下面是主程序:
#include <config.h>
//外部函數(shù)
//-------------------delay.c--------------------------------
extern void delay(unsigned int delay_time); //延時子程序
//------------------LPH7366.c--------------------------------
#define COM 0 //指令
#define DAT 1 //數(shù)據(jù)
#define STR 1 //字符
extern void LPH7366_init(); //LPH7366初始化
extern void LPH7366_flash(unsigned int delay_time); //LPH7366閃屏函數(shù)
extern void LPH7366_write(unsigned char type,unsigned char in_data); //LPH7366寫函數(shù)
extern void LPH7366_clr(); //顯示屏幕清屏
extern void LPH7366_write_str(unsigned char line,unsigned char row,unsigned char str);
extern void LPH7366_write_han(unsigned char symbol_line,unsigned char symbol_row,unsigned char han);
extern void LPH7366_write_doc(unsigned char symbol_line,unsigned char symbol_row,unsigned char doc);
extern void data_tick(unsigned char i_data); //數(shù)據(jù)拆分函數(shù)
extern unsigned char row(unsigned char stye,unsigned char i); //計算屏幕的列地址 類型
extern unsigned char ge,shi; //數(shù)據(jù)拆分
extern bit data_flag; //是否動態(tài)顯示數(shù)據(jù)標(biāo)志位 0:不動態(tài) 1:動態(tài)
//------------------------time.c--------------------------------
extern void time_init(); //時間初始化
extern struct time
unsigned char hour;
unsigned char minute;
unsigned char second;
}local_time,alarm_time,temp_time;
extern bit second_flag; //秒信號標(biāo)志
//------------------------溫度圖.c------------------------------
extern void pic_temp(); //溫度主畫面
extern void pic_temp_face_move(); //臉部表情選擇
extern unsigned char face_flag; //人臉表情標(biāo)志位 1:笑臉 2:閉嘴 3:苦惱 4:講話 5:傷心 6:驚訝 7:沉默
//-------------DS18B20.C-------------------
extern void DS18B20_init(); //DS18B20初始化
extern void DS18B20_send(unsigned char in_data); //DS18B20發(fā)送數(shù)據(jù)
extern void ReadTemperature(); //DS18B20讀取溫度轉(zhuǎn)換好的數(shù)據(jù)
extern void temp_data_turn(float in_data); //DS18B20讀取溫度轉(zhuǎn)換
extern bit T_sign; //溫度正負(fù)符號
extern float temp; //轉(zhuǎn)換好的溫度數(shù)值
extern unsigned char t_bai,t_shi,t_ge,t_feng; //溫度轉(zhuǎn)換好的各個位
extern signed char temp_TH,temp_TL;
//------------DS18B20控制命令-----------------------------
#define T_CONVER 0x44 //開始溫度轉(zhuǎn)換
#define T_CONFIG 0x5f //11位轉(zhuǎn)換
#define T_READ 0xbe //讀暫存器
#define T_WRITE 0x4e //寫暫存器
#define T_ROM_JMP 0xcc //忽略64ROM地址
#define T_COPY_E2 0x48 //將溫度上下限數(shù)值寫到E2ROM
#define T_RECALL_E2 0xb8 //將E2中存儲的溫度上下限數(shù)值復(fù)制到上下限寄存器中。
#define T_cont 0.0625 //溫度轉(zhuǎn)換常數(shù)
//---------------keyB.c---------------------------
extern key_main(); //主鍵盤
//內(nèi)部函數(shù)
void time_move(); //時間部分動畫
void temp_move(); //溫度部分動畫
void temp_display(); //溫度顯示
void temp_bar_move(); //溫度條部分動畫
void data_clr(); //行33-58清零函數(shù)
void tick_time_temp(); //檢查設(shè)置參數(shù)
bit sign_cross=0; //正負(fù)符號交叉標(biāo)志位
bit ring_flag=1;
unsigned char alarm_tick_time=0;
sbit LED=P1^5;
sbit SPK=P1^6;
unsigned char temp_bar[]={0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};
LPH7366_init(); //顯示屏幕初始化
LPH7366_clr(); //屏幕白屏
time_init(); //定時器0初始化
pic_temp();
LPH7366_write_str(1,4,'j');
