查看: 4458|回復(fù): 0
數(shù)碼管電子鐘設(shè)計(jì),具有鬧鐘功能(仿真+源程序)分享
51單片機(jī)電子鐘設(shè)計(jì),功能如下
1.具有時(shí)間校準(zhǔn)功能;
2.具有鬧鐘功能;
3.可以顯示時(shí)、分、秒;
鬧鐘設(shè)置界面
電子時(shí)鐘系統(tǒng).zip (92.97 KB, 下載次數(shù): 86)
程序如下:
#include  "Key.h"
#include  "led.h"
uchar timeSetBuff[8]={'0','0',LED_MODE_COUNT,'0','0',LED_MODE_COUNT,'0','0'};//時(shí)鐘數(shù)據(jù)緩沖區(qū)
uchar alarmSetBuff[8]={'0','0',LED_MODE_ALARM,'0','0',LED_MODE_ALARM,'0','0'};//鬧鐘時(shí)間數(shù)據(jù)緩沖區(qū)
uchar timeDisMod=0x24;                //00100100
uchar secondTemp,minuteTemp,hourTemp;
uchar secondAlarm,minuteAlarm,hourAlarm;
uchar timer0Temp;
uchar alarmKeyCount;                   //鬧鐘起停鍵計(jì)數(shù)
bit alarm_is_ok;                       //鬧鐘起停狀態(tài)
bit time_is_ok;                        //時(shí)間是否到
bit interface_mod;                     // 顯示界面模式,0為主時(shí)間界面,1為設(shè)置界面
* 函數(shù)名稱:定時(shí)器0
* 功    能:定時(shí)器0初始化
* 入口參數(shù):無
* 出口參數(shù):無
void initTimer0(void)                      //定時(shí)10ms
   TMOD |= 0x01;                        //GATE=0,TR=1運(yùn)行;C/T=1,counter,0,timer;01十六進(jìn)制
   TH0 = 0xdc;
   TL0 = 0x00;
   TR0 = 1;                                  //timer0 控制位,為1時(shí)啟動(dòng)timer0
   ET0 = 1;                             //timer0 中斷使能
* 函數(shù)名稱:時(shí)鐘比較
* 功    能:比較時(shí)鐘和鬧鐘的時(shí)間緩沖區(qū),只比較時(shí)和分
* 入口參數(shù):無
* 出口參數(shù):無
void timeCompare(void)
  if((minuteTemp == minuteAlarm) && (hourTemp == hourAlarm))
     time_is_ok = 1;
         alarm_is_ok = 0;
         interface_mod = 1;
* 函數(shù)名稱:主函數(shù)
* 功    能:調(diào)用并執(zhí)行各個(gè)子函數(shù)
* 入口參數(shù):無
* 出口參數(shù):無
uchar keyRead;
init_led();
init_key();
initTimer0();
timer0Temp = 0x00;
secondTemp = 0x00;
minuteTemp = 0x00;
hourTemp = 0x00;
secondAlarm = 0x00;
minuteAlarm = 0x00;
hourAlarm = 0x00;
alarmKeyCount = 0x02;
alarm_is_ok = 0;     //默認(rèn)狀態(tài)停止
time_is_ok = 0;      //默認(rèn)時(shí)間未到
interface_mod = 0;
sei();
   if(interface_mod == 1)
     ledSweepDisplay(alarmSetBuff,timeDisMod);
     ledSweepDisplay(timeSetBuff,timeDisMod);
   if(alarm_is_ok == 1)
     timeCompare();
   keyRead = get_key_value();
   if(keyRead == KEY_ALARM)
      if(alarm_is_ok == 1 || time_is_ok == 1)
            alarm_is_ok = 0;
                time_is_ok = 0;
                interface_mod = 0;
                alarmKeyCount = 0x00;
                if(alarmKeyCount < 0x02)
                alarmKeyCount++;
                if(alarmKeyCount == 0x01)
                  interface_mod = 1;
                if(alarmKeyCount == 0x02)
                   alarm_is_ok = 1;
                   interface_mod = 0;
   if(keyRead == KEY_SECOND)
   { if(interface_mod == 1)
           if(secondAlarm < 59)
             secondAlarm++;
             secondAlarm = 0x00;
           alarmSetBuff[S_L] = secondAlarm % 10 + '0';
           alarmSetBuff[S_H] = secondAlarm / 10 + '0';
           if(secondTemp < 59)
             secondTemp += 1;
             secondTemp = 0x00;
           timeSetBuff[S_L] = secondTemp % 10 + '0';
       timeSetBuff[S_H] = secondTemp / 10 + '0';
   if(keyRead == KEY_MINUTE)
           if(minuteAlarm < 59)
             minuteAlarm++;
             minuteAlarm=0x00;
           alarmSetBuff[M_L]=minuteAlarm%10+'0';
           alarmSetBuff[M_H]=minuteAlarm/10+'0';
           if(minuteTemp < 59)
             minuteTemp += 1;
             minuteTemp = 0x00;
           timeSetBuff[M_L] = minuteTemp % 10 + '0';
       timeSetBuff[M_H] = minuteTemp / 10 + '0';
  if(keyRead == KEY_HOUR)
           if(hourAlarm < 23)
             hourAlarm++;
             hourAlarm = 0x00;
           alarmSetBuff[H_L] = hourAlarm % 10 + '0';
           alarmSetBuff[H_H] = hourAlarm / 10 + '0';
           if(hourTemp < 23)
             hourTemp += 1;
             hourTemp = 0x00;
           timeSetBuff[H_L] = hourTemp%10+'0';
       timeSetBuff[H_H] = hourTemp/10+'0';
* 函數(shù)名稱:定時(shí)器0中斷函數(shù)
* 功    能:定時(shí)器0溢出中斷入口處,定時(shí)10ms
* 入口參數(shù):無
* 出口參數(shù):無
void timer0_overflow(void) interrupt 1
   TH0 = 0xdc;
   TL0 = 0x00;
   if(time_is_ok == 1)            //報(bào)警
     WARN_TRUMPET = ~WARN_TRUMPET;
   if(timer0Temp < 99)        //判斷1s是否到
       timer0Temp++;
   else                            //進(jìn)中斷100次
        timer0Temp = 0x00;
            if(secondTemp < 59)   //判斷1min是否到
                  secondTemp++;
                  secondTemp = 0x00;
                  if(minuteTemp < 59)  //判斷1hour是否到
                     minuteTemp++;
                    minuteTemp = 0x00;
                        if(hourTemp < 23)
                          hourTemp++;
                          hourTemp = 0x00;
   timeSetBuff[S_L] = secondTemp%10+'0';
   timeSetBuff[S_H] = secondTemp/10+'0';
   timeSetBuff[M_L] = minuteTemp%10+'0';
   timeSetBuff[M_H] = minuteTemp/10+'0';
   sei();
收藏收藏6 分享淘帖 頂 踩
