查看: 8904|回復(fù): 4
PIC18f4520單片機(jī)驅(qū)動(dòng)H1632的C語(yǔ)言程序
ID:50658 發(fā)表于 2013-6-12 23:25 | 顯示全部樓層 |閱讀模式
基于PIC18f4520單片機(jī)驅(qū)動(dòng)H1632C語(yǔ)言程序:
#include<p18f4520.h>
#include <delays.h>
//#pragma config OSC = HS //配置內(nèi)部振蕩器Fosc/4 RA7,IO口RA7
//#pragma config PWRT =OFF
//#pragma config BOREN = OFF
//#pragma config WDT = OFF
//#pragma config MCLRE = ON
//#pragma config PBADEN = OFF
//#pragma config LVP = OFF
#define CLK PORTCbits.RC3
#define DAT PORTCbits.RC5
#define CS1 PORTDbits.RD0
//#define CS1 PORTCbits.RC0
//#define CS2 PORTDbits.RD1
//#define CS3 PORTDbits.RD2
//#define CS4 PORTDbits.RD3
#define KEY PORTBbits.RB0
//#define KEY PORTAbits.RA4
void init_command(unsigned int command_data); /nd commad data to HT1632
void set2416(void);
//initialize HT1632
void MCU_Data_0832(unsigned char Data1,unsigned char Data2); /nd 16 bits
data to HT1632 once
void MCU_Address_2416(unsigned char address); /nd address to 1632's RAM
void senddata1(void); /nd data to HT1632(1st screen)to display information
void delay(void);
void KeyJudgement(void);
unsigned char KeyLast,KeyNow;//Record the state of key
unsigned char KeyCounter;
KeyNow=KEY;
if((KeyNow==0)&&(KeyLast==1))
Delay100TCYx(10);//Delay 2ms
KeyNow=KEY;
if(KeyNow==0)
KeyCounter++;
if(KeyCounter==6)
KeyCounter=0;
KeyLast=KeyNow;
void delay(void)
unsigned char i,j;
for(i=0;i<200;i++)
j++;
unsigned int i,j;
command_data=command_data&0xfff;
command_data=command_data<<4;
CS1=1;
CS1=0;
for(i=0;i<12;i++)
CLK=0;
j=command_data&0x8000;
command_data=command_data<<1;
j=j>>15;
DAT=j;
CLK=1;
CS1=1;
//CS2=1;
//CS3=1;
//CS4=1;
void set2416(void)
//sys en
init_command(0b100000000010);
//led on
init_command(0b100000000110);
//blink on
// init_command(0b100000010010);
//master mode
init_command(0b100000101110);
//RC
init_command(0b100000110110);
//commons option
//init_command(0b100001011110);//2416
init_command(0b100001010110);//0832
//pwm duty
init_command(0b100101111110);
unsigned char i,j,databuffer;
for(j=0;j<4;j++)
databuffer=Data1;
for(i=0 ; i<8 ; i++)
CLK=0; //clk = 0 for data ready
if(databuffer & 0x80)
DAT=1;
DAT=0;
CLK=1; //clk = 1 for data write into 2
databuffer=databuffer<<1;
databuffer=Data2;
DAT=1;
DAT=0;
unsigned char i,temp;
temp = 0x40; //address has 7 bits. MSB fisrt
for(i=0;i<7;i++)
CLK= 0; //clk = 0 for data ready
if((temp & address) == 0)
DAT= 0;
DAT= 1;
CLK= 1; //clk = 1 for data write into
1632
temp >>= 1;
unsigned char i,data1,data2;
CS1=1;
delay();
CS1=0;
delay();
CLK=0;
DAT=1;
CLK=1;
CLK=0;
DAT=0;
CLK=1;
CLK=0;
DAT=1;
CLK=1;
MCU_Address_2416(0x00);
switch (KeyCounter)
case 0:{
data1=0x00;
data2=0x00;
}break;
case 1:{
data1=0xaa;
data2=0xaa;
}break;
case 2:{
data1=0x55;
data2=0x55;
}break;
case 3:{
data1=0xff;
data2=0x00;
}break;
case 4:{
data1=0x00;
data2=0xff;
}break;
Page 30832Test
case 5:{
data1=0xff;
data2=0xff;
}break;
for(i=0;i<4;i++)
MCU_Data_0832(data1,data2);
delay();
CS1=1;
void main(void)
unsigned char CounterShallow;
TRISCbits.TRISC3=0;
TRISCbits.TRISC5=0;
TRISDbits.TRISD0=0;
//TRISCbits.TRISC0=0;
TRISDbits.TRISD1=0;
TRISDbits.TRISD2=0;
//TRISAbits.TRISA4=1;
TRISBbits.TRISB0=1;
KeyLast=1;
KeyNow=1;
KeyCounter=0;
CounterShallow=1;
set2416();
delay();
KeyJudgement();
if(CounterShallow!=KeyCounter)
senddata1();
CounterShallow=KeyCounter;
Delay1KTCYx(100);//Keep from intervals
ID:96072 發(fā)表于 2015-11-25 09:46 | 顯示全部樓層
不錯(cuò),學(xué)習(xí)了
ID:98168 發(fā)表于 2015-12-3 15:46 | 顯示全部樓層
不錯(cuò),謝謝分享
ID:33634 發(fā)表于 2016-8-30 20:22 | 顯示全部樓層
不錯(cuò),謝謝分享。
