查看: 3065|回復(fù): 0
DS2438引腳圖與pdf數(shù)據(jù)手冊下載
ID:447740 發(fā)表于 2020-6-27 10:58 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
DS2438 網(wǎng)上資料特別少,這里上傳一個廠家的數(shù)據(jù)手冊,有很大的參考價值
Functional Diagrams
DESCRIPTION
The DS2438 Smart Battery Monitor provides several functions that are desirable to carry in a battery
pack: a means of tagging a battery pack with a unique serial number, a direct-to-digital temperature
sensor which eliminates the need for thermistors in  the battery pack, an A/D converter which measures
the battery voltage and current, an integrated current accumulator which keeps a running total of all
current going into and out of the battery, an elapsed time meter, and 40 bytes of nonvolatile EEPROM
memory for storage of important parameters such  as battery chemistry, battery capacity, charging
methodology and assembly date.  Information is sent to/from the DS2438 over a 1-Wire interface, so that
only one wire (and ground) needs to be connected from a central microprocessor to a DS2438.  This
means that battery packs need only have three output connectors: battery power, ground, and the 1-Wire
interface.
引腳圖:
DS2438.pdf
381.66 KB, 下載次數(shù): 4, 下載積分: 黑幣 -5
admin + 50 共享資料的黑幣獎勵!
