查看: 1544|回復(fù): 0
單片機(jī)超聲波測(cè)距代碼
#include "reg52.H"//器件配置文件
#include"lcd.h"
//傳感器接口
sbit RX  = P3^2;
sbit TX  = P3^3;
sbit key  = P1^4;
char keymode=0;
int keycount=0;
//變量聲明
unsigned int  time=0;
unsigned int  timer=0;
unsigned char posit=0;
unsigned long S=0;
char Mode=0;
bit  flag=0;
bit flag_KEY=0;
unsigned char act[]={0xff,0xfa,0xf5,0xf9,0xf6};          //小車(chē)動(dòng)作控制
unsigned char disbuff[4]           ={0,0,0,0};                 //數(shù)組用于存放距離信息
void Display();
//延時(shí)20ms(不精確)
void delay_ms(unsigned int m)
    unsigned int b,c;
    for(c=0;c<m;c++)
        for(b=0;b<120;b++);
void Key(void)
        key = 1;
        delay_ms(1);
        if(key==0)                  //檢測(cè)按鍵K1是否按下           開(kāi)關(guān)
                        delay_ms(10);   //消除抖動(dòng) 一般大約10ms
                        if(key==0)         //再次判斷按鍵是否按下
                                keymode++;
                                if(keymode == 2)keymode = 0;
                        while(!key);         //檢測(cè)按鍵是否松開(kāi)
        if(keymode==1)
                keycount++;
                if(keycount==8)
                        keycount=0;
                        keymode=0;
void Conut(void)
        time=TH0*256+TL0;          //讀出T0的計(jì)時(shí)數(shù)值
        TH0=0;
        TL0=0;                                  //清空計(jì)時(shí)器
        S=(time*1.7)/100;     //算出來(lái)是CM
        //聲音的速度是340m/s,時(shí)間的單位是us,計(jì)算到秒需要將時(shí)間數(shù)據(jù)/1000000,
        //長(zhǎng)度=速度*時(shí)間,340*time/1000000,長(zhǎng)度數(shù)據(jù)單位是m轉(zhuǎn)換成cm需要乘以100得到340*time/10000,
        //小數(shù)點(diǎn)都向左移兩位得到3.4*time/100,因?yàn)槌暡ㄊ峭盗,所以再除?,得到距離數(shù)據(jù)(time*1.7)/100
        if(Mode==0)                          //非設(shè)置狀態(tài)時(shí)
                if(S>=800) //超出測(cè)量范圍顯示“-”
                        disbuff[0]='o'-0x30;           //“-”
                        disbuff[1]='v'-0x30;           //“-”
                        disbuff[2]='e'-0x30;           //“-”
                        disbuff[3]='r'-0x30;           //“-”
                        disbuff[0]=S%1000/100;                 //將距離數(shù)據(jù)拆成單個(gè)位賦值
                        disbuff[1]=S%100/10;
                        disbuff[2]='.'-0x30;
                        disbuff[3]=S%10;
void delay(unsigned int t)
        while(t--);
//定時(shí)器0
void zd0() interrupt 1                  //T0中斷用來(lái)計(jì)數(shù)器溢出,超過(guò)測(cè)距范圍
        flag=1;                                                 //中斷溢出標(biāo)志
//定時(shí)器1
void zd3() interrupt 3                  //T1中斷用來(lái)掃描數(shù)碼管和計(jì)800MS啟動(dòng)模塊
        char n=10;
        P1 = 0xff;delay(7);
        TH1=0xf8;
        TL1=0x30;                                 //定時(shí)2ms
        timer++;                                //變量加
        if(timer>=400)                        //1次就是40ms
                timer=0;
                TX=1;                                  //40MS  啟動(dòng)一次模塊
                while(n--);
                TX=0;
                SBUF=S/256;//將接收到的數(shù)據(jù)放入到發(fā)送寄存器
                while(!TI);                         //等待發(fā)送數(shù)據(jù)完成
                TI=0;                                                 //清除發(fā)送完成標(biāo)志位
                SBUF=S%256;//將接收到的數(shù)據(jù)放入到發(fā)送寄存器
        P1 = act[keymode];                //掃描顯示
void UsartInit()
        SCON=0X50;                        //設(shè)置為工作方式1
        TMOD=0X20;                        //設(shè)置計(jì)數(shù)器工作方式2
        PCON=0X80;                        //波特率加倍
        TH1=0XF3;                                //計(jì)數(shù)器初始值設(shè)置,注意波特率是4800的
        TL1=0XF3;
        ES=1;                                                //打開(kāi)接收中斷
        EA=1;                                                //打開(kāi)總中斷
        TR1=1;                                        //打開(kāi)計(jì)數(shù)器
//主函數(shù)
void main(void)
        TMOD=0x11;                   //設(shè)T0為方式1
        TH0=0;
        TL0=0;
        TH1=0xf8;                   //2MS定時(shí)
        TL1=0x30;
        ET0=1;                                //允許T0中斷
        ET1=1;                           //允許T1中斷
        TR1=1;                           //開(kāi)啟定時(shí)器
        EA=1;                                        //開(kāi)啟總中斷
        UsartInit();                                //串口初始化 9600
        LcdInit();
                while(!RX);                //當(dāng)上次接收完波后,RX引腳是低電平,取反就是1,此while成立,反復(fù)判斷RX狀態(tài)。當(dāng)RX沒(méi)有接收到返回波時(shí)是高電平,取反就是0,此while不成立,跳出
                TR0=1;                        //開(kāi)啟計(jì)數(shù)
                while(RX);                //當(dāng)RX沒(méi)有接收到返回波,此while成立,程序停在這里一直判斷RX狀態(tài)。當(dāng)RX接收到返回波,RX引腳變?yōu)榈碗娖,此while不成立,跳出
                TR0=0;                        //停止計(jì)數(shù)
                Conut();                        //計(jì)算
                LcdWriteCom(0x80);
                LcdWritestr("distance:");                //液晶顯示距離
                LcdWriteData(disbuff[0]+0x30);
                LcdWriteData(disbuff[1]+0x30);
                LcdWriteData(disbuff[2]+0x30);
                LcdWriteData(disbuff[3]+0x30);
                LcdWritestr("cm");
                Key();
void Usart() interrupt 4
        RI = 0;//清除接收中斷標(biāo)志位
