基于51單片機的自動澆花系統(tǒng),可自設(shè)濕度閾值。
帶有溫濕度監(jiān)測功能,可借鑒學(xué)習(xí)。
2020-6-21 23:14 上傳
2020-6-21 23:14 上傳
2020-6-21 23:14 上傳
單片機源程序如下:
- #include <reg52.h>
- #include <intrins.h>
- #define uchar unsigned char //宏定義
- #define uint unsigned int
- #include"eeprom.h"
- typedef unsigned char unint8;
- typedef unsigned char unint16;
- typedef unsigned int U16;
- uchar code table[] = {"moisture: "};
- uchar code table1[] ={" "};
- uchar code table3[] ={" H: % H: C "};
- uchar code table2[] ={"Set The: "};
- sbit TRH = P1^4;//溫濕度傳感器DHT11數(shù)據(jù)接入
- sbit rs = P2^6;
- sbit en = P2^7;
- sbit beep=P2^0;//蜂鳴器控制端
- sbit k1=P3^1;
- sbit k2=P3^2;
- sbit k3=P3^3;
- sbit jdq=P3^4;
- sbit CS = P1^0;
- sbit Clk = P1^1;
- sbit DATI = P1^2;
- sbit DATO = P1^2;
- uchar stemp=35,shr=50,tr=80; //溫濕度上下線初始化
- bit yyp=1,lalarm=0; //設(shè)置標(biāo)志位,報警標(biāo)志位
- int key_delay=0;
- const int key_count=400;
- unsigned char dat = 0x00;
- unsigned char CH;
- uchar s1num,num,shis,shig,wens,weng;
- unint8 TH_data,TL_data,RH_data,RL_data,CK_data;
- unint8 TH_temp,TL_temp,RH_temp,RL_temp,CK_temp;
- unint8 com_data,untemp,temp;
- unint8 respond;
- void delay(uint x) //毫秒級延時函數(shù)
- uint i,j;
- for(i=x;i>0;i--)
- for(j=110;j>0;j--);
- void di() //蜂鳴器報警
- beep=0;
- delay(100);
- beep=1;
- void write_com(uchar com)
- rs=0;//命令
- P0=com;
- delay(5);
- en=1;
- delay(5);
- en=0;
- void write_date(uchar date)
- rs=1;//數(shù)據(jù)
- P0=date;
- delay(5);
- en=1;
- delay(5);
- en=0;
- void init1602()
- write_com(0x38); //設(shè)置工作方式
- write_com(0x0c); //設(shè)置光標(biāo)
- write_com(0x06); //設(shè)置輸入方式
- write_com(0x01); //清屏
- write_com(0x80);
- for(num=0;num<16;num++)
- write_date(table[num]);
- write_com(0x80+0x40);
- write_date(table1[num]);
- void init16021() //設(shè)置溫度上下限顯示初始化函數(shù)
- write_com(0x80);
- write_date(table2[num]);
- write_date(table3[num]);
- write_com(0x80+0x40+13);
- write_date(0xdf);
- void write_H(uchar add,uchar date)
- uchar shi,ge;
- shi=date/10;
- ge=date%10;
- write_com(0x80+0x40+add);
- write_date(0x30+shi);
- write_date(0x30+ge);
- void write_tr(uchar add,uchar Data)
- uchar bai,shi,ge;
- bai=Data/100;
- shi=Data/10%10;
- ge=Data%10;
- write_com(0x80+add);
- write_date(0X30+bai);
- write_date(0X30+shi);
- write_date(0X30+ge);
- /***********DHT11子程序*************************/
- // 毫秒級延時子程序
- void delay_ms(U16 j)
- { unint8 i;
- for(;j>0;j--)
- for(i=0;i<27;i++);
- //5us級延時程序
- void delay_us()
- unint8 i;
- i--;
- i--;
- i--;
- i--;
- i--;
- i--;
- //收發(fā)信號檢測,數(shù)據(jù)讀取
- char receive()
- unint8 i;
- for(i=0;i<8;i++)
- respond=2;
- while((!TRH)&&respond++);
- delay_us();
- delay_us();
- delay_us();
- temp=0;
- if(TRH)temp=1;
- respond=2;
- while((TRH)&&respond++);
- //超時則跳出for循環(huán)
- if(respond==1)break;
- //判斷數(shù)據(jù)位是0還是1
- // 如果高電平高過預(yù)定0高電平值則數(shù)據(jù)位為 1
- com_data<<=1;
- com_data|=temp;
- return(com_data);
- //濕度讀取子程序
- //溫度高8位== TL_data
- //溫度低8位== TH_data
- //濕度高8位== RH_data
- //濕度低8位== RH_data
- //校驗 8位 == CK_data
- //調(diào)用的程序有 delay();, Delay_5us();,RECEIVE();
- void GET_TRH()
- //主機拉低18ms
- TRH=0;
- delay_ms(180);
- TRH=1;
- //DATA總線由上拉電阻拉高 主機延時20us
- delay_us();
- delay_us();
- delay_us();
- delay_us();
- //主機設(shè)為輸入 判斷從機響應(yīng)信號
- TRH=1;
- //判斷DHT11是否有低電平響應(yīng)信號 如不響應(yīng)則跳出,響應(yīng)則向下運行
- if(!TRH)
- respond=2;
- //判斷DHT11發(fā)出 80us 的低電平響應(yīng)信號是否結(jié)束
- while((!TRH)&& respond++);
- respond=2;
- //判斷從機是否發(fā)出 80us 的高電平,如發(fā)出則進(jìn)入數(shù)據(jù)接收狀態(tài)
- while(TRH && respond++);
