(1)實(shí)驗(yàn)內(nèi)容:實(shí)現(xiàn)甲單片機(jī)發(fā)送控制命令字符控制乙單片機(jī),乙單片機(jī)根據(jù)所接收到的字符完成LED閃爍。(甲單片機(jī)負(fù)責(zé)向外發(fā)送控制命令字符“A”、 “B”、 “C”,或者停止發(fā)送,乙機(jī)根據(jù)所接收到的字符完成LED1閃爍、LED2閃爍、雙閃爍、或停止閃爍。) (2)實(shí)驗(yàn)步驟:A.在PROTEUS平臺(tái)中畫出原理圖;B.在Keil uVision3軟件平臺(tái)進(jìn)行編程,編譯,生成目標(biāo)文件(.HEX文件); 甲單片機(jī)的程序: #include<reg51.h> #define uchar unsigned char #define uint unsigned int sbit LED1=P0^0; sbit LED2=P0^3; sbit K1=P1^0; void DelayMS(uint ms) { uchar i; while (ms--)for(i=0;i<120;i++); } void Putc_to_SerialPort(uchar c) { SBUF=c; while(TI==0); TI=0; } void main() { uchar Operation_No=0; SCON=0x40; TMOD=0X20; PCON=0x00; TH1=0xfd; TL1=0xfd; TI=0; TR1=1; while(1) {if(K1==1) { while(K1==0); Operation_No=(Operation_No+1)%4; } switch(Operation_No) { case 0:LED1=LED2=1;break; case1:Putc_to_SerialPort('A');LED1=~LED1;LED2=1; break; case 2: Putc_to_SerialPort('B');LED2=~LED2;LED1=1;break; case3:Putc_to_SerialPort('C');LED1=~LED1;LED2=LED1;break; } DelayMS(100); }} 乙單片機(jī)的程序如下: #include<reg51.h> #define uchar unsigned char #define uint unsigned int sbit LED1=P0^0; sbit LED2=P0^3; sbit K1=P1^0; void DelayMS(uint ms) { uchar i; while(ms--)for(i=0;i<120;i++); } void main() { SCON=0x50; TMOD=0X20; PCON=0x00; TH1=0xfd; TL1=0xfd; RI=0; TR1=1; LED1=LED2=1; while(1) {if(RI) {RI=0; switch(SBUF) { case 'A':LED1=~LED1;LED2=1;break; case 'B':LED2=~LED2;LED1=1;break; case 'C': LED1=~LED1;LED2=LED1; }} else LED1=LED2=1; DelayMS(100); }} C.在PROTEUS平臺(tái)中加載目標(biāo)文件并進(jìn)行仿真調(diào)試,若達(dá)不到要求,則要修改程序,反復(fù)調(diào)試,直到成功。
