查看: 3562|回復(fù): 0
51單片機(jī)兩個(gè)按鍵及串口控制燈Proteus仿真程序
ID:762492 發(fā)表于 2020-7-2 14:34 | 顯示全部樓層 |閱讀模式
51單片機(jī)實(shí)現(xiàn)小燈按鍵串口精準(zhǔn)亮滅,五種亮燈方式,共28個(gè)小燈。
8個(gè)小精準(zhǔn)閃爍,8個(gè)小燈五種方式亮滅,串口按鍵都可控。
  1. #include <AT89X52.h>
  2. #include <init.h>
  3. void DelayMs(unsigned int n);
  4. unsigned char LedState=0;
  5. void main()
  6. {
  7.
  8.         unsigned char j;
  9.         Timer_Init(0,2,250);
  10.         Uart_Init(1200);
  11.         EXTI_Init(0);
  12.         EXTI_Init(1);
  13.
  14.         SBUF='A';
  15.         DelayMs(1000);
  16.         SBUF='*';
  17.         DelayMs(1000);
  18.         SBUF='6';
  19.         DelayMs(1000);
  20.
  21.         IT0= 1 ;
  22.         EX0= 1 ;
  23.         EA= 1 ;
  24.         PX0= 0 ;
  25.
  26.
  27.         IT1= 1 ;
  28.         EX1= 1 ;
  29.         EA= 1 ;
  30.         PX1= 0 ;
  31.
  32.         while(1)
  33.         {
  34.                         if(P1_0==0)
  35.                         {
  36.                                 DelayMs(10);
  37.                                 while(P1_0==0)
  38.                                 DelayMs(10);
  39.                                 LedState=(LedState+1)%5;
  40.                         }
  41.                         else if(P1_1==0)
  42.                         {
  43.                                 DelayMs(10);
  44.                                 while(P1_0==0)
  45.                                 DelayMs(10);
  46.                                 LedState=(LedState+5-1)%5;
  47.                         }
  48.                         if(LedState==0)
  49.                         {
  50.                                 ////閃爍
  51.                         P2=0x00;
  52.                         DelayMs(100);
  53.                         P2=0xFF;
  54.                         DelayMs(100);
  55.                         }
  56.                         else if(LedState==1)
  57.                         {
  58.                                 ////流水燈上
  59.                         P2=0xFF;
  60.                         for(j=0;j<8;j++)
  61.                                         {
  62.                                                 P2=~(1<<(7-j));;
  63.                                                 DelayMs(100);
  64.                                         }
  65.                                 for(j=0;j<8;j++)
  66.                                 {
  67.                                                 P2=P2|(1<<(7-j));
  68.                                                 DelayMs(100);
  69.                                 }
  70.                         }
  71.                         else if(LedState==2)
  72.                         {
  73.                                 //流水燈下
  74.                                 P2=0xFF;
  75.                                 for(j=0;j<8;j++)
  76.                                 {
  77.                                         P2=P2&(~(1<<j));
  78.                                         DelayMs(100);
  79.                                 }
  80.                                 for(j=0;j<8;j++)
  81.                                 {
  82.                                         ////跑馬燈上
  83.                                                 P2=P2|(1<<j);
  84.                                                 DelayMs(100);
  85.                                 }
  86.                         }
  87.                         else if(LedState==3)
  88.                         {
  89.                                 for(j=0;j<8;j++)
  90.                                 {
  91.                                         P2=~(1<<(7-j));
  92.                                         DelayMs(100);
  93.                                 }
  94.                         }
  95.                         else if(LedState==4)
  96.                         {
  97.         //跑馬燈下
  98.                                 for(j=0;j<8;j++)
  99.                                 {
  100.                                         P2=~(1<<j);
  101.                                         DelayMs(100);
  102.                                 }
  103.                         }
  104.         }
  105. }
  106. void INP_0(void) interrupt 0
  107. {
  108.         LedState=(LedState+1)%5;
  109. }
  110. //定時(shí)器方法
  111. void INP_1(void) interrupt 2
  112. {
  113.         LedState=(LedState+5-1)%5;
  114. }
  115. void INTT0(void) interrupt 1
  116. {
  117.                 static unsigned int times=0;
  118.
  119.                 times++;
  120.                 if(times>=4000)
  121.                 {
  122.                         times=0;
  123.                         P0=~P0;
  124.                 }
  125. }
  126. //串口初始化
  127. void INTS(void) interrupt 4
  128. {
  129.                 if(TI==1)
  130.                 {
  131.                         TI=0;
  132.                 }
  133.                 if(RI==1)
  134.                 {
  135.                         RI=0;
  136.                         LedState=SBUF-'0';
  137.                 }
  138. }
  139. //函數(shù)定義
  140. void DelayMs(unsigned int n)
  141. {
  142.   static unsigned int i;
  143.   while(n--)
  144.   {
  145.     for(i=0;i<89;i++);
  146.   }
  147. }
51單片機(jī)兩個(gè)按鍵及串口控制燈.zip (96.63 KB, 下載次數(shù): 24)
