查看: 1605|回復(fù): 0
用PROTEUS仿真單片機串口通訊
ID:788784 發(fā)表于 2020-6-24 16:19 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
設(shè)計要求:
實現(xiàn)與Proteus中的8051單片機進行串行通信。先回顧一下串行通信。在串行通信中有兩個引腳分別稱為TXRX。TX引腳用于發(fā)送數(shù)據(jù),而RX引腳用于接收數(shù)據(jù)。
8051微控制器具有這兩個引腳,因此它支持串行通信,并且這些引腳位于AT89C52微控制器的10號和11號引腳上。
首先,將對此項目進行原理圖設(shè)計(如下圖),在端口1上連接8LED,并通過串行端口發(fā)送字符來打開或關(guān)閉這些LED。設(shè)計完原理圖之后,我們將為8051微控制器設(shè)計編程代碼,并測試結(jié)果。
#include <reg52.h>
#define Baud_rate 0xFD // BAUD RATE 9600
void SerialInitialize(void);
void SendByteSerially(unsigned char);
void cct_init(void);
sbit Appliance1 = P1^0;
sbit Appliance2 = P1^1;
sbit Appliance3 = P1^2;
sbit Appliance4 = P1^3;
sbit Appliance5 = P1^4;
sbit Appliance6 = P1^5;
sbit Appliance7 = P1^6;
sbit Appliance8 = P1^7;
cct_init();
SerialInitialize();
EA = 1;
ES = 1;
while(1) {;}
void cct_init(void) //initialize cct
P0 = 0x00; //not used
P1 = 0x00; //Used for Appliances
P2 = 0x00; //not used
P3 = 0x03; //used for serial
void SerialInitialize(void) // INITIALIZE SERIAL PORT
TMOD = 0x20;// Timer 1 IN MODE 2 -AUTO RELOAD TO GENERATE BAUD RATE
SCON = 0x50;// SERIAL MODE 1, 8-DATA BIT 1-START BIT, 1-STOP BIT, REN
//ENABLED
TH1 = Baud_rate;// LOAD BAUDRATE TO TIMER REGISTER
TR1 = 1;// START TIMER
void SendByteSerially(unsigned char serialdata)
SBUF = serialdata; // LOAD DATA TO SERIAL BUFFER REGISTER
while(TI == 0);// WAIT UNTIL TRANSMISSION TO COMPLETE
TI = 0;// CLEAR TRANSMISSION INTERRUPT FLAG
void serial_ISR (void) interrupt 4
//receive character
char chr;
if(RI==1)
chr = SBUF;
RI = 0;
P0 = ~P0; //Show the data has been updated
switch(chr)
case '1': Appliance1 = 1; SendByteSerially('k'); break;
case '2': Appliance2 = 1; SendByteSerially('k'); break;
case '3': Appliance3 = 1; SendByteSerially('k');break;
case '4': Appliance4 = 1; SendByteSerially('k'); break;
case '5': Appliance5 = 1; SendByteSerially('k'); break;
case '6': Appliance6 = 1; SendByteSerially('k'); break;
case '7': Appliance7 = 1; SendByteSerially('k'); break;
case '8': Appliance8 = 1; SendByteSerially('k'); break;
case 'a': Appliance1 = 0; SendByteSerially('k'); break;
case 'b':Appliance2 = 0; SendByteSerially('k'); break;
case 'c': Appliance3 = 0; SendByteSerially('k'); break;
case 'd': Appliance4 = 0; SendByteSerially('k'); break;
case 'e': Appliance5 = 0; SendByteSerially('k'); break;
case 'f': Appliance6 = 0; SendByteSerially('k'); break;
case 'g': Appliance7 = 0; SendByteSerially('k'); break;
case 'h': Appliance8 = 0; SendByteSerially('k'); break;
default: ;break; //do nothing
RI = 0;
