查看: 7505|回復(fù): 1
PIC單片機(jī)控制數(shù)碼管顯示4*4矩陣鍵盤對應(yīng)按鍵號
ID:50658 發(fā)表于 2013-6-12 23:28 | 顯示全部樓層 |閱讀模式
;使用C口作鍵盤掃描,7段數(shù)碼管顯示按鍵號 ,63系列通用寄存器地址:20~7FH, A0~FFH ,未達(dá)到預(yù)期目的,只用個位數(shù)顯示按鍵號時正常工作,增加按鍵號轉(zhuǎn)換(用2位數(shù)顯示),則提示“STACK OVERFLOW"--堆棧溢出.編譯后機(jī)器碼容量為1.3KB左右,未超過CALL跳轉(zhuǎn)范圍——1頁(2K) 。
#include P16C63A.INC
KEYCODE EQU  H'0020'
KEYNUM  EQU  H'0021'
CC    EQU  H'0024'
TABADD EQU H'0025'
SW   EQU H'0026'
GW   EQU H'0027'
;PD   EQU H'0028'
ORG H'0000'
GOTO MAIN
ORG H'0010'
MAIN  MOVLW H'00'
      TRIS PORTA
      TRIS PORTB ;RB口全為輸出,用作驅(qū)動7段數(shù)碼管
      MOVWF KEYNUM
      MOVLW H'F0'
      TRIS PORTC ;  設(shè)置RC低四位為輸出,高四位為輸入
      MOVLW TABLE
      MOVWF TABADD
      MOVLW H'0001'
;      MOVWF PD   ;用來判斷按鍵號是否大于9
LOOP
      CALL KEYSCAN
   ;   CALL JUDGE     ;判斷是按鍵號是否大于9
   ;   XORLW H'0001'
   ;   BTFSS STATUS,Z
       CALL XIAO
   ;   GOTO DASHU
XS    CALL DISP_2
      GOTO LOOP    ;循環(huán)掃描、顯示按鍵號
JUDGE
      MOVLW H'0A'
      SUBWF KEYNUM,0
      BTFSC STATUS,0  ; C標(biāo)志
   ;   RETLW 0  ;小于10
   ;   RETLW 1  ; 10以上的按鍵號
      GOTO XIAO
      GOTO DASHU
XIAO  MOVLW 0
      MOVWF SW
      MOVF KEYNUM,0
      MOVWF GW
      RETLW 0
     ; GOTO XS
DASHU
      MOVLW H'01'
      MOVWF SW
      MOVLW H'0A'
      SUBWF KEYNUM,0
      MOVWF GW
      RETLW 0
     ; GOTO XS
DISP_2
      MOVLW H'02'
      MOVWF PORTA
      MOVF SW,0
      CALL DISP
      CALL DELAY
      MOVLW H'01'
      MOVWF PORTA
      MOVF GW,0
      CALL DISP
      CALL DELAY
      RETLW 0
DELAY MOVLW 0
      MOVWF CC
LL    DECFSZ CC,1
      GOTO LL
      RETLW 0
DISP  ; MOVF KEYNUM,0                    ;輸入W,輸出W
      ADDWF TABADD,0
      CALL CONV
      MOVWF PORTB
      RETLW 0
CONV  MOVWF PCL   ;取碼,輸入W(0~F),輸出W
TABLE RETLW H'C0'
      RETLW H'F9'
      RETLW H'A4'
      RETLW H'B0'
      RETLW H'99'
      RETLW H'92'
      RETLW H'82'
      RETLW H'F8'
      RETLW H'80'
      RETLW H'90'
      RETLW H'88'
      RETLW H'83'
      RETLW H'C6'
      RETLW H'A1'
      RETLW H'86'
      RETLW H'8E'    ;0~F 數(shù)碼管代碼
      RETLW H'C0'
KEYSCAN  MOVLW H'FE'  ;第一行置低(RC0輸出0)
         MOVWF PORTC
         NOP
         MOVF PORTC,0 ;讀RC各端口狀態(tài)
         ANDLW H'F0' ;屏蔽低四位,只需要低四位來判斷
         MOVWF KEYCODE ;保存端口狀態(tài)
         MOVLW H'F0'
         SUBWF KEYCODE,0 ;與初值比較,看是否有鍵按下
         BTFSS STATUS,Z  ;有鍵按下(不等于初值,Z為零)則結(jié)束掃描
         GOTO  GETNUM1
         MOVLW H'FD'  ;第二行置低(RC1輸出0)
         MOVWF PORTC
         NOP
         MOVF PORTC,0 ;讀RC各端口值
         MOVLW H'F0'
         GOTO  GETNUM2
         MOVLW H'FB'  ;第三行置低(RC2輸出0)
         MOVWF PORTC
         NOP
         MOVLW H'F0'
         GOTO  GETNUM3
         MOVLW H'F7'  ;第四行置低(RC3輸出0)
         MOVWF PORTC
         NOP
         MOVLW H'F0'
         GOTO  GETNUM4
FH       RETLW  0    ; 子程序返回
QUDOU    MOVF PORTC,0  ;去抖處理
         SUBWF KEYCODE,0
         BTFSC STATUS,Z
         GOTO QUDOU
         GOTO FH
