeyN==2)||(KeyN==8))
if(TimeKflag==1)
P0 = 0xff;
P0 = table[sec/10];
P0 = table[sec/10];
delay(3);
P2 = WE3;
P0 = 0xBF;
delay(3);
P2 = WE4;
if((KeyN==3)||(KeyN==9))
if(TimeKflag==1)
P0 = 0xff;
P0 = table[min%10]- 0x80;
delay(5);
P2 = WE5;
if((KeyN==4)||(KeyN==10))
if(TimeKflag==1)
P0 = 0xff;
P0 = table[min/10] ;
delay(5);
P2 = WE6;
P0 = 0xBF;
delay(3);
P2 = WE7;
if((KeyN==5) ||(KeyN==11))
if(TimeKflag==1)
P0 = 0xff;
P0 = table[hour%10] - 0x80;
delay(3);
P2 = WE8;
if((KeyN==6)||(KeyN==12))
if(TimeKflag==1)
P0 = 0xff;
P0 = table[hour/10];
delay(3);
函數(shù)功能:鍵盤掃描子程序
入口參數(shù):
出口參數(shù):
unsigned char keyscan(void)
unsigned KeyValue =0;
unsigned char n=0;
//掃描第一行
P1=0xfe;
n=P1;
n&=0xf0;
if(n!=0xf0)
P1=0xfe;
n=P1;
n&=0xf0;
if(n!=0xf0)
delay(10);
switch(n)
case(0xe0):KeyValue=1;break; //
case(0xd0):KeyValue=2;break; //
case(0xb0):KeyValue=3;break; //
case(0x70):KeyValue=13;break; //
//掃描第二行
P1=0xfd;
n=P1;
n&=0xf0;
if(n!=0xf0)
P1=0xfd;
n=P1;
n&=0xf0;
if(n!=0xf0)
delay(10);
switch(n)
case(0xe0):KeyValue=4;break; //
case(0xd0):KeyValue=5;break; //
case(0xb0):KeyValue=6;break;
case(0x70):KeyValue=14;break;
//掃描第三行
P1=0xfb;
n=P1;
n&=0xf0;
if(n!=0xf0)
P1=0xfb;
n=P1;
n&=0xf0;
if(n!=0xf0)
delay(10);
switch(n)
case(0xe0):KeyValue=7;break;
case(0xd0):KeyValue=8;break;
case(0xb0):KeyValue=9;break;
case(0x70):KeyValue=15;break;
//掃描第四行
P1=0xf7;
n=P1;
n&=0xf0;
if(n!=0xf0)
P1=0xf7;
n=P1;
n&=0xf0;
if(n!=0xf0)
delay(10);
switch(n)
case(0xe0):KeyValue=11;break; //*鍵
case(0xd0):KeyValue=10;break; //0鍵
case(0xb0):KeyValue=12;break; //#鍵
case(0x70):KeyValue=16;break;
return KeyValue;
void main ()
EA = 1;
ET1 = 1;
TMOD = 0x10;
TR1 = 1;
TH1 = (65536-46071)/256;
TL1 = (65536-46071)%256;
KeyN=0;
P1=0x0f;
Alarmclock();
ReturnKeyValue = keyscan();
if(ReturnKeyValue!=0)
delay(200);
switch(ReturnKeyValue)
case 11:
TimeKCount =10;
TimeGCount =0;
TimeKflag =1;
KeyN++;
if(KeyN>12)
KeyN=0;
break;
case 12: //顯示鬧鐘時(shí)間
ChangeTimeCount++;
break;
case 13: // 沒(méi)用到 可以用于點(diǎn)亮指示燈
case 14: //
case 15: // 沒(méi)用到 可以用于點(diǎn)亮指示燈
case 16: //
LED2=~LED2;
break;
if(ReturnKeyValue<=10)
switch(KeyN)
case 1:
if(ReturnKeyValue==10)
rsec=0;
CurrentSec_ge = 0;
rsec = ReturnKeyValue;
CurrentSec_ge = ReturnKeyValue;
break;
case 2:
rsec=0*10+CurrentSec_ge;
if(ReturnKeyValue<6)
rsec = ReturnKeyValue*10+CurrentSec_ge;
break;
case 3:
rmin=0;
CurrentMin_ge=0;
rmin = ReturnKeyValue;
CurrentMin_ge = ReturnKeyValue;
break;
case 4:
rmin=0*10+CurrentMin_ge;
rmin = ReturnKeyValue*10+ CurrentMin_ge;
break;
case 5:
rhour=0;
CurrentHour_ge=0;
//if(ReturnKeyValue<=4)
rhour = ReturnKeyValue;
CurrentHour_ge = ReturnKeyValue;
break;
case 6:
rhour=CurrentHour_ge;
if(ReturnKeyValue<=2)
if(CurrentHour_ge>=4)
if(ReturnKeyValue<=1)
rhour = ReturnKeyValue*10+CurrentHour_ge;
break;
case 7:
csec=0;
SetClockSec_ge = 0;
csec = ReturnKeyValue;
SetClockSec_ge = ReturnKeyValue;
break;
case 8:
csec=0*10+SetClockSec_ge;
csec = ReturnKeyValue*10+SetClockSec_ge;
break;
case 9:
cmin=0;
SetClockMin_ge=0;
cmin = ReturnKeyValue;
SetClockMin_ge = ReturnKeyValue;
break;
case 10:
cmin=0*10+SetClockMin_ge;
cmin = ReturnKeyValue*10+ SetClockMin_ge;
break;
case 11:
chour=0;
SetClockHour_ge=0;
chour = ReturnKeyValue;
SetClockHour_ge = ReturnKeyValue;
break;
case 12:
chour=SetClockHour_ge;
if(SetClockHour_ge>=4)
chour = ReturnKeyValue*10+SetClockHour_ge;
break;
余下篇幅文件里下
矩陣鍵盤數(shù)碼管鬧鐘.zip
(165.79 KB, 下載次數(shù): 33)
2020-6-15 08:13 上傳
點(diǎn)擊文件名下載附件
文檔 下載積分: 黑幣 -5
