2020-6-28 18:21 上傳
- #include <reg51.h>
- #include <intrins.h>
- #include <ctype.h> /* isdigit()函數(shù) */
- #include <stdlib.h> /* atoi()函數(shù) */
- #define uchar unsigned char
- #define uint unsigned int
- uchar operand1[9], operand2[9]; /* 操作數(shù) */
- uchar operator; /* 操作符 */
- void delay(uint);
- uchar keyscan();
- void disp(void);
- void buf(uint value);
- uint compute(uint va1,uint va2,uchar optor);
- uchar code table[] = {0xc0,0xf9,0xa4,0xb0,0x99,
- 0x92,0x82,0xf8,0x80,0x90,0xff}; /* 字符碼表 */
- uchar dbuf[8] = {10,10,10,10,10,10,10,10}; /* 顯示緩存 */
- /* 延時函數(shù) */
- void delay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- uchar keyscan()
- uchar skey; /* 按鍵值標(biāo)記變量 */
- P1 = 0xfe;
- while((P1 & 0xf0) != 0xf0) /* 有按鍵按下 */
- delay(3); /* 去抖動延時 */
- while((P1 & 0xf0) != 0xf0) /* 仍有鍵按下 */
- switch(P1) /* 識別按鍵并賦值 */
- case 0xee: skey = '7'; break;
- case 0xde: skey = '8'; break;
- case 0xbe: skey = '9'; break;
- case 0x7e: skey = '/'; break;
- default: skey = '#';
- while((P1 & 0xf0) != 0xf0) /* 等待按鍵松開 */
- P1 = 0xfd;
- delay(3);
- switch(P1)
- case 0xed: skey = '4'; break;
- case 0xdd: skey = '5'; break;
- case 0xbd: skey = '6'; break;
- case 0x7d: skey = '*'; break;
- P1 = 0xfb;
- delay(3);
- switch(P1)
- case 0xeb: skey = '1'; break;
- case 0xdb: skey = '2'; break;
- case 0xbb: skey = '3'; break;
- case 0x7b: skey = '-'; break;
- P1 = 0xf7;
- delay(3);
- switch(P1)
- case 0xe7: skey = '
- ; break;
- case 0xd7: skey = '0'; break;
- case 0xb7: skey = '='; break;
- case 0x77: skey = '+'; break;
- return skey;
- void main()
- uint value1, value2, value; /* 數(shù)值1,數(shù)值2,結(jié)果 */
- uchar ckey, cut1 = 0, cut2 = 0; /* ckey鍵盤輸入字符 */
- uchar operator; /* 運算符 */
- uchar i, bool = 0;
- init: /* goto語句定位標(biāo)簽 */
- buf(0); /* 初始化 */
- disp();
- value = 0;
- cut1 = cut2 = 0;
- bool = 0;
- for(i = 0;i < 9;i++)
- operand1[i] = '\0';
- operand2[i] = '\0';
- } /* 初始化 */
- while(1)
- ckey = keyscan(); /* 讀取鍵盤 */
- if(ckey != '#')
- { /* isdigit函數(shù),字符是阿拉伯?dāng)?shù)字返回非0值,否則返回0 */
- if(isdigit(ckey))
- switch(bool)
- case 0:
- operand1[cut1] = ckey;
- operand1[cut1+1] = '\0';
- value1 = atoi(operand1);
- cut1++;
- buf(value1);
- disp();
- break;
- case 1:
- operand2[cut2] = ckey;
- operand2[cut2+1] = '\0';
- value2 = atoi(operand2);
- cut2++;
- buf(value2);
- disp();
- break;
- default: break;
- else if(ckey=='+'||ckey=='-'||ckey=='*'||ckey=='/')
- bool = 1;
- operator = ckey;
- buf(0);
- dbuf[7] = 10;
- disp();
- else if(ckey == '=')
- value = compute(value1,value2,operator);
- buf(value);
- disp();
- while(1)
- ckey = keyscan();
- if(ckey == '
- ) /* 如果有清零鍵按下跳轉(zhuǎn)到開始 */
- goto init;
- else
- buf(value);
- disp();
- else if(ckey == '
- { goto init;}
- disp();
- uint value;
- switch(optor)
- case '+' : value = va1+va2; break;
- case '-' : value = va1-va2; break;
- case '*' : value = va1*va2; break;
- case '/' : value = va1/va2; break;
- default : break;
- return value;
- void buf(uint val)
- uchar i;
- if(val == 0)
- dbuf[7] = 0;
- i = 6;
- else
- for(i = 7; val > 0; i--)
- dbuf[i] = val % 10;
- val /= 10;
- for( ; i > 0; i--)
- dbuf[i] = 10;
- void disp(void)
- uchar bsel, n;
- bsel=0x01;
- for(n=0;n<8;n++)
- P2=bsel;
- P0=table[dbuf[n]];
- bsel=_crol_(bsel,1);
- delay(3);
- P0=0xff;
復(fù)制代碼 |
附件.zip
2020-6-28 18:21 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
56.46 KB, 下載次數(shù): 2, 下載積分: 黑幣 -5
