自己根據(jù)MQTT協(xié)議報文在STM32上成功運行。
2020-7-3 22:40 上傳
單片機源程序如下:
- /* USER CODE END Header */
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "tim.h"
- #include "usart.h"
- #include "gpio.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- #include "string.h"
- #include "xianshispi.h"
- #include "MQTT_8266.H"
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* 大于printf重定向 */
- uint8_t USART1_TX_BUF[200];
- #define u1_printf(...) HAL_UART_Transmit(&huart1,USART1_TX_BUF,sprintf((char *)USART1_TX_BUF,__VA_ARGS__),0xffff)
- uint8_t USART2_TX_BUF[200];
- #define u2_printf(...) HAL_UART_Transmit(&huart2,USART2_TX_BUF,sprintf((char *)USART2_TX_BUF,__VA_ARGS__),0xffff)
- /* esp8266加入的WIFI(熱點)名稱和密碼 */
- #define WIFI_Name "EnHahaha7"
- #define WIFI_Key "hjj1234567890"
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- uint8_t Uart2_RX_Buf,WIFI_IP[15];
- uint8_t num,Buf[150],time;
- extern uint8_t Connect_Flag;
- extern uint16_t MQTT_PING_Time; //PING報文計數(shù)變量
- uint8_t PING_Flag;
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- /* USER CODE BEGIN PFP */
- /* 連接WIFI程序 */
- void ESP_Connect_WIFI()
- char *Start;
- char *End;
- u1_printf("正在連接WIFI...\r\n");
- u2_printf("AT\r\n"); //測試AT啟動
- HAL_Delay(300);
- u2_printf("AT+CWMODE=1\r\n"); //設(shè)置esp8266 STA模式
- HAL_Delay(300);
- u2_printf("AT+CWJAP_CUR=\"%s\",\"%s\"\r\n",WIFI_Name,WIFI_Key); //臨時接入WIFI(熱點)
- HAL_Delay(11000);
- u2_printf("AT+CIFSR\r\n"); //獲取IP地址
- HAL_Delay(300);
- if(strstr((char *)Buf,"\"") != NULL) //軟檢測到IP地址,OLED顯示IP地址
- //顯示IP地址
- OLED_ShowString(0,0,"IP:",1);
- Start = strstr((char *)Buf,"\"") + 1;
- End = strstr(Start,"\"");
- memcpy(WIFI_IP,Start,End - Start);
- WIFI_IP[End - Start] = '\0';
- OLED_ShowString(0,2,WIFI_IP,1);
- //串口1打印熱點名、IP地址
- u1_printf("WIFI Name:%s\nWIFI IP:%s\r\n",WIFI_Name,WIFI_IP);
- else u1_printf("WIFI連接失敗");
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval int
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_USART1_UART_Init();
- MX_USART2_UART_Init();
- MX_TIM1_Init();
- /* USER CODE BEGIN 2 */
- HAL_UART_Receive_IT(&huart2,&Uart2_RX_Buf,1); //開啟串口2接收中斷
- HAL_TIM_Base_Start_IT(&htim1); //開啟T1中斷
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- OLED_Init(); //OLED初始化
- ESP_Connect_WIFI(); //ESP8266連接WIFI,并顯示在OLED
- Connect_Sever(); //TCP連接服務(wù)器
- MQTT_Conect(); //連接云平臺
- MQTT_SUBSCRIBE(); //訂閱主題
- // MQTT_PUBLISH("HJJ"); //發(fā)送消息
- while (1)
- if(PING_Flag == 1)
- PING_Flag=0;
- MQTT_PING(); //發(fā)送心跳包
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- /**Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI_DIV2;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL16;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN 4 */
- void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)//串口接收中斷回調(diào)函數(shù)
- if(huart == &huart2)
- HAL_UART_Receive_IT(&huart2,&Uart2_RX_Buf,1);//開啟串口2接收中斷
- Buf[num] = Uart2_RX_Buf;//將串口2接收到的數(shù)據(jù)存入Buf緩存區(qū)
- num++;time=0;
- //uint8_t i;
- void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)//定時器中斷回調(diào)函數(shù)
- time++;
- if(time>=20 && num>0)
- Buf[num] = '\0';
- MQTT_RxData((char *)Buf,num); //判斷串口2接收到的數(shù)據(jù)
- // for(i=0;i<num;i++) u1_printf("%c",Buf[i]); //串口1打印串口2接收的數(shù)據(jù)
- time=0;num=0;
- if(Connect_Flag == 1) //只有在連接了云平臺且訂閱了主題才需要發(fā)送PING報文
- MQTT_PING_Time++; //每隔10S發(fā)送一次心跳包,防止服務(wù)器將客戶端踢走
- if(MQTT_PING_Time >= 40000)
- PING_Flag=1;
- MQTT_PING_Time=0;
- /* USER CODE END 4 */
MQTT_Demo.7z
(4.18 MB, 下載次數(shù): 122)
2020-7-3 22:40 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
