打算用max7219驅(qū)動(dòng)點(diǎn)陣顯示時(shí)鐘,但是在max7219驅(qū)動(dòng)中出現(xiàn)問題:
問題描述:第一片和第二片顯示正常,第三篇出現(xiàn)殘影,仔細(xì)觀察第三片的殘影是第一片的數(shù)據(jù)。
檢查過硬件和軟件,硬件應(yīng)該沒有問題,就三根數(shù)據(jù)線,芯片為stc15w408as的IO口直連接動(dòng)三片max7219級(jí)聯(lián),max7219驅(qū)動(dòng)部分程序如下,請(qǐng)各位前輩不膩賜教!
#define _max7219_C
#include "max7219.h"
#include "main.h"
#include "DS3231.h"
#include "DS18B20.h"
#include <intrins.h>
/************************************************************************************************/uchar code disp1[10][8]={
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
{0x10,0x18,0x14,0x10,0x10,0x10,0x10,0x10},//1
{0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2
{0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3
{0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8},//4
{0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,0x0},//5
{0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,0x0},//6
{0x3E,0x22,0x4,0x8,0x8,0x8,0x8,0x8},//7
{0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8
{0x3E,0x22,0x22,0x3E,0x2,0x2,0x2,0x3E},//9
/*n毫秒的延時(shí)程序*/
void Delay_xms(uint x)
uint i,j;
for(i=0;i<x;i++)
for(j=0;j<112;j++);
//向MAX7219寫入字節(jié)
void Write_Max7219_byte(uchar DATA)
uchar i;
Max7219_pinCS=0; //CS=0有效,CS=1鎖存
for(i=8;i>=1;i--)
Max7219_pinCLK=0;
Max7219_pinDIN=DATA&0x80;//&10000000, 編譯器對(duì)位操作的理解:非0即為1
DATA=DATA<<1;
Max7219_pinCLK=1; //上升沿把數(shù)據(jù)送出去
/*向M第一片MAX7219寫入數(shù)據(jù)*/
void Write_Max7219_1(uchar add1,uchar dat1)
Max7219_pinCS=0;
Write_Max7219_byte(add1); //寫入地址,即數(shù)碼管編號(hào)
Write_Max7219_byte(dat1); //寫入數(shù)據(jù),即數(shù)碼管顯示數(shù)字
Max7219_pinCS=1;
/*第二片MAX7219的寫入數(shù)據(jù)*/
void Write_Max7219_2(uchar add2,uchar dat2)
Max7219_pinCS=0;
Write_Max7219_byte(add2);
Write_Max7219_byte(dat2);
Max7219_pinCLK=1;
Write_Max7219_byte(0x00); //片1寫入空
Max7219_pinCS=1;
/*第三片MAX7219的寫入數(shù)據(jù)*/
void Write_Max7219_3(uchar add3,uchar dat3)
Max7219_pinCS=0;
Write_Max7219_byte(add3);
Write_Max7219_byte(dat3);
Max7219_pinCLK=1;
Write_Max7219_byte(0x00);//片1寫入空
// _nop_();_nop_();
Write_Max7219_byte(0x00); //片2寫入空
// Max7219_pinCLK=1;
Max7219_pinCS=1;
/*初始化芯片*/
void Init_MAX7219(void)
Write_Max7219_1(0x09, 0x00); //譯碼方式:BCD碼
Write_Max7219_1(0x0a, 0x00); //亮度
Write_Max7219_1(0x0b, 0x07); //掃描界限;8個(gè)數(shù)碼管顯示
Write_Max7219_1(0x0c, 0x01); //掉電模式:0,普通模式:1
Write_Max7219_1(0x0f, 0x00); //顯示測試:1;測試結(jié)束,正常顯示:0
Write_Max7219_2(0x09, 0x00); //譯碼方式:BCD碼
Write_Max7219_2(0x0a, 0x00); //亮度
Write_Max7219_2(0x0b, 0x07); //掃描界限;8個(gè)數(shù)碼管顯示
Write_Max7219_2(0x0c, 0x01); //掉電模式:0,普通模式:1
Write_Max7219_2(0x0f, 0x00); //顯示測試:1;測試結(jié)束,正常顯示:0
Write_Max7219_3(0x09, 0x00); //譯碼方式:BCD碼
Write_Max7219_3(0x0a, 0x00); //亮度
Write_Max7219_3(0x0b, 0x07); //掃描界限;8個(gè)數(shù)碼管顯示
Write_Max7219_3(0x0c, 0x01); //掉電模式:0,普通模式:1
Write_Max7219_3(0x0f, 0x00); //顯示測試:1;測試結(jié)束,正常顯示:0
/**********************顯示程序**************************/
void dis(void)
unsigned char i,k,l,m;
DS3231_Read_time();//讀時(shí)間
l=RTC_Data[0]/10;//秒
k=RTC_Data[0]%10;//秒
m=RTC_Data[1]%10;//分
for(i=1;i<9;i++)//i是數(shù)字
Write_Max7219_1(i,disp1[k][i-1]);
Write_Max7219_2(i,disp1[l][i-1]);
Write_Max7219_3(i,disp1[m][i-1]);
/**********************主程序**************************/
void main ()
Delay_xms(1000);
Delay_xms(1000);
dis(); //顯示函數(shù)
