P_SW2寄存器的最高位EAXFR 是擴(kuò)展SFR訪問(wèn)控制使能
如下特殊功能寄存器位于擴(kuò)展 RAM 區(qū)域 訪問(wèn)這些寄存器,需先將 P_SW2 的 BIT7(EAXFR) 設(shè)置為 1,才可正常讀寫
- #include "reg51.h"
- #include "intrins.h"
- //測(cè)試工作頻率為11.0592MHz
- sfr P_SW2 = 0xba;
- sfr PWMCFG = 0xf1;
- sfr PWMIF = 0xf6;
- sfr PWMFDCR = 0xf7;
- sfr PWMCR = 0xfe;
- #define PWMC (*(unsigned int volatile xdata *)0xfff0)
- #define PWMCKS (*(unsigned char volatile xdata *)0xfff2)
- #define TADCP (*(unsigned int volatile xdata *)0xfff3)
- #define PWM0T1 (*(unsigned int volatile xdata *)0xff00)
- #define PWM0T2 (*(unsigned int volatile xdata *)0xff02)
- #define PWM0CR (*(unsigned char volatile xdata *)0xff04)
- #define PWM0HLD (*(unsigned char volatile xdata *)0xff05)
- #define PWM1T1 (*(unsigned int volatile xdata *)0xff10)
- #define PWM1T2 (*(unsigned int volatile xdata *)0xff12)
- #define PWM1CR (*(unsigned char volatile xdata *)0xff14)
- #define PWM1HLD (*(unsigned char volatile xdata *)0xff15)
- #define PWM2T1 (*(unsigned int volatile xdata *)0xff20)
- #define PWM2T2 (*(unsigned int volatile xdata *)0xff22)
- #define PWM2CR (*(unsigned char volatile xdata *)0xff24)
- #define PWM2HLD (*(unsigned char volatile xdata *)0xff25)
- #define PWM3T1 (*(unsigned int volatile xdata *)0xff30)
- #define PWM3T2 (*(unsigned int volatile xdata *)0xff32)
- #define PWM3CR (*(unsigned char volatile xdata *)0xff34)
- #define PWM3HLD (*(unsigned char volatile xdata *)0xff35)
- #define PWM4T1 (*(unsigned int volatile xdata *)0xff40)
- #define PWM4T2 (*(unsigned int volatile xdata *)0xff42)
- #define PWM4CR (*(unsigned char volatile xdata *)0xff44)
- #define PWM4HLD (*(unsigned char volatile xdata *)0xff45)
- #define PWM5T1 (*(unsigned int volatile xdata *)0xff50)
- #define PWM5T2 (*(unsigned int volatile xdata *)0xff52)
- #define PWM5CR (*(unsigned char volatile xdata *)0xff54)
- #define PWM5HLD (*(unsigned char volatile xdata *)0xff55)
- #define PWM6T1 (*(unsigned int volatile xdata *)0xff60)
- #define PWM6T2 (*(unsigned int volatile xdata *)0xff62)
- #define PWM6CR (*(unsigned char volatile xdata *)0xff64)
- #define PWM6HLD (*(unsigned char volatile xdata *)0xff65)
- #define PWM7T1 (*(unsigned int volatile xdata *)0xff70)
- #define PWM7T2 (*(unsigned int volatile xdata *)0xff72)
- #define PWM7CR (*(unsigned char volatile xdata *)0xff74)
- #define PWM7HLD (*(unsigned char volatile xdata *)0xff75)
- void main()
- P_SW2 = 0x80; //將P_SW2寄存器的最高位EAXFR置1,訪問(wèn)XSFR
- PWMCKS = 0x00; // PWM時(shí)鐘為系統(tǒng)時(shí)鐘
- PWMC = 0x1000; //設(shè)置PWM周期為1000H個(gè)PWM時(shí)鐘
- PWM0T1= 0x0100; //在計(jì)數(shù)值為100H地方輸出低電平
- PWM0T2= 0x0500; //在計(jì)數(shù)值為500H地方輸出高電平
- PWM0CR= 0x80; //使能PWM0輸出
- P_SW2 = 0x00;
- PWMCR = 0x80; //啟動(dòng)PWM模塊
- while (1);
