發(fā)現(xiàn)論壇里好多都是基于51單片機(jī)設(shè)計(jì)的,分享一下手里關(guān)于STM32的設(shè)計(jì)資料,同時(shí)樓主也在學(xué)習(xí)相關(guān)知識(shí)
通過(guò)QT 實(shí)現(xiàn)將數(shù)據(jù)傳輸至ARM FSMC至FPGA
- #include "stm32f10x_lib.h"
- #include "usb_lib.h"
- #include "usb_desc.h"
- #include "hw_config.h"
- #include "usb_pwr.h"
- #include "queue.h"
- #include "string.h"
- #include "stdio.h"
- extern u16 count_out;
- extern u8 buffer_out[VIRTUAL_COM_PORT_DATA_SIZE];
- extern u8 buffer_in[VIRTUAL_COM_PORT_DATA_SIZE];
- extern u16 count_in;
- extern u8 USART1_Tx_Char;
- extern void set_fpga(u8 * dat,u16 len);
- extern void rd_fpga(u8 * dat);
- extern void set_flash(u8 * dat,u16 len);
- extern void rd_flash(u8 * dat);
- void usb_send(u8 *buf,u16 len);
- vu8 Flag_UARTSendOver = 1;
- vu8 Flag_USBSendOver=1;
- vu8 Flag_USBDataReceive = 0;
- u8 QueueWriteFull(DataQueue *Buf, QUEUE_DATA_TYPE Data, u8 Mod)
- Mod = Mod;
- //Uart1_PutString("Queue Full\n" , strlen("Queue Full\n"));
- if(!Flag_UARTSendOver)
- USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
- while(!Flag_UARTSendOver);
- if( QUEUE_OK == QueueRead(&USART1_Tx_Char, (void *)buf_usb_to_uart))
- USART_SendData(USART1, USART1_Tx_Char);
- return QueueWrite((void *)Buf, Data); // 數(shù)據(jù)重新入隊(duì)
- void InitQueue(void)
- //初始化USB接收隊(duì)列
- QueueCreate((void *)buf_usb_to_uart,sizeof(buf_usb_to_uart),NULL,(u8 (*)())QueueWriteFull);
- //初始化USB 發(fā)送隊(duì)列
- QueueCreate((void *)buf_uart_to_usb,sizeof(buf_uart_to_usb),NULL,(u8 (*)())QueueWriteFull);
- void usb_recv_proc()
- //usb_send(buffer_out,count_out);
- if(( buffer_out[0] == 's')&&(buffer_out[1] == 'f'))
- set_fpga(&buffer_out[2],count_out);
- else if(( buffer_out[0] == 'r')&&(buffer_out[1] == 'f'))
- rd_fpga(&buffer_out[2]);
- else if(( buffer_out[0] == 'f')&&(buffer_out[1] == 's'))
- set_flash(&buffer_out[2],count_out);
- else if(( buffer_out[0] == 'f')&&(buffer_out[1] == 'r'))
- rd_flash(&buffer_out[2]);
- void usb_recv_chk()
- if(Flag_USBDataReceive)
- count_out = GetEPRxCount(ENDP3); //獲得接收到的數(shù)據(jù)長(zhǎng)度
- PMAToUserBufferCopy(buffer_out, ENDP3_RXADDR, count_out); //將數(shù)據(jù)從USB EP3 RX的緩沖區(qū)拷貝到用戶(hù)指定的數(shù)組中
- usb_recv_proc();
- SetEPRxValid(ENDP3); //完成拷貝后置有效狀態(tài),從而EP3發(fā)送ACK主機(jī)可以進(jìn)行下一個(gè)數(shù)據(jù)包的發(fā)送
- Flag_USBDataReceive=0;
- void usb_send_chk()
- u16 i,count,recvCount;
- u8 temp;
- if(Flag_USBSendOver)
- Flag_USBSendOver=0;
- recvCount=0;
- count = QueueNData((void *)buf_uart_to_usb);
- if( count > 64 )
- for(i=0;i<64;i++)
- if( QUEUE_OK == QueueRead(&temp, (void *)buf_uart_to_usb) )
- buffer_in[recvCount++] = temp;
- UserToPMABufferCopy(buffer_in, ENDP1_TXADDR, recvCount);
- SetEPTxCount(ENDP1,recvCount);
- SetEPTxValid(ENDP1);
- else
- for(i=0;i<count;i++)
- while(len--)
- QueueWrite((void *)buf_uart_to_usb,*(buf++));
- extern void my_dac_init();
- extern void pwm_init();
- int main(void)
- Set_System();
- USB_Cable_Config(DISABLE);
- InitQueue();
- Set_USBClock();
- USB_Interrupts_Config();
- USB_Init();
- pwm_init();
- //my_dac_init();
- while (1)
- if ( bDeviceState == CONFIGURED )
- usb_recv_chk();
- usb_send_chk();
- #ifdef DEBUG
- void assert_failed(u8* file, u32 line)
- /* Infinite loop */
- while (1)
- #endif
- //不使用半主機(jī)模式
- #if 1 //如果沒(méi)有這段,則需要在target選項(xiàng)中選擇使用USE microLIB
- #pragma import(__use_no_semihosting)
- struct __FILE
- int handle;
- FILE __stdout;
- _sys_exit(int x)
- x = x;
- #endif
- int fputc(int ch, FILE *f)
- QueueWrite((void *)buf_uart_to_usb,ch);
- return ch;
- /******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
MyUSB.7z
(1.17 MB, 下載次數(shù): 18)
2020-6-20 03:11 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