LPH7366_write_str(1,5,'i');
LPH7366_write_str(1,6,'a');
LPH7366_write_str(1,7,'n');
LPH7366_write_str(1,8,'h');
LPH7366_write_str(1,9,'u');
LPH7366_write_str(1,10,'i');
LPH7366_write_han(2,1,0);
LPH7366_write_han(2,2,1);
LPH7366_write_doc(4,25,0x36);
LPH7366_write_doc(4,26,0x36);
while(1) //溫度圖動畫部分
data_flag=1;
pic_temp_face_move(); //人臉表情
key_main(); //主鍵盤
tick_time_temp(); //查詢各個參數(shù)是否到了設(shè)定數(shù)值
if(temp_TL<temp&&temp<temp_TH)
face_flag=1;
void time_move()
data_tick(local_time.hour);
LPH7366_write_str(6,1,(shi+16));
LPH7366_write_str(6,2,(ge+16));
if(second_flag==1)
LPH7366_write_str(6,3,26); //
LPH7366_write_str(6,3,0); //
data_tick(local_time.minute);
LPH7366_write_str(6,4,(shi+16));
LPH7366_write_str(6,5,(ge+16));
if(second_flag==1)
LPH7366_write_str(6,6,26);
LPH7366_write_str(6,6,0); //
data_tick(local_time.second);
LPH7366_write_str(6,7,(shi+16));
LPH7366_write_str(6,8,(ge+16));
if(ring_flag==1)
LPH7366_write_str(6,9,0x00);
LPH7366_write_str(6,10,10);
LPH7366_write_str(6,10,0);
void temp_move()
data_flag=1; //動態(tài)顯示
ReadTemperature(); //讀溫度
temp_data_turn(temp); //轉(zhuǎn)換溫度數(shù)值
temp_display();
void temp_display()
if(T_sign==0) //正數(shù)
if(sign_cross==1)
data_clr();
sign_cross=0;
if(t_bai!=0)
LPH7366_write_str(4,5,(t_bai+16));
LPH7366_write_str(4,6,(t_shi+16));
LPH7366_write_str(4,7,(t_ge+16));
LPH7366_write_doc(4,46,0x01); //C
LPH7366_write_doc(4,47,0x3c);
LPH7366_write_doc(4,48,0x42);
LPH7366_write_doc(4,49,0x42);
LPH7366_write_doc(4,50,0x42);
LPH7366_write_str(4,5,(t_shi+16));
LPH7366_write_str(4,6,(t_ge+16));
LPH7366_write_doc(4,39,0x80); //小數(shù)點(diǎn)
LPH7366_write_str(4,7,(t_feng+16));
else //是負(fù)數(shù)
if(sign_cross==0)
data_clr();
sign_cross=1;
if(t_bai!=0)
LPH7366_write_str(4,5,13); //負(fù)號
LPH7366_write_str(4,6,(t_bai+16));
LPH7366_write_str(4,7,(t_shi+16));
LPH7366_write_str(4,8,(t_ge+16));
LPH7366_write_doc(4,52,0x01); //C
LPH7366_write_doc(4,53,0x3c);
LPH7366_write_doc(4,54,0x42);
LPH7366_write_doc(4,55,0x42);
LPH7366_write_doc(4,56,0x42);
LPH7366_write_doc(4,45,0x80); //小數(shù)點(diǎn)
LPH7366_write_str(4,8,(t_feng+16));
unsigned char k,i,n,j,l;
k=(unsigned char)temp;
i=k/8; //幾行
n=k%8; //幾小行
if(i>=0&&i<=5)
{ if(i>0)
{for(j=5;j>(5-i);j--)
LPH7366_write_doc(j,80,temp_bar[7]); //正行全顯
for(l=1;l<=(5-i);l++) //清除上面不顯示的,主要是為了清楚以前殘留顯示
LPH7366_write_doc(l,80,0x00);
if(n>0) //一行顯示都不到
LPH7366_write_doc((5-i),80,temp_bar[n-1]);
LPH7366_write_doc(1,80,0x04);
void data_clr()
unsigned char i;
for(i=33;i<59;i++)
LPH7366_write_doc(4,i,0x00);
if(ring_flag==1)
{ if(alarm_time.hour==local_time.hour)
if(alarm_time.minute==local_time.minute)
if(local_time.second<30)
SPK=~SPK;
face_flag=4;
SPK=0;
if(temp_time.hour==local_time.hour)
if(temp_time.minute==local_time.minute)
temp_move();
face_flag=7;
if(temp>(temp_TH+0.5))
alarm_tick_time++;
if(alarm_tick_time==10)
alarm_tick_time=0;
LED=0;
face_flag=6;
if(temp<(temp_TL-0.5))
alarm_tick_time++;
alarm_tick_time=0;
LED=~LED;
face_flag=3;
delay(2000);
