查看: 3546|回復(fù): 0
單片機(jī)89c52時(shí)鐘程序+3個(gè)按鍵 注釋非常詳細(xì)
ID:740383 發(fā)表于 2020-7-3 15:54 | 顯示全部樓層 |閱讀模式
三個(gè)按鍵:
key0 //調(diào)整鍵--模式
key1//加1鍵
key2//減1鍵
#include  <reg51.h>
uchar code tab[12]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0xbf};
//共陽(yáng)極數(shù)碼管顯示"0~9","滅"和"-"的字段碼
//uchar code tab[]={0x3f,0x06,05b,0x4f,0x66,0x6d,07d,0x07,0x7f,0x6f,0x00,0x40};//共陰數(shù)碼管
uchar code wetab[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};  //位選
uchar data dis[8]={0x00,0x00,0x0b,0x00,0x00,0x0b,0x00,0x00};
//顯示數(shù)據(jù)緩沖區(qū),時(shí)十、個(gè)位、分十、個(gè)位、秒十、個(gè)位初始為0,0x0b為"-"編碼
uchar data timedat[3]={0x00,0x00,0x00};  //分別為秒、分和小時(shí)的計(jì)數(shù)值(記錄K1和K2次數(shù))
uchar data  ms50=0x00, num=0x00,  n1=0x00,  n2=0x00;
//定義定時(shí)次數(shù)變量,調(diào)整模式變量,按加1鍵次數(shù)變量,按減1鍵次數(shù)變量
sbit  key0=P1^0 ;  //調(diào)整鍵--模式
sbit  key1=P1^1 ;  //加1鍵
sbit  key2=P1^2 ;  //減1鍵
void  delay1ms( unsigned  int  z )  //定義延時(shí)1ms函數(shù)
{ unsigned  int  x, y ;
for  ( x=z;  x>0;  x-- )
                for  ( y=120; y>0 ;  y-- )        ;
//按鍵處理函數(shù)。如果沒(méi)有按鍵則時(shí)鐘正常走時(shí)。當(dāng)按K0鍵1次→暫停走時(shí)進(jìn)入調(diào)小時(shí)狀態(tài);再按K0鍵1次→進(jìn)入調(diào)分鐘狀態(tài);再按K0鍵1次→回到正常走時(shí)狀態(tài)。對(duì)于K1和K2鍵,如果正常走時(shí)下→按K1K2鍵不起作用;如果進(jìn)入調(diào)時(shí)或者調(diào)分狀態(tài)→按K1鍵可對(duì)時(shí)或分加1操作,小時(shí)加到24則回0,分鐘加到60則回0。按K2鍵可對(duì)時(shí)或分減1操作,小時(shí)減到負(fù)則回23,分鐘減到負(fù)則回59。
void keyscan(  void )
{        EA=0;  //關(guān)中斷
        if(timedat[0]==0&timedat[1]==0&timedat[2]==7)  {P1=0xff;}
if (key0==0)         { delay1ms(10);         while (key0==0);
                        num++; TR0=0; ET0=0;  // 調(diào)整鍵K0每按1次--模式變量num加1
                        if (num>=3)         {num=0;  ET0=1;  TR0=1;  }  // 啟動(dòng)T0校時(shí)
                if (num!=0)        //模式變量不等于0
{        if (key1==0)        // K1鍵確實(shí)按下
         {        delay1ms(10);         while (key1==0);           timedat[num]++;  //記錄按鍵K1按下次數(shù)
                                if (num==2) n1=24;  else n1=60;                //模式變量等于小時(shí)2--則回遲到一天或60分鐘
if (timedat[num]>=n1)          { timedat[num]=0; }          }
                if (num!=0)
                 {        if (key2==0)
{        delay1ms(10);        while (key2==0);                 timedat[num]--;  //記錄按鍵K2按下次數(shù)
                                if (num==2) n2=23;else n2=59;
                                if (timedat[num]<=0)                  {timedat[num]=n2; }          }
                 EA=1;
//數(shù)碼管顯示函數(shù)。時(shí)間顯示先秒個(gè)位計(jì)算顯示→秒十位計(jì)算顯示→再分個(gè)位計(jì)算顯示→分十位顯示→再時(shí)個(gè)位計(jì)算顯示→時(shí)十位顯示。
         void  display( void )
        {          uchar k;
                 dis[0]=timedat[0]%10;  dis[1]=timedat[0]/10;   //秒
dis[3]=timedat[1]%10;  dis[4]=timedat[1]/10;  //分
dis[6]=timedat[2]%10;  dis[7]=timedat[2]/10;  //時(shí)
for ( k=0;  k<8;  k++ )
                        {         P0=tab[ dis[k] ];  P2=wetab[k];    delay1ms(1);     P2=0x00;         }
//主函數(shù),時(shí)間顯示先秒個(gè)位計(jì)算顯示,然后是秒十位計(jì)算顯示;再就是分個(gè)位計(jì)算顯示,然后是分十位顯示;再就是時(shí)個(gè)位計(jì)算顯示,然后是時(shí)十位顯示。定時(shí)器中斷先檢測(cè)1秒是否到→1秒如果到則秒單元加1;1秒如果沒(méi)到就檢測(cè)1分鐘是否到→1分鐘如果到則分單元加1;如果沒(méi)到就檢測(cè)1小時(shí)是否到→1小時(shí)如果到則時(shí)單元加1;如果沒(méi)到→則顯示時(shí)間。
         void main( void )
        {   TMOD=0x01;   //T0定時(shí)50ms,方式1
                EA=1;  ET0=1;  TR0=1;  //開(kāi)中斷,允許T0中斷,啟動(dòng)T0
                TH0=0x3c;  TL0=0xb0;
                while (1)
                        {         display( ) ;
                                keyscan( ) ;
//定時(shí)器/計(jì)數(shù)器T0中斷服務(wù)函數(shù)。定時(shí)器中斷先檢測(cè)1秒是否到→1秒如果到則秒單元加1;1秒如果沒(méi)到就檢測(cè)1分鐘是否到→1分鐘如果到則分單元加1;如果沒(méi)到就檢測(cè)1小時(shí)是否到→1小時(shí)如果到則時(shí)單元加1;如果沒(méi)到→則顯示時(shí)間。
  void  timer0(void)  interrupt  1
{ ET0=0; TR0=0;   //不許T0中斷也不啟動(dòng)
TH0=0x3c;  TL0=0xb0;
TR0=1;  //啟動(dòng)T0
ms50++;
P1=0xf7;
if (ms50==20)         {        ms50=0x00;  timedat[0]++;  //變量m回0,且秒加1
                if (timedat[0]==60)          {         timedat[0]=0;timedat[1]++;  //秒到60后回0,且分加1
                        if (timedat[1]==60)         {         timedat[1]=0;timedat[2]++;  //分到60后回0,且時(shí)加1
                                if (timedat[2]==24)         {         timedat[2]=0;         }         }        }  //時(shí)到24后回0
        ET0=1;   //允許T0中斷
全部資料51hei下載地址:
shumaguanshizho時(shí)鐘.zip (81.22 KB, 下載次數(shù): 42)