- //數(shù)據(jù)接收狀態(tài)
- RH_temp = receive();
- RL_temp = receive();
- TH_temp = receive();
- TL_temp = receive();
- CK_temp = receive();
- TRH=1;//ST=1;
- //數(shù)據(jù)校驗
- untemp=(RH_temp+RL_temp+TH_temp+TL_temp);
- if(untemp==CK_temp)
- RH_data = RH_temp;
- RL_data = RL_temp;
- TH_data = TH_temp;
- TL_data = TL_temp;
- CK_data = CK_temp;
- //濕度整數(shù)部分
- shis= (char)(0X30+RH_data/10); //濕度的十位
- shig= (char)(0X30+RH_data%10); //濕度的個
- //溫度整數(shù)部分
- wens= (char)(0X30+TH_data/10); //溫度的十位
- weng= (char)(0X30+TH_data%10); //溫度的個位
- //濕度整數(shù)部分
- //溫度整數(shù)部分
- //溫濕度顯示函數(shù)
- write_com(0x80+0x40+2);
- write_date(shis);
- write_date(shig);
- write_date('%'); //濕度符號
- write_com(0x80+0x40+9);
- write_date(wens);
- write_date(weng);
- write_date(0xdf); //溫度符號
- write_date('C');
- /****按鍵掃描******/
- void keyscan()
- if(k1==0)
- delay(10);
- if(k1==0)
- s1num++;
- while(!k1); //等待按鍵釋放
- yyp=0;
- di();
- switch(s1num)
- case 1: init16021(); //設(shè)置溫度上下限初始化
- tr=byte_read(0x2000);
- shr=byte_read(0x2200);
- stemp=byte_read(0x2400);
- write_tr(9,tr);
- write_H(3,shr);
- write_H(11,stemp);
- write_com(0x80+11);
- write_com(0x0f); //打開光標(biāo)
- break;
- case 2: write_com(0X40+0x80+4);
- break;
- case 3: write_com(0X40+0x80+12);
- break;
- case 4: s1num=0;
- write_com(0x0c); //關(guān)閉光標(biāo)
- yyp=1;
- init1602(); //上電后顯示初始化
- break;
- if(s1num!=0)
- if(k2==0)
- delay(10);
- if(k2==0)
- while(!k2); //等待按鍵釋放
- di();
- switch(s1num)
- case 1: tr++;
- if(tr==255)tr=0;
- write_tr(9,tr);
- SectorErase(0x2000);//擦除扇區(qū)
- byte_write(0x2000,tr);//重新寫入數(shù)據(jù)
- break;
- case 2: shr++;
- if(shr==85)shr=0;
- write_H(3,shr);
- write_com(0X40+0x80+4);
- SectorErase(0x2200);//擦除扇區(qū)
- byte_write(0x2200,shr);//重新寫入數(shù)據(jù)
- break;
- case 3: stemp++;
- if(stemp==45)stemp=0;
- write_com(0X40+0x80+12);
- SectorErase(0x2400);//擦除扇區(qū)
- byte_write(0x2400,stemp);//重新寫入數(shù)據(jù)
- break;
- if(k3==0)
- delay(10);
- if(k3==0)
- while(!k3); //等待按鍵釋放
- di();
- switch(s1num)
- case 1: tr--;
- if(tr==0)tr=255;
- write_tr(9,tr);
- break;
- case 2: shr--;
- if(shr==0)shr=85;
- write_H(3,shr);
- break;
- case 3: stemp--;
- if(stemp==0)stemp=45;
- break;
- unsigned char adc0832(unsigned char CH)
- unsigned char i,test,adval;
- adval = 0x00;
- test = 0x00;
- Clk = 0; //初始化
- DATI = 1;
- _nop_();
- CS = 0;
- _nop_();
- Clk = 1;
- _nop_();
- if ( CH == 0x00 ) //通道選擇
- Clk = 0;
- DATI = 1; //通道0的第一位
- _nop_();
- Clk = 1;
- _nop_();
- Clk = 0;
- DATI = 0; //通道0的第二位
- _nop_();
- Clk = 1;
- _nop_();
- else
- Clk = 0;
- DATI = 1; //通道1的第一位
- _nop_();
- Clk = 1;
- _nop_();
- Clk = 0;
- DATI = 1; //通道1的第二位
- _nop_();
- Clk = 1;
- _nop_();
- Clk = 0;
- DATI = 1;
- for( i = 0;i < 8;i++ ) //讀取前8位的值
- _nop_();
- adval <<= 1;
- Clk = 1;
- _nop_();
- Clk = 0;
- if (DATO)
- adval |= 0x01;
- else
- adval |= 0x00;
- for (i = 0; i < 8; i++) //讀取后8位的值
- test >>= 1;
- if (DATO)
- test |= 0x80;
- else
- test |= 0x00;
- _nop_();
- Clk = 1;
- _nop_();
- Clk = 0;
- if (adval == test) //比較前8位與后8位的值,如果不相同舍去。若一直出現(xiàn)顯示為零,請將該行去掉
- dat = test;
- _nop_();
- CS = 1; //釋放ADC0832
- DATO = 1;
- Clk = 1;
- return dat;
- void display(uchar Data)
- uchar bai,shi,ge;
- bai=Data/100;
- shi=Data/10%10;
- ge=Data%10;
- write_com(0x80+9);
- void baojing()
- if(TH_data>stemp||RH_data>shr)//判斷溫濕度
- lalarm=1;
- if(RH_data>shr) // 報警
- if(TH_data>stemp) // 報警
自動澆花系統(tǒng)+溫濕度監(jiān)測.zip
(762.24 KB, 下載次數(shù): 147)
2020-6-21 23:14 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
