查看: 3328|回復: 2
這是基于srtm32驅動步進電機Proteus仿真程序,有興趣朋友可以了解下
ID:259898 發(fā)表于 2020-6-27 19:00 | 顯示全部樓層 |閱讀模式
這是基于srtm32驅動步進電機,有興趣朋友可以了解下
單片機源程序如下:
  1. #include "main.h"
  2. #include "stm32f1xx_hal.h"
  3. TIM_HandleTypeDef htim1;
  4. void LcdDelay(uint32_t time)
  5. {
  6.         while(time--);
  7. }
  8. void _NOP_(void)
  9. {
  10.     uint32_t i = 100;
  11.     while(i > 0)
  12.                 {
  13.         i--;
  14.     }
  15. }
  16. void Delay(__IO uint32_t nCount)
  17. {
  18.         for(; nCount != 0; nCount--);
  19. }
  20. void delay_us(__IO uint32_t nTime)
  21. {
  22.     int old_val, new_val, val;
  23.     if(nTime > 900)
  24.     {
  25.         for(old_val = 0; old_val < nTime/900; old_val++)
  26.         {
  27.             delay_us(900);
  28.         }
  29.         nTime = nTime%900;
  30.     }
  31.     old_val = SysTick->VAL;
  32.     new_val = old_val - 72*nTime;
  33.     if(new_val >= 0)
  34.     {
  35.         do
  36.         {
  37.             val = SysTick->VAL;
  38.         }
  39.         while((val < old_val)&&(val >= new_val));
  40.     }
  41.     else
  42.     {
  43.         new_val +=72*1000;
  44.         do
  45.         {
  46.             val = SysTick->VAL;
  47.         }
  48.         while((val <= old_val)||(val > new_val));
  49.     }
  50. }
  51. void SystemClock_Config(void)
  52. {
  53.   RCC_OscInitTypeDef RCC_OscInitStruct;
  54.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  55.   /* Initializes the CPU, AHB and APB busses clocks */
  56.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  57.   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  58.   RCC_OscInitStruct.HSICalibrationValue = 16;
  59.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  60.         HAL_RCC_OscConfig(&RCC_OscInitStruct);
  61.
  62.     /* Initializes the CPU, AHB and APB busses clocks */
  63.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  64.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  65.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  66.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  67.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  68.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  69.         HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0);
  70.     /* Configure the Systick interrupt time */
  71.   //HAL_SYSTICK_Config( HAL_RCC_GetHCLKFreq()/1000 );
  72.         SysTick_Config(HAL_RCC_GetHCLKFreq()/1000);
  73.   // SysTick_Config(72000000/1000);
  74.                 /* Configure the Systick  */
  75.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  76.   /* SysTick_IRQn interrupt configuration */
  77.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  78. }
  79. static void MX_GPIO_Init(void)
  80. {
  81.   GPIO_InitTypeDef GPIO_InitStruct;
  82.   __HAL_RCC_GPIOA_CLK_ENABLE();
  83.         __HAL_RCC_GPIOB_CLK_ENABLE();
  84.   __HAL_RCC_GPIOC_CLK_ENABLE();
  85.         HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2, GPIO_PIN_SET);
  86.   GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2;
  87.   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  88.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  89.   HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  90.
  91.         HAL_GPIO_WritePin(GPIOC, GPIO_PIN_13, GPIO_PIN_SET);
  92.         GPIO_InitStruct.Pin = GPIO_PIN_All;
  93.         HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  94. }
  95. /* TIM1 init function */
  96. static void MX_TIM1_Init(void)
  97. {
  98.   TIM_ClockConfigTypeDef sClockSourceConfig;
  99.   TIM_MasterConfigTypeDef sMasterConfig;
  100.   htim1.Instance = TIM1;
  101.   htim1.Init.Prescaler = 0;
  102.   htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
  103.   htim1.Init.Period = 0;
  104.   htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  105.   htim1.Init.RepetitionCounter = 0;
  106.   HAL_TIM_Base_Init(&htim1);
  107.
  108.   sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  109.   HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig);
  110.
  111.   sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  112.   sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  113.   HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig);
  114. }
  115. #define Delay_ms(x) Delay_us(1000*x)         //單位ms
  116. #define uchar unsigned char
  117. #define uint unsigned int
  118. uchar fan[] = {0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01};                                                //正向
  119. uchar zheng[] = {0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09};                                        //反向
  120. int main(void)
  121. ……………………
  122. …………限于本文篇幅 余下代碼請從51黑下載附件…………
復制代碼
STM32_控制步進電機.7z (1.14 MB, 下載次數(shù): 62)
admin + 50 共享資料的黑幣獎勵!
ID:774108 發(fā)表于 2020-7-2 15:02 來自觸屏版 | 顯示全部樓層
有人試過嗎
ID:774108 發(fā)表于 2020-7-3 11:50 來自觸屏版 | 顯示全部樓層
有沒有用標準寫的代碼
Powered by 單片機教程網
