- #include<reg51.h>
- #include "string.h"
- #include "stdio.h"
- #include "math.h"
- #include <INTRINS.H>
- #define uchar unsigned char
- #define uint unsigned int
- uchar a ,b ,time; //聲明變量
- sbit wei1=P0^0; //關(guān)鍵字
- sbit wei2=P0^1;
- sbit key0= P0^2;
- sbit key1= P0^3;
- sbit key2= P0^4;
- bit dao=0; //定義位變量dao(倒計時)=0
- uchar code table[]={0x40,0x4f,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x18}; //段碼表
- void Delay5ms() //@12MHz
- unsigned char i, j;
- i =9;
- j = 255;
- do //循環(huán)指令
- while (--j);
- while (--i); //循環(huán)
- Delay5ms(); //延時
- main()
- TMOD=0X01; //工作方式1
- TH0=(65535-50000)/256; //賦予初值
- TL0=(65535-50000)%256;
- EA=1; //允許中斷
- ET0=1; //允許外部中斷1
- while(1)
- if(key0==0) //啟動
- Delay5ms(); //延時消抖
- if(key0==0)
- while(!key0); //暫停/繼續(xù)
- TR0=~TR0; //TR0取反
- YUI(key2==0)
- if(key2==0) //復(fù)位
- while(!key2);
- time=0;
- TR0=0; //停止T0計數(shù)
- wei1=0;
- P2=table[a]; //P2接口接到table[a]
- wei2=0;
- P3=table;
- if(key1==0)
- Delay5ms();
- if(key1==0)
- while(!key1);
- dao=~dao ; //取反,反向計時
- Delay5ms();
- a=time/10; //手動賦初值
- b=time%10;
- void TIME0()interrupt 1 //定時器0中斷
- uchar i;
- TH0=(65535-50000)/256; //初值高8位
- TL0=(65535-50000)%256; //初值低8位
- i++;
- if(i>20)
- {if(dao==0) //若倒計時為0
- time++; //計時正向(加)
- else
- if(time==0) //若時間為0
- { //正向倒向均為0
- time=0;
- TR0=0;
- dao=0;
- else
- time--; //計時反向(減)
- if(time>=59)
- time=59; //計數(shù)到59
- dao=1;
- TR0=0;
- a=time/10; //賦予初值
- b=time%10;
- i=0;
