查看: 7726|回復(fù): 0
單片機(jī)浮點(diǎn)數(shù)運(yùn)算實(shí)現(xiàn)
ID:50658 發(fā)表于 2013-6-12 23:32 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
單片機(jī)浮點(diǎn)數(shù)運(yùn)算實(shí)現(xiàn):浮點(diǎn)數(shù)顯示子函數(shù)和顯示十進(jìn)制尾數(shù)和階的子函數(shù)。
(1)浮點(diǎn)數(shù)顯示子函數(shù)。
函數(shù)名稱: void DispF(float f)
功能 :用科學(xué)記數(shù)法顯示浮點(diǎn)數(shù),在float全范圍內(nèi)精確顯示,超出范圍給出提示。
說(shuō)明 :浮點(diǎn)數(shù)表示范圍為+-1.175494E-38到+-3.402823E+38
入口參數(shù):f為要顯示的浮點(diǎn)數(shù)
返回值 :無(wú)
void DispF(float f)
      float  tf, b;
      unsigned long w, tw;
      char i, j;
      if(f<0)
        PrintChar(’-’);
        f=-1.0*f;
     if(f<1.175494E-38)
         printf("?.??????");   //太小了,超出了最小范圍。
         return;
     if(f>1E35)            //f>10^35
        tf=f/1E35;
        b=1000.0;
        for(i=0,j=38;i<4;i++,j--)
if(tf/b<1)
            b=b/10.0;
break;
          w=f/(1E29*b);      //1E35*b/1E6
          PrintW(w,j);
     else if(f>1E28)
        tf=f/1E28;
        b=1E7;
        for(i=0,j=35;i<8;i++,j--)
if(tf/b<1)
             b=b/10.0;
   break;
           w=f/(1E22*b);     //1E28*b/1E6
           PrintW(w,j);
      else if(f>1E21)
         tf=f/1E21;
         b=1E7;
         for(i=0,j=28;i<8;i++,j--)
if(tf/b<1)
b=b/10.0;
break;
          w=f/(1E15*b);      //1E21*b/1E6
          PrintW(w,j);
      else if(f>1E14)
         tf=f/1E14;
         b=1E7;
         for(i=0,j=21;i<8;i++,j--)
if(tf/b<1)
            b=b/10.0;
break;
          w=f/(1E8*b);       //1E14*b/1E6
          PrintW(w,j);
      else if(f>1E7)
         tf=f/1E7;
         b=1E7;
         for(i=0,j=14;i<8;i++,j--)
if(tf/b<1)
b=b/10.0;
break;
            w=f/(10.0*b);      //1E28*b/1E6
            PrintW(w,j);
      else if(f>1)
          tf=f;
          b=1E7;
          for(i=0,j=7;i<8;i++,j--)
          if(tf/b<1)
            b=b/10.0;
break;
          w=f/(1E-6*b);       //1E0*b/1E6
          PrintW(w,j);
      else if(f>1E-7)
         tf=f*1E7;           //10^-7
         b=1E7;
         for(i=0,j=0;i<8;i++,j--)
if(tf/b<1)
b=b/10.0;
break;
            w=f*(1E13/b);     //(1E7/b)*1E6
            PrintW(w,j);
       else if(f>1E-14)
           tf=f*1E14;        //10^-14
           b=1E7;
           for(i=0,j=-7;i<8;i++,j--)
if(tf/b<1)
b=b/10.0;
break;
            w=f*(1E20/b);    //(1E14/b)*1E6
            PrintW(w,j);
       else if(f>1E-21)
           tf=f*1E21;       //10^-21
           b=1E7;
           for(i=0,j=-14;i<8;i++,j--)
if(tf/b<1)
b=b/10.0;
break;
              w=f*(1E27/b);    //(1E21/b)*1E6
              PrintW(w,j);
        else if(f>1E-28)
             tf=f*1E28;            //10^-28
             b=1E7;
             for(i=0,j=-21;i<8;i++,j--)
if(tf/b<1)
b=b/10.0;
break;
                w=f*(1E34/b);      //(1E28/b)*1E6
                PrintW(w,j);
         else if(f>1E-35)
             tf=f*1E35;             //10^-35
             b=1E7;
             for(i=0,j=-28;i<8;i++,j--)
if(tf/b<1)
b=b/10.0;
break;
                 w=f*(1E35/b)*1E6;   //(1E35/b)*1E6
                 PrintW(w,j);
            tf=f*1E38;                 //f<=10^-35
            b=1000.0;
            for(i=0,j=-35;i<4;i++,j--)
if(tf/b<1)
b=b/10.0;
break;
               w=f*(1E38/b)*1E6;      //(1E38/b)*1E6
               PrintW(w,j);
(2)顯示十進(jìn)制尾數(shù)和階的子函數(shù)。
函數(shù)名稱: void PrintW(unsigned long w,char j)
功能 :科學(xué)記數(shù)法,顯示十進(jìn)制尾數(shù)和階碼
入口參數(shù):w為尾數(shù),j為階碼
返回值 :無(wú)
        char i;
        unsigned long tw,b;
        if(j<-38)                //太小了,超出最小表數(shù)范圍。
           printf("?.??????");
           return;
if(j>38)                   //此算法不會(huì)出現(xiàn)j>38的情況
           printf("*.******");
           return;
tw=w/1000000;
       PrintChar(tw+’0’);
       PrintChar(’-’);
       w=w-tw*1000000;
       b=100000;
       for(i=0;i<6;i++)
          tw=w/b;
          PrintChar(tw+’0’);
          w=w-tw*b;
          b=b/10;
      printf("E%d",(int)j);
