查看: 4259|回復(fù): 3
上位機(jī)聯(lián)合調(diào)試-串口控制LED燈
ID:762492 發(fā)表于 2020-6-17 19:11 | 顯示全部樓層 |閱讀模式
界面
界面
界面設(shè)計(jì):
<Grid>
        <Grid.RowDefinitions>
            <RowDefinition Height="1*"/>
        </Grid.RowDefinitions>
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="1*"/>
        </Grid.ColumnDefinitions>
        <GroupBox x:Name="groupBox" Header="串口設(shè)置" FontSize="18" HorizontalAlignment="Left" VerticalAlignment="Top" Margin="23,33,0,0" Height="261" Grid.RowSpan="3" Width="241" />
        <Label Content="串口" FontSize="18" VerticalAlignment="Center" Width="100" HorizontalAlignment="Center" HorizontalContentAlignment="Right" Margin="23,0.5,137,71" Grid.Row="1" Height="36"/>
        <Label Content="波特率" FontSize="18" VerticalAlignment="Center" HorizontalAlignment="Center" Width="100" Grid.Row="1" HorizontalContentAlignment="Right" Margin="23,55,135,10" Height="42"></Label>
        <ComboBox x:Name="cmbChuanKou" Width="100" Height="30" Margin="148,6,10,71" Grid.Row="1"/>
        <ComboBox x:Name="cmbBaud" Width="100" Height="30" Margin="148,55,10,22" Grid.Row="1"/>
        <Button x:Name="btnOpenSerialPort" FontSize="18" Grid.Row="2" Height="30" Width="100" Content="打開串口" Margin="36,27,122,49" Click="btnOpenSerialPort_Click"></Button>
        <Button x:Name="btnCloseSerialPort" FontSize="18" Grid.Row="2" Height="30" Width="100" Content="關(guān)閉串口" Margin="148,27,10,49" Click="btnCloseSerialPort_Click"></Button>
        <GroupBox x:Name="groupBox1" Header="控制LED" FontSize="18" HorizontalAlignment="Left" VerticalAlignment="Top" Margin="9.5,33,0,0" Height="261" Grid.RowSpan="3" Width="255" Grid.Column="1" />
        <Label Content="請選擇LED" FontSize="18" VerticalAlignment="Center" HorizontalAlignment="Center" RenderTransformOrigin="0.603,0.654" Grid.Column="1" Margin="10,38,142,22" Grid.Row="1" Height="47" Width="107"></Label>
        <ComboBox x:Name="cmbLed" Grid.Column="1" Height="30" Width="100"  Margin="149,38,10,39" Grid.Row="1" ></ComboBox>
        <Button x:Name="btnOpenLed" FontSize="18" Grid.Row="2" Height="30" Width="100" Content="開燈" Grid.Column="1" Margin="17,27,142,49" Click="btnOpenLed_Click"></Button>
        <Button x:Name="btnCloseLed" FontSize="18" Grid.Row="2" Height="30" Width="100" Content="關(guān)燈" Grid.Column="1" Margin="149,27,10,49" Click="btnCloseLed_Click"></Button>
    </Grid>
</Window>
后臺代碼:
  private void Window_Loaded(object sender, RoutedEventArgs e)
            foreach (string s in SerialPort.GetPortNames())
                cmbChuanKou.Items.Add(s);
            List<string> Baud = new List<string>(new string[] { "600", "1200", "2400", "4800", "9600", "14400", "19200", "115200" });
            cmbBaud.ItemsSource = Baud;
            cmbLed.Items.Add("全部");
            for (int i = 1; i < 17; i++)
                cmbLed.Items.Add(string.Format("{0}號燈", i));
            cmbChuanKou.SelectedIndex = 0;
            cmbLed.SelectedIndex = 0;
            cmbBaud.SelectedIndex = 0;
  private void Window_Closing(object sender, System.ComponentModel.CancelEventArgs e)
        private void btnOpenSerialPort_Click(object sender, RoutedEventArgs e)
            mySerialPort.PortName = cmbChuanKou.Text;
            mySerialPort.BaudRate = Convert.ToInt32(cmbBaud.Text);
            try
                mySerialPort.Open();
                btnOpenSerialPort.IsEnabled = false;
                btnCloseSerialPort.IsEnabled = true;
                cmbChuanKou.IsEnabled = false;
                cmbBaud.IsEnabled = false;
            catch
                MessageBox.Show("打開端口出錯(cuò),請檢查串口", "錯(cuò)誤");
        private void btnCloseSerialPort_Click(object sender, RoutedEventArgs e)
            try
                mySerialPort.Close();
                cmbChuanKou.IsEnabled = true;
                cmbBaud.IsEnabled = true;
            catch
        private byte sum(byte[] d)
            byte s = 0;
            for (int i = 0; i < d.Length - 1; i++)
                s += d[ i];[ i]
            return s;
        private void btnOpenLed_Click(object sender, RoutedEventArgs e)
            byte[] data = new byte[5];
            data[0] = 0x55;
            data[1] = 0xaa;
            data[2] = (byte)cmbLed.SelectedIndex;
            data[3] = 0x00;
            data[4] = sum(data);
            mySerialPort.Write(data, 0, 5);
        private void btnCloseLed_Click(object sender, RoutedEventArgs e)
            data[0] = 0x55;
            data[1] = 0xaa;
            data[3] = 0xFF;
聯(lián)合調(diào)試-LED.zip
73.18 KB, 下載次數(shù): 42, 下載積分: 黑幣 -5
ID:885725 發(fā)表于 2021-2-23 15:47 | 顯示全部樓層
這是利用單片機(jī)做下位機(jī)實(shí)現(xiàn)的嗎?有硬件圖嗎?
ID:885725 發(fā)表于 2021-2-26 11:22 | 顯示全部樓層
試了一下,居然能運(yùn)行!請問樓主,程序現(xiàn)在控制的是P0口,怎樣修改成控制P1口呢?
ID:885725 發(fā)表于 2021-3-3 10:00 | 顯示全部樓層
請問以上程序運(yùn)行后,串口模擬輸入1時(shí)顯示的是6,輸入2時(shí)顯示亂碼,請見附件顯示圖片。該怎樣解決顯示不正確的這個(gè)問題呢?
無效樓層,該帖已經(jīng)被刪除
